Old 11-15-2018, 10:52 AM   #1
solidsnake11
Drives: brz
Oil system mods for more pressure and flow.
This thread has been censored
solidsnake11 is offline   Reply With Quote
The Following 14 Users Say Thank You to solidsnake11 For This Useful Post:
-Phil (11-24-2018), AKITA (05-30-2020), B T (11-26-2018), ballsdeep (11-15-2018), BatStig (02-11-2019), Boris_Petrov (08-28-2019), Calum (12-01-2018), gtengr (11-15-2018), jeepmor (05-10-2022), lamawithonel (11-26-2018), makinen (12-02-2018), scion fr-s (11-25-2018), Tristor (04-29-2019), UYCR (11-24-2019)
Old 11-15-2018, 11:45 AM   #2
gtengr
Drives: 2017 BRZ
Lots of good info. Welcome to the forum!
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
Calum (12-01-2018)
Old 11-15-2018, 07:54 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
Good info. I have often wondered if the oil feed to the heads should be restricted in favour of the crank and rods but you clearly have gone well beyond that
Killer B Motorsport does a replacement oil pick up. The filter is in the same place as the OEM unit however, but it might be worth a look.
http://www.killerbmotorsport.net/oil...il-pickup.html
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Calum (12-01-2018)
Old 11-15-2018, 09:36 PM   #4
WOW! You put a bunch of thought and machining into that project!
Good presentation and pictures!
Old 11-15-2018, 09:49 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
@solidsnake11 have you thought about using the Reimax hi volume oil pump? Or do you expect with your mods it will be unnecessary?
1974 TA22 Celica
2013 86 GT
Calum (12-01-2018)
Old 11-15-2018, 11:13 PM   #6
Trust86
Drives: 2016 Halo FRS
Now you got me worried about my oil feed for turbo :/
Trust86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trust86 For This Useful Post:
Boris_Petrov (08-28-2019), Calum (12-01-2018), DarkPira7e (11-15-2018)
Old 11-16-2018, 08:08 AM   #7
CoolHandMoss
Drives: 2013 FRS
Have you run the engine since making these changes? Most of these seem like good solid ideas to me but I am curious if there are any unforeseen effects of changes like these.
CoolHandMoss is offline   Reply With Quote
The Following 2 Users Say Thank You to CoolHandMoss For This Useful Post:
Old 11-17-2018, 03:16 PM   #8
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by solidsnake11 View Post
I am in the process of rebuilding the engine so no I have not ran it. I bought the car with a bad engine. The only mod that I'm not real sure about is shimming the oil pressure spring. If it blows the oil filter apart, I used to many washers in it. Had a VW that would do it, if it was reved cold.
Purolator Boss (#PBL14461) can withstand over 500psi before bursting. It has a thicker case than regulator oil filters.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Calum (12-01-2018)
Old 11-17-2018, 04:04 PM   #9
Do you have any images of the cavitation marks?
Calum (12-01-2018)
Old 11-18-2018, 05:14 PM   #10
Unfortunately I sealed the pump up before I took any.
Was it in the vicinity of either of the two areas circled? Which one?
Old 11-21-2018, 08:18 AM   #11
CoolHandMoss
Drives: 2013 FRS
I've seen reports of as high as 80psi when cold even with 0w-20 on these engines. I was apprehensive about your use of washers too knowing this. I can't imagine really wanting more. The pressure bypass does not seem to be a problem on this engine. Especially if you use heavier oil your pressure may be excessive on cold starts. What made you want to try the washers to begin with?
The Following User Says Thank You to CoolHandMoss For This Useful Post:
Calum (12-01-2018)
Old 11-21-2018, 12:59 PM   #12
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
My oil pressure gauge reads 80-90psi cold at idle with 0W-20 in it. After a session on track, that may only be 30 psi at idle when the oil temp is in the 210-220 F range.
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
Calum (12-01-2018)
Old 11-22-2018, 07:58 AM   #13
CoolHandMoss
Drives: 2013 FRS
Right. So is 80-90 not enough pressure for a cold start? Shimming the bypass stiffer will only increase the maximum pressure the pump will produce. It won't effect hot pressure whether it's shimmed or not.
Calum (12-01-2018)
Old 11-22-2018, 04:26 PM   #14
Icecreamtruk
Drives: Track preped NA FRS
http://www.ft86club.com/forums/showthread.php?t=63723
Seems this guy was having problem with oil pressure. He fixed it but never said how. I was just showing what I did, it may work or it may not. Did he shim the spring? Did he drill the block? Did he open up the port around the tempature sensor? Did he open up the pick up tube, straighten the entrance to the oil pump? I don't know but he fixed it. He had so much of a problem that he put an accumulator on it, who wants to have that to fool with on a dd? Not me.
Didnt they end up using a dry sump? Im pretty sure it was not an oil accumulator but an actual dry sump setup.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Calum (12-01-2018)
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 04:57 AM
No a/c but system has pressure ZionsWrath Other Vehicles & General Automotive Discussions 8 06-14-2015 03:43 PM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 01:54 PM
SRT FR-S/BRZ High Flow Intake System R&D Swift Racing Technologies Engine, Exhaust, Transmission 160 03-03-2013 01:41 AM
