#197 |
Drives: Scion Frs
What class should i run? SCCA
f/r sway bars
coilovers camber bolts OFT e85 stage 2 tune Borla catted header hatless frontpipe/invidia n1 18x9.5 wheels w 255 michelin ps5s IRP short shifter |
#198 | |
Drives: 2017 BRZ
STX if you go back to 93 octane, 9" wide wheels, and possibly a different shifter if someone is going by the book. You randomly still have a cat (required) which is unusual
#199 | |
Drives: 2013 WRB BRZ
EDIT: Maybe the shifter? 15.10-DD-8
#200 | |
Drives: 2014 Subaru BRZ
I'd recommend running pump gas and getting some 17x9 wheels with some RE71r's (255/40-17) and run in STX unless you don't care, then run in CSP, SM, or XP. |
#201 |
Drives: 2017 BRZ
e85 and IRP shifter (it removes a transmission mount). At least, I am not finding anything that states a change in fuel rules from touring.
#202 | ||
| The Following User Says Thank You to BigTuna For This Useful Post: | cjd (10-25-2018) |
#203 |
Drives: 13 FR-S
Quick question. Have Scion F-RS. Can I replace my struts with OEM BR-Z struts and remain in stock DS? Almost the same minus spring rates, but "technically" from a different car so aren't "technically" OEM parts, but they fit like OEM parts (because they really are...).
In this general idea, can any BR-Z parts be put on a FR-S and remain in stock? |
#204 | |
Refer to rule 13.5.A And no, for instance, if you put an OEM BRZ spoiler on an FRS, its technically illegal. I highly doubt anyone would question it though.
#205 |
Drives: 2017 BRZ
Blah. That's why I missed it. Thanks!
#206 |
Drives: 2014 WRB BRZ Limited
How would the IRP shifter not be STX legal?
The rules state that any mechanical linkage can be used: G. Any mechanical shift linkage may be used. I also don't think it changes how the transmission is mounted; Any engine or transmission mount is allowed provided it attaches only to the original mounting points, does not relocate the engine/transmission (other than incidental to changes in compliance material), and weighs no less than the OE mount. All components between the engine/transmission and the mounting structure are considered to be part of the mount assem- bly. Is it maybe because of the very slight weight reduction? Though its debatable that the shifter be considered part of the mounting assembly. Last edited by BR-ZED; 11-24-2018 at 02:59 PM. |
#207 | |
Drives: 2017 BRZ
It removes a transmission mount.
#208 |
Is the shifter carrier here technically a transmission mount though? It seems as though it is just a component used to connect the shifter to the transmission. I can't see how it's bolted into the car but was under the impression it attached the shifter to the transmission, not the transmission to the car.
#209 | |
Drives: 2017 BRZ
I believe the argument is that it limits rotation. There is no functional reason for it to attach to the body at all otherwise, and the IRP is exhibit A proving it isn't needed...
#210 | |
Yeah but I'm still trying to see if that piece (shift lever retainer) in the diagram below even attaches to the body. It seems to only attach to the transmission. Am I missing something?
| Official DTM Autobody Services Thread for FT86Club! | DTMAUTOBODY | Southern California | 9 | 12-31-2013 02:09 PM |
| Official FT86Club Chatroom? | wrxgoose | Site Announcements / Questions / Issues | 13 | 09-15-2012 05:26 PM |
| Official FT86Club decal idea? | Hanzo | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-21-2012 08:09 PM |
| Official FT86Club decal ideas? | Hanzo | BRZ First-Gen (2012+) — General Topics | 46 | 06-04-2012 01:15 PM |
