#1793 | |
Drives: BRZ 2018
It is normal such knock correction with 95RON, try using octane booster or lower advance timing, even with our medium quality 100RON I have some flkc. Tor's AVCS maps for Gruppe-S headers, posted in his thread, improved overall my car while knock behavior is reduced not increased from the extra degrees VVT! Better follow tomm.brz suggestion or contact a friendly tuner of the forum that can help your with the tuning procedure for a small donation! |
#1794 |
Drives: Turbo FRS
Hey, I am 100% unqualified to read logs. I just swapped in a new to me lightly built engine after I spun a bearing in my old one (Oil mishap). I'm using FBM's Turbo (Garret T57), 550cc injectors. The block is forged, running upgraded springs and valves, but same compression. I am running the same tune from my old engine, and I just want to make sure everything is running fine. I sent the logs to my tuner, but he is pretty busy lately. Anyone care to take a look and tell me what they think? In the zip below there are two 2nd gear pulls. EDIT: https://datazap.me/u/kerber23/log-15...7?log=0&data=7
#1795 | |
Drives: FT86
mate grab you log and post it up to www.datazap.me will create nice graph. post the link here and we can have a look |
#1796 | |
Drives: Turbo FRS
Sorry about that! |
#1797 | |
Drives: FT86
highest boost is 0.6 bar or about 9 psi but your only at about 40% throttle You are starting to get a little knock about -1 but your not pushing it hard, assume your on petrol 91/93 ? that knock will likely get worse as you go full throttle so keep and eye on that (ignition correction fine) and the Advance multiplier it should be 1 with minimal knock. AFR on petrol should be round low 12 or high 11 at full throttle on petrol |
#1798 | |
Drives: Turbo FRS
#1799 | |
Drives: 2017 Toyota 86
#1800 | |
Drives: FT86
If your tuned for 91 then you can use 93 as it better fuel but dont use 91 in a car tuned for 93 especially boosted cars |
#1801 |
Drives: 2022 GR86
@steve99 Could you take a look at my log from the tail of the dragon run I went on. im on 93 Oct Uel header and N1 Catback
https://datazap.me/u/bentleyboii/tai...g=0&data=1-4-6 Last edited by bentleyboii; 11-10-2018 at 09:09 PM. |
#1802 | |
Drives: FT86
looks fine iam dropped once to 0.88 looks like you got hard on throttle at 2000 rpm but it went straight back to 1, rest of flkc corrections less than -1 so thats fine . |
#1803 |
Drives: 2022 GR86
Yeah it was a semi difficult road in my opinion Was probably after a downshift then wot on a straight. also mild quality gas and high elevation im assuming all played a part? Thanks!
#1804 |
WRBLUE BRZ
Drives: 2016 Subaru BRZ
I have -1.3 flkc in mid-rage about 5k-6k, 0.5-0.7 load with low-half throttle (spirit driving). Should I pull some timing in this area or is it ok to leave it like this ?
I'm running e85 but not good quality compare to US e85 https://datazap.me/u/shirokuma/stg2-...zoom=5235-5472 |
#1805 |
Drives: '22 GR86
Getting positive FLKC which seems kinda odd. IAM starts at .7 (OFT sets value to this if I remember right) and slowly goes up over 2 pulls.
Open Flash Tablet Stage 1, 91 octane. Car is stock engine wise other than a drop in filter. https://datazap.me/u/staples323/2015...0&data=1-12-14 https://datazap.me/u/staples323/2015...0&data=1-12-14
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD |
#1806 |
Drives: UK GT86
It's normal
.: Stealth 86 :.
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
