Old 11-25-2018, 04:14 PM   #1
imped4now
Drives: '17 BRZ PP - '17 FoRS
2017 BRZ Mud Guard Compatibility
Hey guys, I'm guessing these will also work with the BRZ, but I want to ensure there are no small differences that will create an installation issue:
These are the Toyota OEM 2017+ 86 guards:
http://www.ft86speedfactory.com/toyo...l#.W_sQZuhKhPY
imped4now is offline   Reply With Quote
Old 11-25-2018, 05:09 PM   #2
Brink
Drives: 2017 BRZ
There have been a couple mentions on here of the 86 having some small differences in mounting points, though the discussion was usually centering on aftermarket mud flaps rather than those OEM parts so I don't know if it will affect your install.
http://www.ft86club.com/forums/showp...5&postcount=24
http://www.ft86club.com/forums/showp...34&postcount=4
Brink is offline   Reply With Quote
Old 11-26-2018, 12:47 AM   #3
gpvecchi
gpvecchi's Avatar
2017 86 has different rear bumper from other models.
You need -2017 mud flaps for all other bumpers.
Old 11-26-2018, 10:06 AM   #4
imped4now
Does anyone have a link to suitable guards for a 2017+ BRZ? My search is failing me.
Old 11-26-2018, 10:44 AM   #5
Racecomp Engineering
These are the earlier version that fit 2013-2016 BRZ. I can't tell you for sure if they fit the 2017 BRZ but if you post a picture of the mounting area we could probably figure it out. Or call FT86 SF.
https://www.ft86speedfactory.com/toy...l#.W_wQUJNKhaQ
- Andrew
Old 11-26-2018, 04:44 PM   #6
gpvecchi
gpvecchi's Avatar
All BRZs use same bumper.
Old 11-27-2018, 10:05 AM   #7
reebis
reebis's Avatar
Drives: 2020 STI Limited
These are the ones that will fit a 17+ BRZ.
https://www.amazon.com/dp/B0083LH5F6...v_ov_lig_dp_it
reebis is offline   Reply With Quote
Old 11-27-2018, 11:28 AM   #8
The rear shape of the bumpers changed a little but the wheel well areas are still the same. Anything that fit before still will. The only monkey wrench is if you have skirts but then nothing fits any year anyway.
Old 11-27-2018, 11:53 AM   #9
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I have the 2013-2016 mud guards on my 2017 BRZ and they fit perfect.
DaBoBo21 is offline   Reply With Quote
Old 11-27-2018, 12:51 PM   #10
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
I do as well. I think the 2017+ 86 is different but the BRZ can still use the old 13-16 Scion ones, linked on Amazon above.
Horrid_Funk is offline   Reply With Quote
Old 11-27-2018, 01:15 PM   #11
I repeat.
Wheel wells did not change on any of the cars.
The changes to the bumper shape are above where the mud flaps attach.
DaBoBo21 (11-27-2018)
Old 11-27-2018, 02:25 PM   #12
Horrid_Funk
I repeat.
From a review on FT86SF:
"Be aware installation requires drilling holes, and the 2017 86 actually required more holes drilled than the older models."
I don't know if this guy is right or not but it seems like it's possibly not exactly the same, especially since FT86SF carries the two different SKUs for 13-16 and 17+. From the pictures they look practically the same, though it could just be because they switched from Scion to Toyota.
I'm just saying that for certain I know the old Scion ones fit the 17+ BRZ. The 13-16 ones are cheaper anyways so just go with those.
The Following User Says Thank You to Horrid_Funk For This Useful Post:
Tcoat (11-27-2018)
Official 2017 MY CHANGES (Full Document) and Backwards Compatibility Discussion Stang70Fastback BRZ First-Gen (2012+) — General Topics 301 06-08-2018 02:07 AM
2017 BRZ iDatalink ADS-RR Headunit Install Compatibility dman22 Electronics | Audio | NAV | Infotainment 7 03-13-2018 07:04 PM
TPMS Compatibility MrDinkleman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 01-24-2017 10:52 PM
Compatibility question fr-S-14 Forced Induction 4 06-01-2015 11:15 PM
Sizing compatibility? mikkeluo Engine, Exhaust, Transmission 1 05-10-2015 08:12 PM
