Old 10-25-2018, 09:40 AM   #197
Mdulin
Drives: Scion Frs
What class should i run? SCCA
f/r sway bars
coilovers
camber bolts
OFT e85 stage 2 tune
Borla catted header
hatless frontpipe/invidia n1
18x9.5 wheels w 255 michelin ps5s
IRP short shifter
Mdulin is offline   Reply With Quote
Old 10-25-2018, 10:18 AM   #198
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Mdulin View Post
f/r sway bars
coilovers
camber bolts
Borla catted header
IRP short shifter
Uncompetitive in SM but that's where you'll go.
STX if you go back to 93 octane, 9" wide wheels, and possibly a different shifter if someone is going by the book. You randomly still have a cat (required) which is unusual
Old 10-25-2018, 10:27 AM   #199
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
What mods would put him in SM rather than CSP?
EDIT: Maybe the shifter? 15.10-DD-8
BigTuna is offline   Reply With Quote
Old 10-25-2018, 10:27 AM   #200
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
f/r sway bars
coilovers
camber bolts
Borla catted header
IRP short shifter
If you run 93/91 instead of e85 and went down to 9" wide wheels you could run STX, you've put yourself into CSP or SM with the wheels wider than 9" and the e85 (either one bumps you out of STX).
I'd recommend running pump gas and getting some 17x9 wheels with some RE71r's (255/40-17) and run in STX unless you don't care, then run in CSP, SM, or XP.
14stu is offline   Reply With Quote
Old 10-25-2018, 10:35 AM   #201
cjd
cjd's Avatar
Drives: 2017 BRZ
e85 and IRP shifter (it removes a transmission mount). At least, I am not finding anything that states a change in fuel rules from touring.
Old 10-25-2018, 10:52 AM   #202
BigTuna
BigTuna's Avatar
E85 is legal in CSP. It's in the Fuel section, not the allowed modifications section. 3.6.B
In addition to fuels which are allowed by Section 3.6.A, Street Prepared, Street Modified, Prepared, and Modified category vehicles may use diesel fuel, any grade of gasoline, or Federally-approved E85.
The Following User Says Thank You to BigTuna For This Useful Post:
cjd (10-25-2018)
Old 10-25-2018, 12:22 PM   #203
Zycle
Drives: 13 FR-S
Quick question. Have Scion F-RS. Can I replace my struts with OEM BR-Z struts and remain in stock DS? Almost the same minus spring rates, but "technically" from a different car so aren't "technically" OEM parts, but they fit like OEM parts (because they really are...).
In this general idea, can any BR-Z parts be put on a FR-S and remain in stock?
Zycle is offline   Reply With Quote
Old 10-25-2018, 12:25 PM   #204
BigTuna
BigTuna's Avatar
Yes, shocks are able to be swapped out in stock class. You could upgrade to Koni's if you really wanted to.
Refer to rule 13.5.A
And no, for instance, if you put an OEM BRZ spoiler on an FRS, its technically illegal. I highly doubt anyone would question it though.
Old 10-25-2018, 11:18 PM   #205
cjd
cjd's Avatar
Drives: 2017 BRZ
Blah. That's why I missed it. Thanks!
Old 11-24-2018, 02:24 PM   #206
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
How would the IRP shifter not be STX legal?
The rules state that any mechanical linkage can be used:
G. Any mechanical shift linkage may be used.
I also don't think it changes how the transmission is mounted;
Any engine or transmission mount is allowed provided it attaches only to
the original mounting points, does not relocate the engine/transmission
(other than incidental to changes in compliance material), and weighs no
less than the OE mount. All components between the engine/transmission
and the mounting structure are considered to be part of the mount assem-
bly.
Is it maybe because of the very slight weight reduction? Though its debatable that the shifter be considered part of the mounting assembly.
BR-ZED is offline   Reply With Quote
Old 11-24-2018, 11:13 PM   #207
cjd
cjd's Avatar
Drives: 2017 BRZ
bly.
It removes a transmission mount.
Old 11-24-2018, 11:22 PM   #208
BR-ZED
BR-ZED's Avatar
Is the shifter carrier here technically a transmission mount though? It seems as though it is just a component used to connect the shifter to the transmission. I can't see how it's bolted into the car but was under the impression it attached the shifter to the transmission, not the transmission to the car.
Old 11-24-2018, 11:31 PM   #209
cjd
cjd's Avatar
Drives: 2017 BRZ
I believe the argument is that it limits rotation. There is no functional reason for it to attach to the body at all otherwise, and the IRP is exhibit A proving it isn't needed...
Old 11-25-2018, 08:15 AM   #210
BR-ZED
BR-ZED's Avatar
Yeah but I'm still trying to see if that piece (shift lever retainer) in the diagram below even attaches to the body.
It seems to only attach to the transmission. Am I missing something?
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
Official FT86Club decal ideas? Hanzo BRZ First-Gen (2012+) — General Topics 46 06-04-2012 01:15 PM
