Old 11-19-2018, 07:41 AM   #15
snk828
snk828's Avatar
Drives: raven FRS
Originally Posted by Scir16v View Post
On a side note, if you have ever had to have the engine replaced, your car now does not qualify for the recall if a used engine is in the bay. They consider a car as a whole, as one unit. If any parts of those have been removed and replaced with something from another car(i.e. used replacement engine from a place like LKQ), it is not a complete unit anymore.
I contacted Toyota customer service and spoke with a Scion rep there. I called because I have a replacement engine that I had gotten for another FRS that has 65,xxx miles on it, and since it was built in the time frame, I wanted to see if it would qualify.
I was told that if the engine had been replaced, it would not qualify for the recall
What if the dealer replaced the short block because rod bearing issue ? I have a brand new short block installed by dealer under warranty few months ago.
snk828 is offline   Reply With Quote
Old 11-19-2018, 08:54 AM   #16
Talk to them but most likely you would already have the later springs. All depends on when the short block was made though.
Old 11-19-2018, 12:34 PM   #17
Scir16v
Drives: 240sx, 2013 frs
And potentially they will not have sourced the engine from a used source. If it is new, then they also have a history of work performed
Scir16v is offline   Reply With Quote
Old 11-19-2018, 07:55 PM   #18
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
A "short block" is crankcase without heads.
A "long block" is crankcase and heads.
So no, a short block would not have a fresh set of springs, even if the heads were taken apart for the rebuild process, it's original springs should have been reinstalled if there was no notice to do otherwise at the time.
The Following 5 Users Say Thank You to RZNT4R For This Useful Post:
Gunman (11-21-2018), humfrz (11-19-2018), Rampage (11-19-2018), snk828 (11-24-2018), Summerwolf (11-21-2018)
Old 11-19-2018, 08:02 PM   #19
Yes.
Apparently I had a mind fart moment.
Old 11-19-2018, 08:58 PM   #20
gravitylover
Yes.
It's ok, you're old
The Following User Says Thank You to gravitylover For This Useful Post:
humfrz (11-19-2018)
Old 11-19-2018, 09:33 PM   #21
Originally Posted by gravitylover View Post
It's ok, you're old
Yep, it all starts with brain farts and then degenerates into .. into .. oh, never mind ..
gravitylover (11-20-2018)
Old 11-19-2018, 09:37 PM   #22
brain diarrhea
humfrz (11-20-2018)
Old 11-20-2018, 12:20 PM   #23
brain diarrhea
Like said in the movie "never trust a brain fart" (or something like that).
Ultramaroon (11-20-2018)
Old 11-20-2018, 04:05 PM   #24
godzuki
godzuki's Avatar
Drives: frs
Originally Posted by fitcious View Post
Hey, should we use this thread for everyone who completed the valve spring recall to post which dealership they went to, experience, and whether it was done correctly? this can help those who have a hard time deciding which dealer to go to. Just a thought! Thanks
Need to get vacuum pump & valve cover gasket replaced, 120k service (spark plugs, etc) done... should be cheaper to wait till there's a fix for the recall and get it all done at once right? :P
godzuki is offline   Reply With Quote
Old 11-21-2018, 10:20 AM   #25
gravitylover
That's what I'm hoping. I know it's time to change the plugs and I'm hoping they only charge for parts and a minimal labor charge rather than the regular $300.
Old 11-21-2018, 02:55 PM   #26
Gunman
Drives: 2019 Mazda Miata RF
When the piston let go in my v6 Ranger, I got a mid-block...crankcase and one head.
Old 01-15-2019, 10:23 AM   #27
Tvars
Tvars's Avatar
Drives: Firestorm
I am having my spark plugs changed. Rockingham Toyota is charging me a .5hr of work. plus the OEM spark plugs,
Tvars is offline   Reply With Quote
Old 01-15-2019, 10:50 AM   #28
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
A half hour of work while they're doing the recall? They take the plugs out anyway, there's no way there should be any more labor to put in different plugs than what they took out
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 10:55 PM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 03:12 PM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
