Old 11-29-2018, 10:28 PM   #1
stlgrym3
How to use ecutek ProECU to read engine code?
Got a CEL today, car drives fine, how do I get the code via ProECU? Does the code automatically pops up when I connect the ecutek cable and identify the car? Further more, can ProECU clear the error code?
stlgrym3 is offline   Reply With Quote
Old 11-29-2018, 11:14 PM   #2
Do you have the manual that came with that instrument?
Old 11-30-2018, 01:20 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's really simple, a quick look at ProECU and you'd have found it.....
Either detect the ECU as if going to flash it or select manually:
The bottom option in red will give you any DTCs. The upper options are for if you know which ECU is throwing a code.
.: Stealth 86 :.
Kodename 47 DJ:
stlgrym3 (11-30-2018)
Old 11-30-2018, 01:40 PM   #4
stlgrym3
thank you, exactly what i was looking for
Old 11-30-2018, 02:57 PM   #5
tomm.brz
Drives: brz 2017 hksv2
What is the reason that often ProEcu doesn t read all the eventual codes that are present or stored, while Techstream (sometimes even Torque) reads them everytime?
I even had a car at one moment pulling p0302 , with the CEL on, Torque could detect the code, while ProEcu read was empty
Old 11-30-2018, 05:56 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
No idea. Worked a every time for me, but only checked a couple of times. Just let the team know if it doesn't work.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-01-2018, 01:32 PM   #7
stlgrym3
Update on this, my friend who I left my car with to install wheels and tires took liberty of clearing my code, and his device did not have the ability to see exactly which code it was. Right now it’s showing zero engine codes. The car drives normal.
Old 12-02-2018, 01:27 AM   #8
tomm.brz
As I said before, ecutek has serious problems about reading codes, like to the point it isnt trusty anymore.. I saw this at least 7 times in the last 2 months
check codes with torque or even better techstream
Old 12-02-2018, 07:41 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-02-2018, 12:02 PM   #10
stlgrym3
Now the error code was cleared manually, will it come back if the same issue still exists? Or is it now been suppressed to throw the same CEL again?
Old 12-02-2018, 12:21 PM   #11
steve99
Drives: FT86
only cleares latched alarms, if it occurs again it will trip CEL.
Only way to stop is to disable code in tune and reflash
Old 12-02-2018, 02:54 PM   #12
stlgrym3
I don’t mind see it again if it was a legit code, because it was cleared by my wheel installer which noting down the error code.
Oft tunes through proecu ecutek Dillydallen Software Tuning 1 03-13-2017 07:45 AM
Ecutek ProECU w/ License BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 3 06-06-2016 10:10 AM
Ecutek ProECU w/ License BRZ_HaVoKx Miscellaneous 0 05-25-2016 09:22 PM
FS: EcuTek ProEcu cable and key Celica00 Engine, Exhaust, Bolt-Ons 2 03-31-2014 04:00 PM
EcuTek ProECU twinturba Engine, Exhaust, Bolt-Ons 8 11-19-2012 07:28 PM
