Old 06-08-2012, 02:57 PM   #15
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Originally Posted by sadiqawos View Post
One relatively easy interior mod for Fr-s owners should be swapping the center console of the fr-s for the one in the GT-86 or even the Brz. it looks a lot nicer, it has the push to start button that can be wired into the stock harness and you also don't have to worry about cutting holes into the original bezel.
fr-s center console
GT-86 center console
Another mod that can be done is building a car computer with touch screen display instead of the crappy stock one.
I was thinking the same thing.
Cessblood is offline   Reply With Quote
Old 06-09-2012, 10:45 PM   #16
arbnpx
Originally Posted by Honeydew View Post
Wow i would wish i could do that dont know how pricey it could get though. I thought that the Fr-s doesn't have dual climate control so you just dont wire up some of those buttons??
I'm starting to research a dual zone climate swap as well. One of the guys in the JDM parts buy topic started by Carson mentioned that the heater box would probably have to be changed out. I looked at the FR-S heater box, and it has two gears turned by the cables on the two front dials: temperature, and HVAC mode (the fan speed dial is an electric switch dial). I got a chance to take a picture of the BRZ Limited heater box side, and there's a motor that turns a gear, though I'm not sure which one it is.
I'm thinking of starting a topic to research what it would take for an FR-S dual zone climate conversion. One thing I have to get past, first: how to remove the center console panels. The radio one is probably easier to remove, but I'm not brave enough to try yet without proper trim tools. The HVAC one might be a bit harder, but again, I'm not brave enough to start pulling at panels.
arbnpx is offline   Reply With Quote
Old 06-11-2012, 03:56 PM   #17
Cessblood
I just P.M. Carson Toyota to see if he can get any info on this for us.
Old 06-12-2012, 04:16 AM   #18
TheChopShop
TheChopShop's Avatar
Drives: 2013 Whiteout 6sp
I'm on the fence about this. I like the gt86, however I like the simplicity of the FR-S. I guess it depends on the cost and difficulty of the swap. I've done a RHD swap (Lexus GS300) and a couple 5-speed swaps, so difficulty isn't a problem, more of a hassle on a brand new car.
But a dry carbon piece behind the dials might be in the works for me.
TheChopShop is offline   Reply With Quote
Old 06-12-2012, 07:09 PM   #19
Ess Vee
Ess Vee's Avatar
Drives: White 2011 Camaro 2SS 6MT
I called my local Subie dealer to see if I could order the BRZ's ac-control unit (since it's the same as the GT86's) but supposedly you can only order individual parts and would have to assemble the unit yourself.
Ess Vee is offline   Reply With Quote
Old 06-13-2012, 10:51 PM   #20
arbnpx
Interesting; I'll have to see what the total cost of all the parts would be. I imagine that it includes the control panel, at least one servo unit, maybe two, and maybe some harnesses and boxes.
Old 06-14-2012, 12:04 AM   #21
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
I will be replacing the orange LED's for the climate controls when I get my FR-S.
|-Goku-| is offline   Reply With Quote
Old 07-15-2012, 05:57 AM   #22
JiB
JiB's Avatar
Drives: GT86
Just saw a youtube clip of this car cruising around Suzuka and i was admiring the dials in the dash, anyone seen these for sale anywhere or thought about doing it themselves? i really like the look, and it would be handy knowing what your temps are running at
JiB is offline   Reply With Quote
The Following User Says Thank You to JiB For This Useful Post:
MiguelAE86 (07-19-2012)
Old 07-15-2012, 08:05 AM   #23
|-Goku-|
|-Goku-|'s Avatar
That looks awesome!
Old 07-15-2012, 02:21 PM   #24
TRD_86
Drives: 2013 86 white
I think just wait for few months the complete GT86 JDM center console kit will be available to make it ez swap. That cheap black plastic around the knob & dials need to be upgraded w/ nicer trim like from lexus IS sedan; and then upgrade the stock HU to top of the line Alpine or Kenwood NAV. There will be tons of coming accessories available for the market of this car itself. It's a hobby to own this car and proud to play with it !
TRD_86 is offline   Reply With Quote
Old 07-15-2012, 02:47 PM   #25
xcelir8brz
Drives: 2013 BRZ Limited
Considering mounting small tablet flush there with obd ii driving virtual gauges.
xcelir8brz is offline   Reply With Quote
Old 07-16-2012, 12:48 PM   #26
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I have the Torque app on an android tablet and I sync it up to an ELM327 bluetooth OBDII adapter to pull live OBD data for my MR2... I haven't been able to use it since I went to a LinkECU, but I will definitely be setting it up on my FR-S for random OBD info + datalogging. Well worth the 5 dollars, IMO.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following 2 Users Say Thank You to deucethemoose For This Useful Post:
MiguelAE86 (07-19-2012), xcelir8brz (07-16-2012)
Old 07-17-2012, 12:21 AM   #27
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Climate Control swap is probably far more invasive than you think. With the GTOs, the US market manual climate control was vacuum operated, while the Australian market dual zone was electrically actuated. I believe there was Body Control Module programming that needed to be done as well. Those units are very rarely self contained.
LSxJunkie is offline   Reply With Quote
Old 07-17-2012, 12:08 PM   #28
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
I was just thinking about gauges in the plastic panel this morning. I would love for someone to come out with a carbon version like this one though!
Center Armrest Sovran Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2012 12:49 AM
FR-S center stack blk Scion FR-S / Toyota 86 GT86 General Forum 81 02-29-2012 01:03 AM
What will be the first upgrade you buy for your FR-S / BRZ? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 9 02-26-2012 07:30 PM
FR-S / FT-86 Colors, Instruments, and Center Console/Dash Now Revealed Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 202 11-25-2011 08:21 AM
truck got hit. time to upgrade... NESW20 Other Vehicles & General Automotive Discussions 20 06-12-2011 01:43 PM
