Old 10-25-2018, 04:57 AM   #1
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
racing seat install questions
any of u guys had 6 point harness and racing seat installed on driver side ?
already bought seat and harness and resistor which is 3.3 oms 2w
my question is where u guys drill the holes for the harness
i am think to drill 4 holes on the floor
or
2 holes on the floor for the leg harness and 1 hole on the transmission
side with factor seat belt on the other side
still going to keep my stock seat belt for sure
any pictures will be helpfully
thx guys
update 2018 10 30
now i running a problem which my bracket is not allow me any lower
but it was just higher compare to stock seat position
any one using sparco ergo size m seat ?
i am using the sparco bracket they r not good for a tall guy
i am 183 cm
any one can help
i currently think to buy another bracket like buddy club or nagisa double lock bracket
the problem is buddy club my not solid with their rails
and nagisa seen be a best opinion, but when i connect to evasive they said it not going to fit my seat
i saw one guys using my seat with that bracket
i dont know neeed help
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 10-25-2018, 06:10 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
How about buying & installing this & this instead of drilling? Normally use stock belt, when multipoint one @track, lower back of seats.
As in here.
Old 10-25-2018, 07:04 AM   #3
86MLR
86MLR's Avatar
As in here.
That harness bar is way to low IMO.
Also, if your going fixed seat and harness you really need some form of ROPS (roll over protection), i.e. roll cage, because in the the event of a roll over, due to being locked in upright from the harness, without ROPS, your head and neck will now be the things taking the hit.
https://www.supercars.com/videos/201...in-townsville/
With a 3 point, your shoulder can drop, thus getting your melon out of the crush zone.
Something like this for the street and the occasional track day or khana would be good
https://www.renowngarage.com/blog/re...oint-roll-bar/
Or this
https://gspeed.com/product/ft86-bolt-in-roll-bar/
Because this
http://www.speedhunters.com/2017/12/...ing-harnesses/
http://www.speedhunters.com/2017/07/roll-cage-tech/
As for mounting the seats, if you cannot pick up the OEM locations, you may require plates underneath, no point in having all the good gear, only to have the fixtures rip through the floor in the event of an accident.
Food for thought
The Following 9 Users Say Thank You to 86MLR For This Useful Post:
atomicalex (10-29-2018), chickunfut (03-24-2019), Jyn (03-25-2019), Leonardo (10-25-2018), new2subaru (10-25-2018), Takumi788 (10-26-2018), TofuJoe (03-25-2019), Tristor (10-25-2018), x808drifter (10-25-2018)
Old 10-25-2018, 05:25 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
^^^^ That.
Old 10-25-2018, 07:47 PM   #5
kch
Senior Misanthrope
kch's Avatar
I would suggest having a professional race shop handle the install for you.
Edit: and have them fab you a roll bar while they're at it
Old 10-25-2018, 08:27 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I bet those seats are universal and will need specific gt86/brz/fr-s seat brackets to install them.
I totally destroyed an OEM seat trying to salvage the seat rail. I ended up throwing it away and purchasing new seat brackets to install my racing seats. Then you drill your bracket and mount the seat to it. No drilling on the car. The new seat bracket (if you have ordered the correct one) will bolt to the factory seat location.
I LIKE TIRES!
Old 10-31-2018, 12:55 AM   #7
i am 183 cm
any one can help
Old 10-31-2018, 12:35 PM   #8
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
i am 183 cm
any one can help
What's the issue with Buddy Club rails?
tyler_win_photo is offline   Reply With Quote
Old 11-01-2018, 05:29 AM   #9
people said that the rail is not parallel after u tighten them down
and it may waggling when u hard cornering on the track
i have use it, so don't my word
Old 03-25-2019, 12:43 AM   #10
86MLR
86MLR's Avatar
Originally Posted by FT86wannabe View Post
Fellows, as I understand you are good with racing seats. On reviewseye, I found reviews on some models. So, I want to make a present for my brother but I don't know a lot about it. Which one would you choose? Or maybe it's better to consider other options? Thanks in advance.
Seats are very personal, your friend needs to sit in it to see if it fits him and the car.
Plus cheap and poorly fixed seats can kill.
Legalities might be a issue IRT airbags, or lack of them.
The Following User Says Thank You to 86MLR For This Useful Post:
Tristor (03-25-2019)
Old 03-25-2019, 07:18 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
86MLR: expensive and well fixed seats can kill aswell. That's why such seats are street-illegal setup (at least in countries that care about safety and enforce modification legality rules), as one needs in addition to such also multipoint harness and rollcage and wear helmet, but due reducing visibility helmet is no-go on streets either. Catch 22.
I'd probably go to what's still legal, as in reclaimable recaros, instead of braking the law or modding car to track-only non-street-legal one. At most would add to that seat also bolton harness bar like Essex's + helmet & multipoint safety belts (it that combo gets allowed on local tracks) only on track, while daily driving with stock belt on streets.
korhun (02-01-2020), x808drifter (03-25-2019)
Old 05-04-2019, 12:12 AM   #12
get everything fix and waiting for the harness install. will be done on wedneday
will post a review !!!
NRG Harness Bar install questions fizzymike Cosmetic Modification (Interior/Exterior/Lighting) 4 03-07-2018 09:09 AM
SARD Racing Japan seat cover install & review CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 136 09-22-2017 05:58 PM
Gauge install questions drz400dude Forced Induction 1 06-12-2017 02:48 AM
Harness Bar with Stock Seat Questions Lebby83 Tracking / Autocross / HPDE / Drifting 10 02-13-2017 07:52 PM
Cat back self install questions? Dispect Engine, Exhaust, Transmission 24 10-31-2012 03:47 AM
