Old 11-25-2018, 01:02 PM   #1
dlb9000
Drives: 2017 BRZ
Enable TPMS on non-US BRZ
I've got a 2017 BRZ, and here in Canada TPMS is not mandatory so it's not a feature on my car. I know there are aftermarket systems, but given it's included on the US models I'm wondering if there's any way to enable it on the Canadian model (assuming I purchase and install the sensors). Has anyone done this, and if so how?
Sent from my SM-G930W8 using Tapatalk
dlb9000 is offline   Reply With Quote
Old 11-25-2018, 02:36 PM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
You'd probably just need a TPMS programmer in order to get it done. The FR-S in Canada had TPMS. I bet the only thing missing from the BRZ are the sensors for the wheels.
Trueweltall is offline   Reply With Quote
Old 11-26-2018, 01:41 PM   #3
funwheeldrive
On the flipside, is there any way to disable TPMS on American cars?
Old 11-26-2018, 04:25 PM   #4
kch
Senior Misanthrope
kch's Avatar
Beastronix's 86 nanny. Although I remember reading he's either stopped production or is on hiatus.
The Following User Says Thank You to kch For This Useful Post:
funwheeldrive (11-26-2018)
Old 11-30-2018, 09:58 PM   #5
dlb9000
Drives: 2017 BRZ
Thanks, #Trueweltall. I had my other car in for service at Toyota today so I stopped by the parts desk to ask about the TPMS. His opinion was that the BRZ wouldn't have the receiver module installed. Wonder if anyone out there could confirm.
Old 12-01-2018, 02:57 AM   #6
Trueweltall
The BRZ does have it installed, the door control and the TPMS are one receiver located on the back shelf. The service wiring diagram confirms this as being a dual function unit on page 252. http://www.ft86club.com/files/BRZwiringi.pdf
I think there is also one in the front behind the radio. Check out page 42 in the same PDF, A30/A64.
Old 12-01-2018, 03:28 AM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Though a pressure stick would be far cheaper.
If you walk around and look at the tires, sometimes (not always) you can see a sub pressure situation before it becomes acute.
Then you fill it up with air until it gets round again.
I know it's daft! It's traditional though.
Old 12-01-2018, 06:43 AM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
TPMS is a safety feature. It only indicates pressure is low when it is a safety concern. It does not help with maintaining the optimal pressure for performance and/or efficiency. It does not show actual pressure and specific tire.
I would add something like this.
Old 12-03-2018, 02:26 PM   #9
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
The Subaru scan tool at my local shop can pull both the individual pressures and temps at each wheel through the OBDII port. It would be nice to have on display.
B T is offline   Reply With Quote
re-enable cold start on OTS stage 2 plus Laz84 Software Tuning 21 08-16-2020 06:04 PM
Rear Foglight Enable Tye300 DIY (Do-It-Yourself) Guides 73 05-09-2017 02:37 PM
Enable DRL?? peachch ASIA 6 08-09-2015 05:30 PM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 09:11 AM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
