Old 11-08-2018, 08:19 PM   #1
Tripp1117
Drives: Whiteout Scion FR-S
To Stroke or not to Stroke? (Luckily I work as a machinist @ a machine shop)
Hello all,
It's been a long while since I've been on here and I'm marking my return with a bang.
Unfortunately I spun a main bearing in my BONE STOCK first gen (early 2013) FRS. Luckily I got over 120k miles out of my engine before I suffered from what many others have. I
So now I'm at a crossroads for decision making on what route to take to get back on the road. Luckily I'm a machinist by trade and specifically an automotive machinist, so I have access to anything and everything I need to rebuild and for cheap.
Question is should I go with one of the 2.1 stroker kits, just keep stock crank and change over to forged rods and pistons or just rebuild with regular internals?
I plan to go FI by way of Edelbrocks Supercharger by next summer but I would like to keep my rebuild costs as low as possible. Seeing as I can do all the engine work myself it will be easy to do this cheaply and parts are my ONLY cost.
How good is our stock crank for instance? I've considered just replacing rods and pistons but the notion that I'll be pushing a 2.1 is almost too good to pass up. 2/3 of the cost of the kit is from the crank though.
Any advice from others that have gone this route is much appreciated as well as other advice opinions etc
Tripp1117 is offline   Reply With Quote
Old 11-08-2018, 09:08 PM   #2
Tripp1117
The more I think about it in the more research I do, $3,600 Stroker is probably overkill for what I plan on doing since I only want to supercharge it and max hit 350 horsepower.
I'm thinking that I would be able to get away with just changing to forged pistons and forged rods and foregoing a stroker kit.
To me it just seems like a lot of money to add a tenth of a liter. Can anyone tell me what horsepower games are made from going with a 2.1 stroker kit?
Sent from my SM-N960U using Tapatalk
Old 11-08-2018, 09:38 PM   #3
alphasaur
friendly
Drives: 17' 86
a 10th of a liter for $3600
I think you answered you're own question.
alphasaur is offline   Reply With Quote
Old 11-08-2018, 09:39 PM   #4
Tripp1117
Yeah I was only considering it because of all the other money I'm able to save doing all the work on my own
Old 11-08-2018, 09:43 PM   #5
Tripp1117
If it's so cost inefficient, why are there so many aftermarket of to go 2.1?
Old 11-08-2018, 09:52 PM   #6
alphasaur
friendly
Drives: 17' 86
If you're going forced induction I don't really think it's worth the cost to add such a small amount of displacement. I haven't seen dynos, but what are you going to get? 10-20hp? Just add more boost.
Old 11-08-2018, 09:56 PM   #7
Tripp1117
Yeah I plan to go forced induction around summer of next year I just wanted to build an extra hopped-up motor because I have the capability to at my work and basically do it for free besides parts cost.
I also recently thought that I could get the kid a little bit cheaper but that crankshaft is $$$$
I know this may be a dumb newb question but is the stock crank forged?
Old 11-08-2018, 09:57 PM   #8
Tripp1117
I also wanted to run a pretty stout naturally aspirated engine so it was just a consideration
Old 11-08-2018, 10:01 PM   #9
alphasaur
friendly
Drives: 17' 86
No idea, new to this platform. If going NA and trying to extract as much power NA as you'd like stroking is probably the way to go. If going FI seems like a waste of money You do have the resources available to make it way easier but on the same token you're still going to be using those resources to rebuild anyway
Old 11-08-2018, 10:19 PM   #10
86TOYO2k17
Drives: 2017 toyota 86
How come not doing a forged 2.3L stroker kit? Rods pistons bearing crank for about 5,500? You know the saying. No replacement for displacement.
A 2.0L making 200hp 300hp on 8psi
2.3L should be 230hp and 345hp on 8psi.
Plus the added safety of forged internals. While your in there might as well do valves springs and cams to really bring out the potential.
Doesn’t seem cost ineffective if labor is free imo.
Most people just do engine swaps before going this route. But most people can’t do the internal work themselves either. So a swap is easier/ more cost effective. Would be cool to see someone go this route and how it works out.
Old 11-08-2018, 10:32 PM   #11
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Originally Posted by 86TOYO2k17 View Post
How come not doing a forged 2.3L stroker kit? Rods pistons bearing crank for about 2,000? You know the saying. No replacement for displacement.
It's not that linear, especially with boost.
You'll have a bigger pressure drop to suck in air (which your SC doesn't give a crap about), but you'll still have the same intake/head restrictions.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 11-09-2018, 07:46 AM   #12
Tripp1117
Haven't come across the 2.3 kit. If it truly is 2k then I will definitely be going that route. I'm still in the research and selection stages of the motor build.
Old 11-09-2018, 09:19 AM   #13
86TOYO2k17
sorry i lied, was looking at the wrong thing...
looks like the toda 2.3l stroker kit is about 5,500...
Old 11-09-2018, 12:33 PM   #14
ML
ML's Avatar
Drives: 13 White MT FR-S
yes, the stock crank is forged. Most don't replace it when building the motor.
2.1, forged, rebuild, stroker
New 2 stroke??? Leonardo Other Vehicles & General Automotive Discussions 0 11-06-2018 11:51 AM
FS: Moritmoto 2-Stroke LED Low Beam Headlights skylinekin Exterior Parts (Aero, Lighting, Etc.) 7 06-16-2017 09:23 AM
Morimoto 2-stroke DRL LED Shinigami301 Cosmetic Modification (Interior/Exterior/Lighting) 23 09-21-2016 12:59 PM
Stroke saving, room giving front camber plates please. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 01-31-2014 04:34 PM
Possible crickets fix? Adding a capfull of synthetic 2 stroke oil per tank full? mike the snake Issues | Warranty | Recalls / TSB 29 09-29-2013 04:29 PM
