Old 11-07-2018, 06:43 PM   #29
86prime
Drives: 18 BRZ tS
I like that square bumpstop idea. The round one doesn't last very long. Maybe some metal instead of rubber?
86prime is offline   Reply With Quote
The Following User Says Thank You to 86prime For This Useful Post:
reeves (11-09-2018)
Old 11-07-2018, 08:57 PM   #30
churchx
churchx's Avatar
Drives: 2014 GT86
Metal will clunk.
Old 11-08-2018, 03:15 PM   #31
86prime
Drives: 18 BRZ tS
Originally Posted by churchx View Post
Metal will clunk.
Oh well, what's another clunk. Kidding aside, the main point of this "mod" is to raise the stop point, not to provide cushioning. Well, maybe just replace the rubber every year, annoying as that is.
jcw99 (11-09-2018)
Old 11-08-2018, 03:32 PM   #32
churchx
churchx's Avatar
Drives: 2014 GT86
It's .. annoying clunk. These are no diesels, one has to use clutch frequently, when rowing through gears on MT. That's annoying clunk often.
BTW, i had this mod with similar round stopper. Relatively thin metal plate of pedal cut through this rubber bumper quickly. 2-3 weeks quickly. Currently i DIY made thinner but much wider (then even base, that stopper is attached to) stopper (made from round furniture anti-skid pad, that can be attached with screw). Longer contact area = will cut through less.
And main point of this mod is not so much as to rise clutch bite point, as reducing overly long dead travel till bite point, isn't it? It's simpler to do by adjusting pedal travel (and clutch sensor) imho.
Old 11-08-2018, 03:54 PM   #33
86prime
Drives: 18 BRZ tS
I think that's what I said, raising the point where the pedal stops, i.e., no further travel. And no matter how much you adjust the pedal, it'll still travel all the way to the stop. This is not about bite point, but rather about eliminating that travel region where the clutch spring misbehaves, without having to remove the spring.
Old 11-08-2018, 04:08 PM   #34
bobbinator
Drives: 2013 FRS Hot Lava
Where can I buy the kit?
bobbinator is offline   Reply With Quote
Old 01-26-2019, 02:58 PM   #35
86prime
Drives: 18 BRZ tS
You can buy all sorts of bumpers from here:
https://www.mcmaster.com/bumper-cushions
However, I still haven't found a durable solution. Maybe I'll cut down some polyurethane?
The felt pads and rubber pads on Amazon are too soft imo.
Old 01-26-2019, 03:37 PM   #36
churchx
churchx's Avatar
Drives: 2014 GT86
As i've mentioned before. Try for bumpstop something of larger & flat area. If area of touch between pedal plate and bumpstop will be few times wider, proportionally it will cut through less/last longer, even if of same material and pushed against with same force / same frequency.
My current "bumpstop", flat furniture leg cushion in ring/washer shape, around 1 1/2 inch in diameter, with hole in mid for screw, lasts for me already for around two years.
Used for it screw from "desintegrated" bumpstop mentioned in this thread (as for me it also didn't last long before it got cut through), and sticked above this stopper thin felt.
jcw99 (01-28-2019)
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
Worn out clutch stopper AsianStyle Issues | Warranty | Recalls / TSB 1 07-05-2013 07:07 PM
New Clutch Pedal Stopper -- Bang For The Buck Mod!! 86_ZN6 Interior Parts (Incl. Lighting) 1 04-17-2013 10:26 PM
Clutch Stopper? wootwoot Engine, Exhaust, Transmission 4 08-06-2012 02:02 PM
