Old 10-29-2018, 10:00 AM   #1
Treize
Drives: 37J 2013 FRS
Turbo burning?
Hello, need help figuring out this issue,recently installed turbo myself Blitz tuner kit with cat.After installation one hose came off and oil spilled cleaned it up as much as possible car smoked a bit then stopped smoking.But I noticed this burning smell checked to make sure no hoses were rubbing any belt or nothing too close to one another. But after driving a bit I observed what looks to be the turbo burning there was faint smoke coming from it,the part particularly in the pic.any ideal? I was thinking maybe I clamped the hose too tight or wrong spot?
Treize is offline   Reply With Quote
Old 10-29-2018, 11:40 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If there's no residue on the CHRA you can see and nothing around that bolt, I wonder if it's leaking inside of that line and you can't see it because you've covered it in a heat management tubing. I'd honestly cut a little slit at the lowest point in that tubing and see if oil starts dripping out.
EDIT: Just realized, if that tubing is NOT COVERING something or SS braided line, I retract everything I've written; don't cut it!
Tcoat (10-29-2018)
Old 10-29-2018, 01:51 PM   #3
Treize
That line is SS braided. On the other side of that is a hose that goes that connects to the oil pan the oil return line. That's what I'm referring to. The pic is just to show what part the smoke is coming from,its that part of the housing where its smoking.
Old 10-29-2018, 02:24 PM   #4
sid94
Drives: 2013 frs
Did you put the crush washers on both ends of the banjo bolt?
sid94 is offline   Reply With Quote
Old 10-29-2018, 02:33 PM   #5
DarkPira7e
DarkPira7e's Avatar
And there's no oil leak at the other end of that hose (At the fitting going into the oil pan)? I was suspecting the line leaking and the smoke coming out of your hose cover; this may make it seem like the fitting is smoking, when it's actually coming from the hose itself. Since it's the drain line, I guess there's no lowest point to poke and see if oil comes out.
As stated elsewhere, it may be this fitting. How long total has this kit been installed? This may be explained away if it's been less than two weeks and there are no visible leaks. Hopefully it's not that your oil drain line is backing up into the turbo and putting pressure onto the seals.
Old 10-29-2018, 03:37 PM   #6
Treize
Kit has been on there a week maybe week and a half,sat in garage after initial leaks found due to time constraints. there was an initial leak from the fitting there but that was taken care of.but I'll double check that area.
Edit:found the leak.
Old 10-29-2018, 05:09 PM   #7
DarkPira7e
DarkPira7e's Avatar
I'll admit, I have no idea what I'm seeing. But glad you found the leak
Old 10-29-2018, 10:14 PM   #8
Treize
It's where the compressor connects to the headers. I'll try to get it taken care of asap. Another question or 2, I have my afr gauge wired into the dimmer switch but it only comes on when I turn on the lights. Did I tap into the wrong wire? Also is there a way to extend a power harness or somewhere I can tap into near the top of the dash,the power harness for my boost gauge is too short to reach the side panel.
Old 10-29-2018, 11:11 PM   #9
DarkPira7e
DarkPira7e's Avatar
You likely need both connectors connected. It sounds like you wired the constant accessory to the dimmer. Constant 12v should be hooked to a constant. There should be another wire that goes to the dimmer. Wires are wires, so theoretically you can extend them as far as you please. Just use the correct gauge of wire that matches what you're extending, and make quality connections. Don't just twist wires together and hope it works out long term
Old 10-29-2018, 11:52 PM   #10
Treize
Gotcha,I'll rewire it. The burning smell has returned and the leak gone,the fitting on the turbo where the drain hose is connected has oil around the the base of the fitting which is where the smoke and smell is coming from.
Burning Oil? RandomHero Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 10-04-2019 04:56 PM
86 air con burning smell crewchief Issues | Warranty | Recalls / TSB 36 10-21-2017 11:49 AM
'17 BRZ burning smell Zoh Issues | Warranty | Recalls / TSB 28 05-14-2017 11:09 PM
Something Burning? samisons Issues | Warranty | Recalls / TSB 8 11-27-2013 10:18 PM
Burning oil? N/A Synack Issues | Warranty | Recalls / TSB 11 11-08-2012 06:14 PM
