Old 11-05-2018, 10:43 PM   #1
yourboyvic
Drives: brz
Difference between the three different Ace Headers
What is the physical differences and the design differences between the 4-2-1, the Clubsport and the Anaconda?
I know that the 4-2-1 comes with front pipe and the collector comes into play, the Clubsport is extended so there is 'more torque below the line'? And the Anaconda is designed for race cars and the track? What I'm asking is how the physical aspects play to the design/purpose and is there a source online that shows if you want this, this Ace header is best, however if this other thing is what you're after then this is actually better? [MENTION=126922]CSGmike [MENTION=80983]Anyone?
Sorry, FNG here; thanks in advance
yourboyvic is offline   Reply With Quote
Old 11-05-2018, 11:30 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Type A (with different overpipes 350/250/150) and Clubsport ar both 4-2-1 design headers (first 4 runners from each cylinders merge in 2 runners, that merge into 1 connecting to rest of exhaust).
IIRC what differs between these is clubsport being made using cheaper tech (type B slip-on welds) but it has better clearance (matters for RHD). Type A/350 provides best all around gains/most area under curve.
Anaconda is 4-1 design header with all 4 runners merging in one place/collector. Its design makes it better for more top range of rpms and for high-power forced induction.
Your best bet imho would be getting Type A/350 for both daily driving and track use (with good ecu tune of course, eg. DT tune for these headers)
Old 11-06-2018, 10:24 AM   #3
yourboyvic
Drives: brz
Got it, thank you!
ace, aceheader, whichaceheader, whichheader
Difference Between V2.076 and V4.03 NyX_Nick Software Tuning 2 06-01-2018 10:00 AM
TIS and GTS, any difference? babybreath Software Tuning 1 03-28-2016 10:06 PM
bra difference from frs shift2launch BRZ First-Gen (2012+) — General Topics 5 01-22-2015 01:00 AM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
LED vs HID: what's the difference? GhostofAkina Cosmetic Modification (Interior/Exterior/Lighting) 13 04-06-2013 07:23 AM
