Old 12-12-2018, 03:20 PM   #29
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Stang70Fastback View Post
I would imagine someone would have to be a complete ass to contest that, since all it's doing is saving you 10 seconds of looking like a moron every time you want to enable it, lol. In for the answer to this question, though, because some people are all about the technicalities.
I would assume shouldn't be an issue. Other tuning can technically disable and enable those kind of things and STX class allow tuning.
Keyword: "assume"
Old 12-12-2018, 04:09 PM   #30
Kenny_LongWrench
Tacticool_BRZ
Kenny_LongWrench's Avatar
Drives: ZC6 - AW11
With enough interest, more Beastronix units can be made and sold by CSG.
Count me in, too.
Kenny_LongWrench is offline   Reply With Quote
The Following User Says Thank You to Kenny_LongWrench For This Useful Post:
TheStig85 (12-19-2018)
Old 12-12-2018, 04:18 PM   #31
CSG Mike
CSG Mike's Avatar
Hang tight guys. Beastronix is not gone forever! May be a few months, but should be before the season starts for most of the country.
The Following 15 Users Say Thank You to CSG Mike For This Useful Post:
arkanist (12-12-2018), cjd (12-12-2018), conedodging (12-12-2018), Enkrow (12-19-2018), Iceman (12-13-2018), jbailey8748 (12-16-2018), Joesurf79 (12-12-2018), kch (12-19-2018), Kenny_LongWrench (12-13-2018), Stang70Fastback (12-12-2018), Takumi788 (12-13-2018), TheStig85 (12-19-2018), Tristor (12-13-2018), whataboutbob (12-19-2018), why? (12-20-2018)
Old 12-12-2018, 05:07 PM   #32
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by conedodging View Post
Might be interested, can't remember if these were ruled legal for STX or not.
I thought you couldn't disable ABS but turns out you can per 14.6.D so probably a gray area and a definite weenie protest since it doesn't do anything not already programmed into the car except for killing the ABS.
ineedyourdiddly
CSG Mike (12-12-2018)
Old 12-12-2018, 05:12 PM   #33
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Doesnt Beastronix just enable "Padal Dance Mode?" That doesn't disable ABS.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 12-12-2018, 05:43 PM   #34
strat61caster
It has a mode that disables ABS to prevent Ice Mode from happening.
https://support.beastronix.com/porta...the-86nanny-v2
ineedyourdiddly
Old 12-12-2018, 06:38 PM   #35
CSG Mike
CSG Mike's Avatar
Depends on configuration!
jbailey8748 (12-16-2018), Stang70Fastback (12-12-2018)
Old 12-12-2018, 06:38 PM   #36
Stang70Fastback
A.K.A. Starlord
Ahh. Well that just sounds like a safety feature to me! :P
Ultramaroon (12-13-2018)
Old 12-12-2018, 08:46 PM   #37
cjd
cjd's Avatar
Drives: 2017 BRZ
Unfortunately, for STX it potentially runs afoul of the "and nothing else" portion of the rule for systems that disable ABS electronically (the only legal way to do so).
If it were JUST pedal dance, you might be able to argue that it's an ABS disable feature, with a convenience option to do pedal dance the easy way (since you DO NOT NEED the device to do pedal dance)
With the fan switch mode, it might be too many 'convenience' features.
Anyone that protests for it is a pathetic sore loser, but...
Unless it is easy to break out each of the features into a separate box that's daisy-chained on the OBD circuit, you're taking a chance in STX with this.
I'd definitely be interested in acquiring one again - I sold my old one when I had to get the new car because the 17+ hadn't been resolved at the time... though disabling ABS turned nasty ice mode into flat-spotting, I've worked on my braking technique a LOT since then.
The Following 2 Users Say Thank You to cjd For This Useful Post:
ichitaka05 (12-13-2018), Stang70Fastback (12-13-2018)
Old 12-13-2018, 09:19 AM   #38
Evan55
Drives: 06 Exige, 17 BRZ PP
Openflash tablet can disable traction control and ice mode too, correct?
Evan55 is offline   Reply With Quote
Old 12-13-2018, 11:48 AM   #39
conedodging
conedodging's Avatar
Drives: '14 BRZ
It bothers me that both functions being in the same box is what matters. They're on separate switches, so each switch does only one function.
conedodging is offline   Reply With Quote
Old 12-13-2018, 01:50 PM   #40
CSG Mike
CSG Mike's Avatar
AC switch = fan switch. Just saying
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
ka-t_240 (01-03-2019), Ultramaroon (12-13-2018), whataboutbob (12-19-2018)
Old 12-13-2018, 07:49 PM   #41
cjd
cjd's Avatar
Drives: 2017 BRZ
Write the board. This isn't the place for a discussion on the merits of the rule as written, but in this case: I agree. I don't know what caused the rule to be written that way though. The combo oil cooler/radiator is also not legal, same fundamental reason.
Yup. That's what I do now when I need to - I usually put it to the floor vent and stuff my helmet under while I'm at it, helps dry it out and keeps it cool. My 86nanny only had PD/ABS (and tpms light) features...
I'll also be writing a letter along the way, but need a little more research.
For that matter, I'll be testing PD at the spring test-n-tune, whether I have an 86nanny or not.
Old 12-13-2018, 08:34 PM   #42
Hades
Hades's Avatar
Drives: 2013 Scion FRS
Well there's something I didn't know I wanted...
+1
Hades is offline   Reply With Quote
WTB a Beastronix 86 Nanny unit tonylop33 Want-To-Buy Requests 0 09-25-2018 07:14 PM
FS: Beastronix 86 Nanny - SOLD Agent_D Engine, Exhaust, Bolt-Ons 3 05-09-2018 01:57 PM
Beastronix Install HoonThis Software Tuning 4 06-08-2017 10:02 PM
Flex Fuel Kit and Beastronix 86Nanny Trac/VSC Juanito08 Engine, Exhaust, Bolt-Ons 7 05-10-2017 02:20 PM
Beastronix - 86 Nanny , Speed Academy version brzaapi User/Vendor/Sponsor Reviews, Feedback, Comments 4 07-05-2016 11:17 AM
