Old 12-04-2018, 12:51 AM   #50933
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Fuck no. All that shit does is make a mess.
Sounds ruined. Start part out thread.
Sapphireho is offline
Old 12-04-2018, 12:53 AM   #50934
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
A shout out to @Leonardo. Great job on the stickers, perfect fit. Also, thanks for the little light. Thank you so much!
Unfortunately my clock idea is dead. No one makes a clock motor with a long enough shaft. It will just have to be a wheel on the wall.
How long does it have to be? You can probably make a few shaft extensions of various diameters...
Spuds is offline
Old 12-04-2018, 01:03 AM   #50935
Well, I reckon you're jest ah usen too much, you don't hafta use the whole can -
I was usen belt dressing before you were born, on bigger belts than you have ever worked around. It was black sticky stuff that came in large cylinder shaped tubes. The only difficulty was to figure out which side of the belt to treat, when they crossed the belt to make the machine run in the proper direction.
humfrz for Bubba
humfrz is offline
Sapphireho (12-04-2018)
Old 12-04-2018, 01:09 AM   #50936
totaled
Ultramaroon is offline
Old 12-04-2018, 01:21 AM   #50937
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The longest threaded shaft i can find is 15/16. I need like 1 7/16.
The other option is machining the inside of the rim, but then the clock gets way too expensive.
Old 12-04-2018, 01:44 AM   #50938
But then you're just hanging a wheel on the wall.
Old 12-04-2018, 01:47 AM   #50939
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I know. So disappoint.
Old 12-04-2018, 01:55 AM   #50940
You have to make the clock. Otherwise you're just keeping it for spite.
...which is still a good enough reason but it's no clock.
Spuds (12-04-2018)
Old 12-04-2018, 08:01 AM   #50941
Tcoat is offline
Old 12-04-2018, 08:39 AM   #50942
Spuds
The Dictater
Spuds's Avatar
Another option is making bent arms.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (12-04-2018)
Old 12-04-2018, 09:53 AM   #50943
cjd
cjd's Avatar
Drives: 2017 BRZ
Nothing that fits inside the center bore?
cjd is offline
Old 12-04-2018, 12:27 PM   #50944
Sapphireho
Famous Potatoes
Sapphireho's Avatar
No, a 1.5 inch threaded shaft would just give me enough to get thru the center cap. I would still have to bend the arms to clear the rim spokes. To have straight arms I would need about a 3 inch shaft.
Old 12-04-2018, 12:29 PM   #50945
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I found a small round clock motor that would fit in the bore. It is commonly used to restore old auto clocks, but it is super wimpy and only has enough torque to handle 1 inch arms, so it would be a very tiny clock in a big rim.
Old 12-04-2018, 12:43 PM   #50946
Oooo! Smart! Good call!
Spuds (12-04-2018)
