Old 12-04-2018, 02:38 AM   #1
Cojonudo
I'm New
Cojonudo's Avatar
Drives: 2016 Limited Subaru BRZ White Pearl
Tire Fitment 18x9.5+35
Hey guys, I just got my wheels in they are 18x9.5 with an offset of +35. I was looking at running 245/35/18 in the front and 255/35/18 on the rear. I have a 1 inch drop. Will I experience any rubbing with this setup? If anyone is running this setup and can give some input, it would be greatly appreciated. I'd like to get the wheels as flush as possible but don't want to be rubbing. Thank you.
"You do you"
Cojonudo is offline   Reply With Quote
The Following User Says Thank You to Cojonudo For This Useful Post:
JeremyR (12-11-2018)
Old 12-05-2018, 12:05 AM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Are you running springs or coils?
And what is your alignment specs?
https://www.ft86motorsports.com/wheelitfit/
tyler_win_photo is offline   Reply With Quote
Old 12-05-2018, 01:07 AM   #3
Cojonudo
I'm New
Cojonudo's Avatar
Springs
"You do you"
Old 12-05-2018, 02:48 PM   #4
kch
Senior Misanthrope
kch's Avatar
Originally Posted by Cojonudo View Post
Springs
And your alignment?
Depending on your alignment, you may rub on the front fender or the front spring perch. You might be able to fit 245s on those wheels, but it will require some fiddling.
Regardless, I would suggest two things:
(1) Don't stagger your tire sizes. There's no reason to do so. The car was designed for a square setup. Staggering also means you can't rotate your tires front-to-back.
(2) Ideally, you should be running a 255 or 265 on those wheels. 245 won't be dangerous or anything, but it's not ideal. But you'll have problems fitting 255 or 265s, so either get coils and add -2.5 front camber, or get different wheels that fit better on stock dampers.
The Following User Says Thank You to kch For This Useful Post:
Leonardo (12-05-2018)
Old 12-08-2018, 08:58 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
For the rear you'll be fine. The front I'm not 100% sure because you might rub on the spring perch. If you are willing to stretch tires, 235 won't rub in the front. 245 is a maybe. 255 I think you will. This also depends on brand of tire as well. Federals run wider than they really are.
I have the same set up, but I switched to coils. Also, you'll have some pretty bad poke in the front without any negative camber adjustment, just FYI on that, it won't be "flush" per se.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Leonardo (12-09-2018)
Old 12-09-2018, 04:52 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I concur.
I LIKE TIRES!
Old 12-10-2018, 07:53 PM   #7
Cojonudo
I'm New
Cojonudo's Avatar
Yeah I went to my local tire shop and they suggested doing 245s all around
"You do you"
Old 12-11-2018, 11:31 AM   #8
N1rve
N1rve's Avatar
Just don't get federals or else you might rub at 245.
N1rve
Old 12-11-2018, 01:37 PM   #9
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Hi there.
Do not stagger your tire sizes. If your wheels are all 18x9.5 than you need to run the same size tire all around or else you will run into issues with oversteer/understeer.
An 18x9.5 should run a 255/35/18 or larger tire. Anything less will not be ideal, UNLESS you specifically want the stretched tire look, or a stanced out car.
If you are doing grip driving, go with a 255 or larger. I run a 18x9.5 +40 with a 265/35/18 and it did/does rub if you do not apply enough camber.
The fact that your wheels are a +35 means they will stick out farther than mine do, so I could imagine they will rub on the fenders unless you add a decent amount of camber. However, you only have a 1 inch drop, which is not much, so I don't think you would have any rubbing issues.
You should check out the meaty tire thread! There are lots of people running the same setup as you.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 02-27-2024, 11:02 PM   #10
Kiyora
Kiyora's Avatar
Drives: 2013 Subaru BRZ / 2013 Scion FRS
Hello,
Been reading on the forums about tire size, I am currently running 18x9.5 with 255/35 and I am on coils. I experience rub only sometimes, is it because the tire size?
Kiyora is offline   Reply With Quote
Old 02-28-2024, 02:12 AM   #11
alphasaur
friendly
Drives: 17' 86
I needed 5mm spacers on the front for 17x9 35 offset with 255 tires. ymmv.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 02-28-2024, 01:17 PM   #12
RedReplicant
Drives: None
I run either a 3mm or a 5mm spacer up front to keep the tire out of the coil on 17x9.5 +45 depending on which 255 I am running at the time.
ymmv also
RedReplicant is offline   Reply With Quote
Old 03-22-2024, 03:13 PM   #13
tyler_win_photo
Originally Posted by Kiyora View Post
Hello,
It could be a number of things. Offset, alignment, ride height. I run a 255/35 on 18x9.5 +38 but with about an inch drop with -3.3 camber up front and -2 rear I do not get any rub even on track.
Old 03-25-2024, 01:06 PM   #14
N1rve
N1rve's Avatar
Hello,
Depends, could be tire brand like Federals are wider than they should be. Also the amount of negative camber and offset of the wheels could affect it. The measurement of 255 isn't consistent among all of the tire manufactures as there are some variances.
You didn't state if it was the front or the rear, I am guessing the front since that's where the clearance issue usually happens. Dial back some negative camber and you may need to raise the car.
In essence it's more like the tire brand than the actual size.
N1rve
quick question 18x9.5+38 fitment/tire size BlaqkHavok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-18-2018 09:41 AM
18x9 +30 wheel tire fitment help! Tomec.lunasin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-18-2016 04:37 PM
Need help on tire fitment white_frs_e46 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-03-2015 07:25 PM
Need help on tire fitment, Please! Rbmonroe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-20-2014 01:52 PM
Eibach Sportline, 18x8 35, 18x9 38, 245F/265R tire/wheel fitment Q Blizzz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-14-2014 05:28 PM
