Old 09-25-2018, 05:27 AM   #141
Jaes86
Drives: 2017 Toyota 86
Trying to fit Spec-D headlights onto my 2017 GT86 but the pins are very different. Any way you can show me a diagram that's friendly to someone who's just starting out on learning to do DIY their own car? Tia.
Jaes86 is offline   Reply With Quote
Old 09-27-2018, 09:21 PM   #142
Premium 615
Premium 615's Avatar
Drives: '15 BRZ Limited
I'm contemplating a fog light retrofit. Anyone know off hand if a Morimoto Matchbox projector will fit in a 2015 BRZ fog light housing?
https://www.theretrofitsource.com/bi...box-2-562.html
2015 Subaru BRZ Limited AT6
Premium 615 is offline   Reply With Quote
Old 09-27-2018, 09:22 PM   #143
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
You deff could make this work. it will likely need a bolt/nut retrofit style. It is not deep enough for just using the supplied mounting nut.
There is also plenty of room behind the foglight.
-B
HeresMyMind is offline   Reply With Quote
Old 11-01-2018, 10:20 PM   #144
Mphillips
Drives: 15 FRS, 15 GTI, 88 928, 92 Skyline
I installed the Spyder Foglights this last weekend and the relay wasn't sending power to the interior switch. I replaced it thinking it was bad tonight and the same issue! Do you have any suggestions as to what could be causing this? Thank you in advance!
Mphillips is offline   Reply With Quote
Old 11-01-2018, 11:16 PM   #145
Balf
Drives: 2013 WRB BRZ Limited 6MT
Hey HeresMyMind, I've done an STI-R lense swap coupled with some of morimoto's xengreen bulbs a few years ago. I like the output but i never could get the cutoff just right. I think the driver's side is solid, but the passenger side is a bit frowny and I couldn't really get it right. Do you have any tips for getting the cutoff right and optimizing the setup? I don't mind pulling the lights apart again as long as I can get it right. Your pictures look really good.
Thanks,
Balf
Balf is offline   Reply With Quote
Old 11-20-2018, 12:37 AM   #146
RainEG
MTXclusive
I also wanna know how to wire them onto a 2017+ 86 if anyone is kind enough to help that’d be greatly appreciated. Thank you!
RainEG is offline   Reply With Quote
Old 11-26-2018, 02:46 PM   #147
HeresMyMind
It won't fit without decent modification,. Morimoto makes a LED replacement that is decent. but if you want the Bee's Knees, grab a Baja Designs Squadron Pro or Sport setup like mine. Way brighter than anything else on the market and they include brackets that fit.
-B
Old 12-08-2018, 03:50 AM   #148
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
Anyone replace their stock foglight bulbs in a 2018/2019 BRZ limited? What brand and bulb type did you go with?
HID?
LED? ie: auxbeam?
mikeg7827 is offline   Reply With Quote
Old 12-10-2018, 11:38 PM   #149
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Originally Posted by HeresMyMind View Post
If you have an FRS, you can purchase RX350 bixenon projectors, or RX350 non-afs projectors which are HID projectors and they will be a direct swap in the headlight once you open it up, using the pre-existing philips screws.
-B
Can you elaborate on this?
So if I go buy a RX350's bixenon projectors from toyota, they slide right into the fr-s's H11 sockets? And the electric connection fits and everything?
edit - also, if I'm interested in the Morimoto HID kit, should the '13 fr-s be H11A or H11B?
Edit 2 - nevermind, it looks like H11B. Feel free to confirm.
My other question is can you run H1 HID's DRL and High beams? Or will I lose the DRL functionality?
https://www.theretrofitsource.com/h1...ect_restrict=1
Old 12-11-2018, 11:07 AM   #150
HeresMyMind
I mispoke, you need to purchase a used set of RX330 Non-AFS projectors off ebay and make sure they are the xenon / D2S bulb projectors. they bolt directly into the OEM FRS housings, but they are LOW beam only. They are a 2.5" lens. The RX350 BIXENON ones you mentioned are a 3" lens and will not bolt directly in without modification.
Ontop of the projectors install, you will need to purchase D2S Hid Bulbs, and D2S ballast and adapters to plug the ballast into your OEM low beam wiring.
-B
The Following User Says Thank You to HeresMyMind For This Useful Post:
Bonburner (12-11-2018)
Old 12-11-2018, 02:00 PM   #151
Circa85
HID?
LED? ie: auxbeam?
The 2017+ BRZ limited foglights (in the US) are already LED and don't have replaceable bulbs
Circa85 is offline   Reply With Quote
Old 12-13-2018, 02:43 PM   #152
HeresMyMind
this is a very simple 100% complete kit you can use that I highly recommend.
https://www.theretrofitsource.com/mo...cion-gt86.html
-B
The Following 2 Users Say Thank You to HeresMyMind For This Useful Post:
Bonburner (12-13-2018), DAEMANO (01-08-2020)
Old 01-26-2019, 02:30 PM   #153
DriveDriftDogfight86
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
I have a question, so I have an FRS and I recently put on a 2013 BRZ bumper. How do I get the BRZ LED strip DRL's and foglights to wire up? My FRS has optional DRL strip LED's, but they don't seem to match up with to the harness that the BRZ uses. Any help or part names/numbers would be appreciated. Thanks
DriveDriftDogfight86 is offline   Reply With Quote
Old 01-26-2019, 04:33 PM   #154
HeresMyMind
There should be one fog light wires from your FRS car harness.
The running lights will have to be connected to the oem headlight running light widespread. You’ll probably have to use universal connectors or solder them.
-B
DriveDriftDogfight86 (01-28-2019)
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 04:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 09:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 02:19 AM
