Old 11-08-2018, 02:58 PM   #1
CA2
Dusty Raven
Drives: FR-S MT
P2419 CEL code - what to do?
Hi everyone,
I have a first year FRS with about 90k miles on it. A short while ago, I had the CEL come on (along with the traction control light) when I hit a bumpy part of road. Torque found one code - P2419 - Powertrain. Evaporative Emission System Switching Valve Control Circuit Low.
I reset it, it stayed off for a few weeks, but came on again (I drive dirt roads and some of the paved ones are terrible, and this seems to happen more when I am on bumpy surfaces, but I might be making that up).
Anyway, I reset but now it is coming back on every 2-3 days. So maybe there really is a problem...
Car seems to drive fine, don't notice any difference. The traction control light comes on and off as I drive around, CEL stays on.
Any ideas? I'm hoping it's just a loose wiring harness somewhere, but I don't know where to look - don't know where the EVAP system pump/sensor/valves are located. I'm out of warranty so I'd like to take a crack at it myself if reasonably possible.
Thanks!
CA2 is offline   Reply With Quote
Old 11-09-2018, 02:36 AM   #2
You may find this reference helpful:
https://demos.starbase7.net/t3Portal..._rm_index.html
I hope you get it sorted out.
CA2 (11-09-2018)
Old 11-09-2018, 04:29 AM   #3
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
the VSV is under the intake manifold
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
The Following User Says Thank You to 1GiantTurtle For This Useful Post:
CA2 (11-09-2018)
Old 11-09-2018, 05:59 PM   #4
CA2
Dusty Raven
Drives: FR-S MT
Wow, thanks - this is great.
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 09:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 02:27 AM
