View Poll Results: Which gas is better?
Shell 50 44.64%
Chevron with Techron 27 24.11%
Mobil/Exxon 5 4.46%
BP 5 4.46%
other. please state. 25 22.32%
Voters: 112. You may not vote on this poll
Old 12-13-2018, 11:04 AM   #57
Victorscp
Drives: 2018 BRZ premium
Originally Posted by PetrolioBenzina View Post
Nope, you know exactly where the noise is coming from if you have crickets.
damn squeaky ass cabin... its brand new i cant find that noise and its annoying lol
Victorscp is offline   Reply With Quote
Old 12-13-2018, 12:18 PM   #58
The good news is that after 100,000 or so miles everything wears into place and all the squeaks go away.
jflogerzi (12-13-2018), why? (12-19-2018)
Old 12-13-2018, 12:22 PM   #59
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Are you sure? I figure you just learn to ignore them.
Old 12-13-2018, 12:33 PM   #60
That was the interim solution yes but I only get any real noises now when it hits about -10 out and pretty much any car made makes noises at that point.
Old 12-18-2018, 07:41 PM   #61
yurikaze
yurikaze's Avatar
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
Has anyone run both 93 and 91 and noticed any difference?
Not being able to run anything above 91, I'm curious to see how much (if any) performance I'm losing since the manual specifies 93.
yurikaze is offline   Reply With Quote
Old 12-19-2018, 05:34 AM   #62
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by Decep View Post
These are mass produced engines that aren't really anything special... any decent gas station where the gas doesn't sit for months should be fine.
12.5:1 compression ratio... so yeah, gas does actually make a difference.
It really depends on your area. If you go to a low volume crappy station that isn't maintained well but carries the best brand of gas it won't matter- it'll be crap. In Tampa, in my area at least, the best stations are Shell and there's one Citgo too. The are high volume, well maintained and carry 93 (I never see 91 in this area, but 93 is common).
Remember, if they don't take care of the facilities above ground, they probably aren't taking care of the tanks below ground.
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
chaoskaze (12-19-2018), Tcoat (12-19-2018)
Old 12-19-2018, 06:19 AM   #63
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
93 vs 91 has difference, atleast thats how i feel when i had 94 in it when it was stock. But how long the gas been sitting matters too.
It just feel more smooth reving it out.
The Following User Says Thank You to chaoskaze For This Useful Post:
yurikaze (12-19-2018)
Old 12-19-2018, 08:07 AM   #64
gravitylover
Haha yeah, my car is quieter than it used to be too. Not squeak free but certainly bearable. We have more expensive cars that are worse.
The Following User Says Thank You to gravitylover For This Useful Post:
Tcoat (12-19-2018)
Old 12-19-2018, 08:29 AM   #65
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
It is noticable but it isn't a night and day difference.
When I made the switch to 94, the engine felt smoother to rev out and the occasional knocks went away.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 12-19-2018, 10:49 AM   #66
There is a bit of a difference but it isn't huge. You will not notice any change at all when you first switch because it takes time and miles for the ECU to learn the change in the engine and advance the timing a bit. This gradual change also means that the difference is blurred a bit because the improvement is incremental not direct. Anybody that thinks they feel an immediate change when changing from one octane level to another are simply experiencing confirmation bias since the ECU has not made adjustments yet.
bcj (12-19-2018), nikitopo (12-21-2018), yurikaze (12-19-2018)
Old 12-21-2018, 10:41 PM   #67
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
I have to drive 80 miles to buy anything more than 91 octane. If I do so, I can fill my tank with 93 octane but then I have to drive 80 miles home on boring Interstate and waste about 2 1/2 gallons of 93 octane fun. That and if there was an appreciable amount of 91 octane left in the tank the mixture doesn't really hit 93 octane anyway.
BUT, the same station that has the 93 octane also sells 102 octane. Instead of buying 93, I bring a 5 gallon gas can and fill it with 102 octane and head home. Now, when the time comes to have some fun, I put 2 1/2 gallons of 102 in the tank and top it off with 91 which results in a solid 93+ octane tank.
Yes, it takes a few miles for the ECU to realize what happened but there is a definite difference. And I can get two tanks of 93+ using my 5 gallons of 102.
Here is a handy site for finding 93 octane and calculating mixtures:
https://find93.com/
LimitedSlip is offline   Reply With Quote
Old 01-08-2019, 06:56 PM   #68
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Originally Posted by itsAlex View Post
I normally use Costco 91 gas since its top-tier certified. Based on the previous posts I assume Costco in the states offers 93, I haven't seen 93 at any Costco yet here in Ontario. Where I live in southern Ontario Esso offers 93 and Petro offers 94.
+ 1, Costco 91 (No 93 available in CA)
eastendraceshop is offline   Reply With Quote
Old 01-08-2019, 08:44 PM   #69
OwlDance
Drives: Halo 86, '19
Well since this thread is back up, I tried Sunoco 93 e10 the other day and the difference between it and the one Shell station I keep going to was like night and day. The engine's a little quieter and less rackety than the 93 e10 Shell V-powerwhatever. I actually feel like I'm not wrecking my engine when I bring it above 4K RPMs. It's "quieter" and smoother from idle to all the way to redline.
With the active MPG monitor (probably not 100% accurate but w/e) I can both feel and tell the engine is pulling more weight, and more easily on the same stretch of highway commute. At 5th gear (absurdly tall on the AT) I can use less gas and feel the car accelerate more easily (23.4 mpg under light acceleration), whereas I could be harder on the throttle and not feel like I'm going anywhere with the shell 93 (18.X MPG under light acceleration and still accelerating more slowly than the Sunoco). I swore I even felt a difference almost as soon as I put in fresh gas into the car.
The downside is, I'm hoping I haven't just been putting crap gas in my new car for the past however long I've been using that station. This isn't an indication of Shell as a whole but more likely just that station. It's probably just paranoia about owning babby's first sports car, but I digress.
Lesson learned. Vary the gas stations until you find one the cheapest one that feels just right to you I guess.
OwlDance is offline   Reply With Quote
Old 01-12-2019, 06:27 PM   #70
jflogerzi
jflogerzi's Avatar
Local e85 baby. This car loves corn juice. Drives so smooth with a tune and uel headers.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
AAA: Top Tier Fuel Study tekFRS234 Scion FR-S / Toyota 86 GT86 General Forum 31 07-14-2016 07:52 PM
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 2 07-03-2016 02:50 AM
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 0 06-26-2016 11:57 AM
Costco Gas now Top Tier N1rve Off-Topic Lounge [WARNING: NO POLITICS] 22 04-15-2014 06:19 PM
Companies supplying top-tier gasoline in the USA and Canada FRiSson Scion FR-S / Toyota 86 GT86 General Forum 30 10-11-2012 04:40 PM
