#99 |
Drives: MR2, Sliver BRZ
I once saw a BRZ 2016 in LKQ which i was shocked! But mine was a Small yard who have a somewhat focus on FRS/BRZ/86 cars. Not sure just remembered there close to LAX. IF i find out the address il let ya know.
Always looking to tinker with something..
#100 |
Drives: FR-S RS 1.0 #1037/1500
I'm 100% for putting the buttons where the turnkey would be
#101 | |
Drives: 2013 FRS
Sent from my Moto Z (2) using Tapatalk |
#102 | |
Le Ingenieur
Drives: 2015 Subaru BRZ Aozora
http://car-part.com/ I just looked at this site and found one randomly relatively nearby, within ~150km. Check your state, YMMV. GL with the hunt |
#103 |
I Love custom Turbo kits
Drives: Limited BRZ
I confirm the cluster works on older models. Got it working yesterday! From a limited 2017 BRZ to a 2013 limited BRZ.
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
#104 |
Drives: 2013 WRB Subaru BRZ Limited 2.0
Has anyone attempted wiring up the new cluster AND the new steering wheel with controls?
#105 |
That would require a new airbag, new clock spring, steering wheel, And repining the connector from the clock spring into the rest of th harness. Then adding the three other cables from that connector into the cluster connector. If you dont want to do that you will need to then buy a new dash harness too.
#106 |
Drives: 13 BRZ Sport Tech Turbo
thanks for this great thread! I picked up a 2017 cluster from a part out and have been pretty excited to get it into my 2013 BRZ - I've been on the search for a new steering wheel but after reading through this thread - @geraldjust I think your kit with the printed joystick is a fantastic option! You have put an incredible amount of work into sorting this all out! Thank you!!
#107 | |
Drives: Project BRZ
Just wondering is there a setting in the eeprom for the 2017 BRZ to have the G meter to work even while driving or you have to flash with the GT86 eeprom to get that to work. Thanks. |
#108 |
Drives: 2013 Ultramarine FR-S
Got my techstream today. Only issue being my windows partition on my MacBook is almost full and I can’t unzip the techstream file -_- As soon as I can get this inconvenience figured out I will be testing the Turn Key programming with an eBay techstream.
#109 | |
For now my best guess it that its a simple bit that tells whether to load the BRZ program or 86 program. and the rest of the settings minor like Km and C or F. If anyone had a Any of these clusters in a different market and it acts different let me know. Perhaps like the Eurospec one does something different. At the end of the day, i can always switch the cluster to a gt86 and turn off the welcome screen. @DustinS Let me know how that works! some techstream "ebay" programs come fully unlocked. Even the utilities to bind the clusters to the Body control modules. Some dont either.
#110 | |
Drives: Limited BRZ
gt86 2017 cluster working on a pre 17 car
![]() ![]() [ame]https://www.youtube.com/watch?v=dW0NsyIDRU8[/ame] These are @geraldjust buttons working on a 2013 BRZ Very happy with the results, fits like a glove and works perfectly! The buttons feel really natural in that position.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | DustinS (01-30-2019) |
#111 |
AT Pleb
Drives: 2014 FR-S Monogram (Firestorm Red)
Did you say you were able to select the boot animation? I've been able to track down a cluster from a BRZ, but I have an FR-S, would you be able to select the Toyota boot animation?
Knowledge is knowing that a tomato is a fruit. Wisdom is not putting it in a fruit salad. |
#112 |
YUP! Im able to reprogram it for either animation.
If you want.. i have a 86 cluster but i want a BRZ we can always swap if your looking for one that has that white outline like the FR-S.
| 2017 Limited Gauge Cluster | halleffect | Electronics | Audio | NAV | Infotainment | 26 | 10-22-2020 07:32 PM |
| 2017 GR edition cluster mod | vagthomas | Cosmetic Modification (Interior/Exterior/Lighting) | 63 | 06-29-2020 04:41 PM |
| Help! Is there anyway to change the 2017 cluster start up image? | slashlee | DIY (Do-It-Yourself) Guides | 2 | 11-17-2018 05:36 PM |
| 2017 Limited Gauge Cluster | halleffect | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-16-2017 03:55 AM |
| 2017 gauge cluster | Drakiv | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-14-2016 11:32 PM |
