| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Frs
20mm H&R spacer + Volk te37
Hi
I refurbished an older set of te37 7.5x17 +48 recess area between holes 2-3 mm. Looking to add a set of bolt on 20mm H&R spacers. Will the stock studs hit the back of the rim? Thanks |
#2 | |
Country Boy 4 Life
look at post# 25 And this is on stock suspension. this is a 17x9 +42 http://www.ft86club.com/forums/showt...t=56878&page=2 My front wheel pokes out an additional 12mm compared to this. And I was able to tuck the top of my tire with only a set of camber bolts set at -1.4 camber. (not even maxed)
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | edo475 (11-14-2018) |
| A +42 offset wheel and a 20mm spacer... | Crusard | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-24-2018 02:31 PM |
| FS: Pairs, Volk te37 18x10.5 +22 and Volk te37 18x10.5 +24 | jay92 | Wheels and Tires | 2 | 08-19-2016 03:30 AM |
| FS: H&R DRM 20mm Spacer 5x100 | Firestorm_86 | Wheels and Tires | 3 | 10-22-2014 06:34 PM |
| FS: H&R DRM 20mm Spacer 5x100 | Firestorm_86 | Wheels and Tires | 4 | 10-08-2014 05:23 PM |
| help with the 20mm spacer nuts | Vten | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 12-01-2013 01:35 AM |
