View Poll Results: Which gas is better?
Shell 50 44.64%
Chevron with Techron 27 24.11%
Mobil/Exxon 5 4.46%
BP 5 4.46%
other. please state. 25 22.32%
Voters: 112. You may not vote on this poll
Old 11-02-2018, 01:06 PM   #1
Twin-Dragons
Drives: toyota 86
Exclamation The BEST Top Tier Gas For Our Cars
Now before you say "not this thread again", yes, i understand, im sure this has been posted many times, but since our car has been out for 6 years now, it would be a good time to make a thread about which gas is better, since more people have experimented over the years..
That being said, for the people who live in the USA (not sure about canadian gas), which gas brand works better in our cars, in terms of better gas mileage, less knocking, smoother idles, and better performance.
And yes, i know, it's all the same gas, but im talking about which gas has the best additives...
I added a poll
Twin-Dragons is offline   Reply With Quote
Old 11-02-2018, 01:11 PM   #2
Brand has little to with it and fuel is not consistent from region to region anyway. Just get the newest fuel you can find no matter what brand and all is good.
extrashaky (11-03-2018)
Old 11-02-2018, 01:25 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
you should read the list.
https://toptiergas.com/licensed-brands/
"Top Tier Gas" only means it has to meet a level of additives. Branding doesn't matter on the retail level.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
JohnJuan (11-06-2018), Tcoat (11-02-2018)
Old 11-02-2018, 01:29 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Here, all gas comes from the same refinery, and none of the brands add enough of anything to matter. For example, years ago Porsche did a study of fuel additives. They determined that the Chevron Techron was the best and actually worked, however, Chevron doesn't put enough of it in the fuel to do anything. If you want the cleaning of Techron you have to buy bottles of it (yes, they do sell it, and it is expensive) and add it.
Again, it is all the same. Buy the cheapest at the station that has turnover.
And "Top Tier" is a marketing gimmick.
Old 11-02-2018, 03:58 PM   #5
stevesnj
stevesnj's Avatar
Sunoco 93 since day 1
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Spuds (11-02-2018), Teseo (11-02-2018)
Old 11-02-2018, 04:06 PM   #6
Akari
Drives: 2013 DGM BRZ
I usually just go for high-volume stations that are affordable.
Been running mostly Costco 92 (They do so much volume that they refill their tanks twice a day), have had 0 issues and my FI tuner was able to get a few more degrees of timing than normal.
If you experience any performance issues, knocking, or unsmooth idle, especially NA, then there's a pretty major problem with the fuel you're getting.
Akari is offline   Reply With Quote
The Following User Says Thank You to Akari For This Useful Post:
Dadhawk (11-03-2018)
Old 11-02-2018, 04:08 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yeah, I've noticed less knock correction on Sunoco in MD-PA than others. Used to like Shell but half the time my IAM drops when running it. Could just be the local stations though. Not enough traveling data to see a trend elsewhere.
The Following User Says Thank You to Spuds For This Useful Post:
stevesnj (11-02-2018)
Old 11-02-2018, 04:10 PM   #8
milanojess
milanojess's Avatar
Drives: 2013 FRS
All said and true, most first tier brands have consistent quality fuel, while no name brands often suffer with less performance, check engine when pushed, etc. ive seen these behavior with Costco, Valero, and other no name gas disguised as shell. The last one apparently took over an old shell station and pumped unknown gas. I was puzzled why I wasn’t able to reach expected speed until I returned to gas station next day in day light... went to gas up at nearby major gas and had no problem getting to top gear before turn 8 on willow springs.
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 11-02-2018, 04:12 PM   #9
arkanist
Drives: 2016 BRZ Limited, Stock
My tuner told me to go with Chevron, so I do.
arkanist is offline   Reply With Quote
Old 11-02-2018, 06:08 PM   #10
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
The manual says 93, or 91 if that's all that is available so I go by highest octane available from stations with high fuel turnover.
So... Chevron 94 for me (ethanol free).
wolffbite is offline   Reply With Quote
The Following 2 Users Say Thank You to wolffbite For This Useful Post:
stevesnj (11-02-2018), Teseo (11-02-2018)
Old 11-02-2018, 06:15 PM   #11
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
For my engine, I've felt Chevron being the smoothest.
But I don't fill them because they're so pricey.
I fill Shell (2nd best for my engine) because of their fuel rewards program giving me $0.05 off each fill and the occasional extra $0.25 from T-Mobile Tuesday. I've saved $100.16 ever since I've started ... 2 or 3 years ago?.
Old 11-02-2018, 06:22 PM   #12
Impureclient
Drives: 2015 FR-S
Since the last cricket fix I had done a couple years ago I've only ever ran Chevron 93 and the chirp has stayed gone so I'm sticking with that.
Impureclient is offline   Reply With Quote
Old 11-02-2018, 06:38 PM   #13
Decep
Drives: 2013 FR-S Series 10
These are mass produced engines that aren't really anything special... any decent gas station where the gas doesn't sit for months should be fine.
The Following User Says Thank You to Decep For This Useful Post:
Tcoat (11-02-2018)
Old 11-02-2018, 06:49 PM   #14
Teseo
Drives: frs
So jelly, how much per liter?
AAA: Top Tier Fuel Study tekFRS234 Scion FR-S / Toyota 86 GT86 General Forum 31 07-14-2016 07:52 PM
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 2 07-03-2016 02:50 AM
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 0 06-26-2016 11:57 AM
Costco Gas now Top Tier N1rve Off-Topic Lounge [WARNING: NO POLITICS] 22 04-15-2014 06:19 PM
Companies supplying top-tier gasoline in the USA and Canada FRiSson Scion FR-S / Toyota 86 GT86 General Forum 30 10-11-2012 04:40 PM
