Old 11-04-2018, 08:21 PM   #1
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
BRZ/86 stopping distance
So I have been looking high and low for this info. I came across one article that says the standard brakes stops the car in 164 feet from 70. I cannot find a stopping distance for a car with Brembo's. My car has them and was just wondering if anyone knows where the stopping distance of a Brembo'd car can be found? Thanks
Don
Dadillac is offline   Reply With Quote
Old 11-04-2018, 08:25 PM   #2
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Probably about the same. Braking distance is normally dependent not on the brake caliper/rotor but a number of other factors, to name a few: tire compound, pad type, car weight, wheel weight, suspension setup, etc.
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
The Following 5 Users Say Thank You to idkwhatimdoing For This Useful Post:
CSG Mike (11-07-2018), kch (11-05-2018), Spuds (11-04-2018), strat61caster (11-05-2018), wparsons (11-06-2018)
Old 11-04-2018, 08:38 PM   #3
Don
Just find an empty stretch of road and stomp on the brakes. Unless you have some Frankenstein tires, ABS should easily be the limiting factor.
Old 11-04-2018, 08:59 PM   #4
ls1ac
ls1ac's Avatar
Do not forget temp and humidity and altitude.
With ABS all else being equal the largest factor is the compound of the tire (as said above).
Brake kits are to help with repeated stopping for heat management. Not stopping distance.
The Following User Says Thank You to ls1ac For This Useful Post:
kch (11-05-2018)
Old 11-04-2018, 09:04 PM   #5
Dadillac
I was always under the assumption that larger brakes significantly improved stopping distance.
Don
Old 11-04-2018, 09:05 PM   #6
gt86yasss
Drives: White 86
Assuming with the same tires and count-out abs, wouldn’t the bigger calipers provide more force to the brake pad and therefore more contact and friction with the rotor?
gt86yasss is offline   Reply With Quote
Old 11-04-2018, 09:10 PM   #7
Common misconception. Larger brakes can absorb more energy before they overheat and fade. More stopping power in the textbook sense of the word.
Power=energy dissipated per unit time
kch (11-05-2018)
Old 11-04-2018, 10:07 PM   #8
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Let's ignore ABS for a moment. Will you stop in a shorter distance with standard brakes that are capable of locking the wheels into a skid OR heavy duty brakes that will also lock the wheels? If both brake configurations are capable of locking the wheels then stopping distances will be determined by other factors. The advantage with HD brakes is being able to stop repeatedly in the same distance without having the brakes fade to uselessness.
LimitedSlip is offline   Reply With Quote
The Following 5 Users Say Thank You to LimitedSlip For This Useful Post:
CSG Mike (11-07-2018), Grady (11-04-2018), humfrz (11-04-2018), strat61caster (11-05-2018), wparsons (11-06-2018)
Old 11-04-2018, 10:24 PM   #9
Grady
Grady's Avatar
Exactly. Drum brakes will stop you just as good as disk brakes.... the first time!
The Following 2 Users Say Thank You to Grady For This Useful Post:
strat61caster (11-05-2018), venturaII (11-05-2018)
Old 11-05-2018, 12:50 PM   #10
arkanist
Drives: 2016 BRZ Limited, Stock
Don
If your brakes can lock up your wheels (without ABS) then adding bigger / better brakes isn't going to decrease stopping distance.
arkanist is offline   Reply With Quote
The Following 3 Users Say Thank You to arkanist For This Useful Post:
kch (11-05-2018), strat61caster (11-05-2018), wparsons (11-06-2018)
Old 11-05-2018, 01:23 PM   #11
fatoni
Out of curiosity, why does it matter?
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
Old 11-05-2018, 02:59 PM   #12
kch
Senior Misanthrope
kch's Avatar
Like others have said, the limiting factor is your tires. If you upgrade brakes but keep the same tires, your stopping distance will be pretty much the same, as the rubber cannot stop the car any quicker than it already did.
Bigger brakes only help in a track setting, or on twisty mountain roads that require a lot of braking. The goal is to allow the brakes to dissipate more heat so they don't fade with repeated use.
The Following User Says Thank You to kch For This Useful Post:
mistople (11-06-2018)
Old 11-05-2018, 03:59 PM   #13
86MLR
86MLR's Avatar
Tyres, suspension, alignment are all factors.
Old 11-05-2018, 04:28 PM   #14
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Dadillac, I have not found any hard data on stopping distances of the twins with big brakes. However, if you were to take two BRZ’s, one with standard brakes and the other with the Brembo brakes given everything else is equal, (the same make/model/size/compound of tire, time of day, road surface etc.) the Brembo car WILL stop in a shorter distance.
However, that’s not what is important about having better brakes. Everyone seems fixated on stopping and it’s just not about stopping! It’s about slowing down as quickly as possible from a high speed to a lower speed. How many times does anyone have to make a panic, I mean, come to a full and complete stop? Not very often. But I’d say everyone who spends anytime on a major freeway, interstate or 400 series highway will in the course of any given drive will at least once per trip have to rapidly slow down to avoid disaster. In the case of driving across the north end of Toronto it’s many, many times! This is where better brakes really shine. Here’s why…
Standard brakes use a sliding or floating style caliper whereby piston(s) are only on one side. When force is applied it pushes the brake pad against one side of the rotor. Continued force will cause the caliper to pull the opposite pad into contact with the other side of the rotor. It may only take a fraction of a second to accomplish but, that coupled with smaller rotors and less bite equals longer time to slow down. On the plus side, it is an elegant and cost effective way to increase the stopping ability of the average vehicle over the old style drum brakes.
Big Brake Kits, like the Brembo’s use much larger rotors and multiple opposed pistons in fixed calipers. When force is applied it pushes the larger brake pads against both sides of the rotor at the same time. This means big brakes reach their maximum efficiency faster. The forces that opposed piston, fixed caliper brakes produce are far greater than those of a sliding caliper design. The larger the swept area, the greater the force exerted, the quicker the rotating wheel assembly will slow down. And slowing down over a shorter distance should be the goal. Having the ability to stop quicker is a bonus. One I have had to put to the test more times than I wish to recount.
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
humfrz (11-05-2018), JesseG (04-22-2021)
Stopping the window half way BirdTRD Issues | Warranty | Recalls / TSB 18 11-07-2017 04:09 PM
Klunks when stopping NOHOME Scion FR-S / Toyota 86 GT86 General Forum 8 06-26-2017 11:44 AM
FR-S - AT nearly stalls when stopping WryGuy Issues | Warranty | Recalls / TSB 12 05-27-2016 03:04 PM
Distance? Nonfacter1 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-13-2015 10:17 AM
Distance Drive for New Car Kundiethala Scion FR-S / Toyota 86 GT86 General Forum 25 08-14-2012 10:56 PM
