Old 11-06-2018, 05:49 PM   #17277
Grady
Grady's Avatar
Don’t use screws.
Shitty install. There is double sided tape, they did not clean the area correct or at all prior to installation. I would get it fixed under warranty. If they can not get good quality tape they can replace the kit with new.
The Following 3 Users Say Thank You to Grady For This Useful Post:
Busybee (12-22-2018), Leonardo (11-06-2018), weederr33 (11-06-2018)
Old 11-06-2018, 05:57 PM   #17278
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Chikna View Post
Pictures attached.
This is what I would use in that location.
https://www.3m.com/3M/en_US/company-...3241071&rt=rud
I LIKE TIRES!
wolffbite (11-06-2018)
Old 11-06-2018, 06:53 PM   #17279
spike021
spike021's Avatar
You shouldn't have to drill at all for a BRZ's sideskirts. There are holes on the underside of the rocker panels with coated plugs that you pop out, and then the sideskirts have new hardware that pops in to hold the sideskirts on, plus the doublesided tape.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 11-07-2018, 01:35 PM   #17280
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Originally Posted by BA9092 View Post
Loving the new leather/perforated leather steering wheel from REAL Japan!
Thanks to 86WORX for carrying these - @Max @ 86WORX
Amazing quality, looks great, feels awesome!
Been a few months now. How is the wheel holding up? Any concerns or complaints?
wolffbite is offline   Reply With Quote
Old 11-08-2018, 01:25 PM   #17281
Chikna
Drives: 2018 BRZ TS 244/500
This morning I took tS to dealer and they were shocked to see how it was installed. Service Manager ordered a part, I don't know what part is and he will call me once the part is arrived. Awful.
Chikna is offline   Reply With Quote
Old 11-08-2018, 02:16 PM   #17282
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
Still looks and feels as good as new. No complaints or concerns.
I do like the shape of the ones for the '17 and '18 that are being sold through FT86SF better, but they're only available with carbon fiber and don't have an all-leather option...yet.
BA9092 is offline   Reply With Quote
The Following User Says Thank You to BA9092 For This Useful Post:
wolffbite (11-08-2018)
Old 11-08-2018, 02:18 PM   #17283
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
is there a way to get the controls on the wheel to work on the older models like a 14'?
Old 11-08-2018, 03:01 PM   #17284
wolffbite
Just the tip
wolffbite's Avatar
I think it's possible but pretty cost prohibitive.
A while back someone looked into this and it requires a new clockspring (MY2017+) as that has a different harness for the controls, and the old and new airbag are different sizes so you would need an entirely new steering wheel assembly to do this.
The Following 2 Users Say Thank You to wolffbite For This Useful Post:
BA9092 (11-08-2018), echo419 (11-09-2018)
Old 11-08-2018, 03:02 PM   #17285
BA9092
Captain Slow
BA9092's Avatar
You probably need to replace the clock spring in the column, since mine looked different than the pre-'17 version without the controls, along with whatever wiring and harness you need to run the radio controls.
But there's also buttons for the menu in the dash to the right of the speedo which would require the new dash as well for that to work.
Anyone tried this swap yet?
Old 11-09-2018, 06:32 AM   #17286
echo419
echo419's Avatar
F all that.
The Following User Says Thank You to echo419 For This Useful Post:
wolffbite (11-09-2018)
Old 11-09-2018, 03:45 PM   #17287
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Corsa installed!
Totally different sound from the UEL + V1 I had on my FR-S -- I've matured a bit since then.
[ame]https://www.youtube.com/watch?v=sl_kiPX58GU[/ame]
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
The Following 3 Users Say Thank You to dhuang For This Useful Post:
MJones_RB (11-09-2018), tehShirt (11-09-2018), weederr33 (11-10-2018)
Old 11-10-2018, 01:21 AM   #17288
Chikna
Good review
[ame="https://www.youtube.com/watch?v=B119ipAR-d0"]https://www.youtube.com/watch?v=B119ipAR-d0[/ame]
The Following User Says Thank You to Chikna For This Useful Post:
Old 11-10-2018, 01:27 AM   #17289
Vten
Drives: Too heavy
From summer set te37saga with a white brembo to a black fifteen52 winter set with banana 6pots ap racing 😇
Vten is offline   Reply With Quote
The Following User Says Thank You to Vten For This Useful Post:
yberther (11-10-2018)
Old 11-10-2018, 03:40 AM   #17290
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by dhuang View Post
Corsa installed!
Says the man driving a yellow car
The Following User Says Thank You to JD001 For This Useful Post:
dhuang (11-10-2018)
