Old 11-29-2018, 11:59 PM   #1
Peanrocks
Heat is hot on driver side and cold on passenger.
I’m at a loss. When running my heater it is hot as ever on the drivers side vents but on passenger side it is Luke warm at best. It doesn’t happen with the AC. Coolant is full. I’ve checked the actuator and it seems to be fine. It doesn’t have the dual climate control. Any ideas on what to check next? 2013 Fr-s base.
Thanks
Peanrocks is offline   Reply With Quote
Old 11-30-2018, 12:15 AM   #2
Grady
Grady's Avatar
Sounds like you do have dual climate control.
Old 11-30-2018, 12:20 AM   #3
Thanks
Welcome to the forum, Peanrocks -
It's supposed to be the other way around, so as to keep your SO all toasty.
Is the air flow the same on both sides?
Are you talking about the floor vent or the dash vents or both?
Old 11-30-2018, 12:23 AM   #4
well, he does NOW ….. but, he just don't want it no more -
Old 11-30-2018, 12:55 AM   #5
Only difference between base model and dual climate controls are the knobs. The base model has a common control but the ducts are still separated. Something slipped or broke on the passenger side.
https://demos.starbase7.net/t3Portal...04PH8002X.html
Bonburner (11-30-2018), humfrz (11-30-2018)
Old 11-30-2018, 02:22 AM   #6
Peanrocks
Thank you, it’s work for me but passengers don’t like it lol. Air flow is the same and it is all vents.
Old 11-30-2018, 02:23 AM   #7
Peanrocks
Awesome thank you for that I will look into that
Old 11-30-2018, 03:14 AM   #8
It's going to be deep inside the unit itself. No easy way to get to it.
Old 11-30-2018, 01:55 PM   #9
Bubba says to poke up there with a coat hangar - is that not a good idea?
Warm air drivers side, cold air passenger... elitegunslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-12-2018 11:23 AM
heat on one side ice cold on the other? DarkCard Issues | Warranty | Recalls / TSB 4 02-15-2015 04:22 PM
Selling Buddy Club Side Mount Seat Rails (Driver and Passenger) kseipel Interior Parts (Incl. Lighting) 0 07-02-2014 03:34 PM
wtb brz driver and passenger side sun visors nerdgsr Want-To-Buy Requests 3 04-29-2014 05:28 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 01:32 AM
