#197 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Yeah, that's really more your springs, not the shocks. Base model and Z51 corvettes have this problem. Anything even resembling a track day tire is too much for them whereas the GS, Z06 and Z07 springs are just fine on substantially larger slicks. My friend's Z51 practically endos on the brakes on 265 RE71 whereas my car would be 100% fine on 315 slicks (and I have much stronger brakes too). We both have the same mag-ride shocks. He dialed his up to max stiffness and it didn't do much.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#198 | |
Drives: 2016 White Pearl BRZ Premium
You aren't maximizing any tire's traction capability without a quality suspension setup. Slicks may cut 2 seconds off the bat with bad suspension and a driver that wasn't maximizing the previous tire's potential anyway... but that doesn't mean either tire was anywhere near being used to it's full traction potential. Not making any judgements on anyone's driving skills at all here. Just saying that good suspension DOES make a big difference - especially with stickier "slicks" or any tire that has a "peakier maximum friction zone". With those it's even MORE important that you get maximum chassis communication at the limit. |
| The Following User Says Thank You to Joesurf79 For This Useful Post: | CSG Mike (11-01-2018) |
#199 | |
It's allllll a system, it's not just spring rate. What's the spring rate delta between the stock/Z51 and the GS? *EDIT* think I found it - for the C7 stingray with the Z51 package and the C7 GS, it looks like the front spring rate was 2% stiffer and the rear was 8-ish percent. Not exactly a huge rate difference - i'd be surprised if I could feel that difference all things being equal. Not saying the suspension action and car performance you describe wasn't occurring - his car may have been nose diving like a mutha - but it wasn't due to a massive spring rate disparity
#200 | |
Drives: '15 STX
| The Following User Says Thank You to tony_r For This Useful Post: | CSG Mike (11-01-2018) |
#201 |
Drives: Track preped NA FRS
Is nobody going to say anything about that 2s difference between slicks and street tires? Because my experience and everything I see on track (time attacks) points towards a fairly larger difference than that (about double actually).
#202 |
Drives: 2017 BRZ
What course length? I think 2s is likely accurate for some tracks, but certainly not all.
#203 |
Anywhere from 3k to 5k long, the difference is around 3 to 4 secs, depending on how twisty the track is, at least for our cars is, maybe that changes when the weight/power ratio changes drastically. Unless we are talking about little 1k to 2k tracks that are around 1min lap, there it is around 2s per lap, but there arent many tracks like that down there, are there?
#204 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | cjd (11-01-2018) |
#205 | |
Typical call it 2.4 mile-ish track going from a street tire you'd do a track day on (R888R, NT01, MPSS, etc) to a Slick/semi/cheater slick you'd do a track day on. I'm not trying to go from one extreme to another extreme. I'm not sure about that. I think virtually every driver would take slicks every single time. I'd be really surprised if one coilover system to another resulted in 2 second difference in lap time, assuming both are setup right. Suspension as a whole (geometry, spring rates, shocks, etc) can do a lot, but just one shock brand to another? Eh.
#206 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Joesurf79 (11-01-2018) |
#207 | |
Could easily be conditions from one day to another, but I expected to be flying on 888R. At least close to my Cup2 times given I had another 30 or 40mm of rubber up front (and it doesn't need more in the rear). My biggest problem with PSS is that they are greasy by the second full lap.
#208 |
Laptimes with a skilled driver aside...good shocks are just a lot more fun and confidence inspiring IMO. That also tends to translate into more consistent times for a newer driver.
There are plenty of time attack cars on crappy shocks and sticky tires that can put in a good lap. But watch the in-car video and it's a battle with thin margins. Not always fun or consistent lap after lap (without even mentioning shock fade). The cars with good shocks and enough travel and a nice balance make for a happy driver and longer lasting tires and drama-free consistent lap times. ![]() Anyway, really love my MPS4S and the older MPSS on the street but it's less of a track tire and more of a tire you can track if you need to. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#209 | |
That could explain the lack of gain from the R888R - any tire can be over driven and once it's out of its operating temp range, it's a losing battle until you back off and cool the tire back to its happy place
#210 | |
Haven't run NT01 on the GS yet, but R888R are VERY pressure sensitive as well, as you might expect. I can't remember the numbers right now, but I want to say they were good at 33 and worthless at 36 or so. Might be off on those numbers- this was 4 months ago. edit: and yeah, obviously I was over-driving them
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. Last edited by GrandSport; 11-01-2018 at 05:28 PM. |
| The Following 2 Users Say Thank You to GrandSport For This Useful Post: | Joesurf79 (11-01-2018), Racecomp Engineering (11-01-2018) |
| Contemplating Fix bumper or buy aftermarket. Earlier than expected choice | Heat Sinker | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-30-2016 04:34 PM |
| Contemplating LS swap, brakes to suit the package? | hayden55 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 03-07-2016 03:42 PM |
| Contemplating new ARP studs ... anyone with bad experiences? | donoman | Tracking / Autocross / HPDE / Drifting | 20 | 06-02-2015 12:50 PM |
| Contemplating buying used BRZ with tons of mods but is it worth it? | Sebaru | BRZ First-Gen (2012+) — General Topics | 48 | 07-19-2013 11:25 AM |
| Contemplating Raven Purchase Please Advise | steve87j | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 11-29-2012 10:44 PM |
