Old 11-19-2018, 11:47 PM   #1
Mttogo
Drives: Toyota GT 86 2013
Stock Gt 16" Rim on wider tires?
Hey, im new here so sorry if i come across as a forum noob. Im just wondering whats the maximum width of tire could you get on the stock rims?
People might just say get new wheels but i have rota grids and theyre simply too heavy i believe, these stock enkei rims are fairly light, much lighter than my rotas so hoping these stock wheels can take some meaty tires!
Thanks in advance
-Mttogo
Mttogo is offline   Reply With Quote
Old 11-20-2018, 03:11 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
16x6.5 +48 wheels. I wouldn't go bigger than a 225/50/16.
I LIKE TIRES!
Old 11-20-2018, 04:22 PM   #3
Mttogo
225 would be perfect! Thanks for that
The Following User Says Thank You to Mttogo For This Useful Post:
Leonardo (11-20-2018)
Old 11-20-2018, 05:43 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
FYI, if you don't like how sunk in your wheels are, you could run bolt-on spacers to flush things up. 25mm would be the where I'd start. This sounds aggressive, but the wheel will have the same "poke" as a 16x7.5 +35. Which is not very aggressive.
like these.
http://www.ft86club.com/forums/showthread.php?t=36471
I LIKE TIRES!
rims, tires
Wider tires on stock wheels buzznasa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 01-21-2019 01:55 PM
Practicality of wider tires mike_ekim1024 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 01-11-2019 01:51 PM
what is needed to run tires wider than 275? AdrianSaldana Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-13-2016 11:13 AM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 02:49 PM
Camber or wider tires? Khyron686 Tracking / Autocross / HPDE / Drifting 8 05-27-2014 09:27 PM
