Southern California SoCal
Old 01-04-2017, 04:53 PM   #57
rainmonkey
Drives: BRZ - Dark Grey
Hey, so I have a perrin tune that was configured for CA 91 gas... I failed my smog today and the printout says OBDII Monitors Not Ready, Evaporative System, Oxygen Sensor
Everything else passed.
Now the thing is, I just had the battery replaced after the car was sitting dead for about a month (went out of town). Do I need to reflash to the stock ECU programming? Or just drive it for 100 miles to get 'wake the ECU up'?
rainmonkey is offline   Reply With Quote
Old 01-04-2017, 05:49 PM   #58
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
I would say drive the car at highway speeds to set the o2 sensor monitor and if everything else passed you should be fine with passing. EVAP being incomplete will still get the car to pass.
ExxelDistributions is offline   Reply With Quote
Old 01-05-2017, 12:47 PM   #59
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Originally Posted by ExxelDistributions View Post
new cars off the dealer lot when bought brand new are smog exempt for 6 years. But if you bring a car from out of state doesnt matter what year or mileage you need to get it smogged.
Hey, if a twin is bought from a private party and its been registered as Non Op for a year... does the car still need to be smog? Or still exempt since our twins have the 6 year rule? Thanks
Decimus is offline   Reply With Quote
Old 01-05-2017, 01:29 PM   #60
ExxelDistributions
6 Year rule does not apply to ownership transfers.
Old 01-05-2017, 02:47 PM   #61
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
So a smog certificate will still be required to get the car registered? Darnnn
Old 01-05-2017, 05:00 PM   #62
ExxelDistributions
Yes!
Old 12-05-2018, 04:00 PM   #63
thenameisnest
Drives: 2017 BRZ
Front Pipe
Can I pass smog if i have a Front Pipe (non catted)??
thenameisnest is offline   Reply With Quote
Old 12-05-2018, 05:40 PM   #64
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
No, you'll fail visual inspection.
Sent from my SM-G900V using Tapatalk
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 12-09-2018, 09:24 PM   #65
jflogerzi
jflogerzi's Avatar
Flex fuel kit would cause a failure correct? I if they see the aftermarket sensor and lines... Even if the stock tune and all other components we're stock..?
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 12-10-2018, 03:39 AM   #66
Phantobe
Phantobe's Avatar
Not sure on that one...
Im guessing If you were running 91 and the stock tune it'd pass, even though you had a ff kit.
May want to do some research yourself though.
Old 12-18-2018, 01:33 PM   #67
MrDinkleman
Drives: 2016 Oceanic, "base" model
Regarding the EO# label, I bought a TRD intake on line. It is 50 state compliant and has an EO#. But because I bought it on line I didn't get the sticker. Does it have to be the "official" sticker or can I just tell the smog tech the EO#?
Thanks
MrDinkleman is offline   Reply With Quote
Old 12-18-2018, 01:39 PM   #68
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Thanks
If I remember correctly, the TRD intake kit does not include the sticker. If you want one you have to get it at the dealer, about $16.
MrDinkleman (12-25-2018)
Old 01-02-2019, 08:51 PM   #69
MrDinkleman
So, I went to the dealer today to buy some parts, including the sticker. He told me they can't just sell the sticker, willy-nilly. He said I need to go to the dealer I originally purchased it from with proof of purchase. And THEN they will contact Toyota Corporate who will ship them the sticker...
So, plans B and C:
B. Anyone have one for sale?
C. Can anyone post a hi-rez pic that I can just print and stick on the airbox?
Thanks...
Old 01-02-2019, 09:38 PM   #70
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
EO# should be sufficient...Have the same issue with my Cummins 5.9 intake...
vintagemxer is offline   Reply With Quote
Smog check for out of state people? goshem Southern California 4 09-25-2015 06:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 11:05 AM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-26-2015 11:19 PM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 12:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-19-2014 11:57 PM
