#43 | |
Drives: 2018 BRZ tS
#44 |
Drives: 2017 Subaru BRZ Limited PP
I was just told by a retailer that there is now a Federal law prohibiting 3rd party manuf from adding guidelines because people are stupid and were not adjusting them and were running into things and complained. Pioneer just confirmed due to NHTSA requirements.
| The Following User Says Thank You to COBlue For This Useful Post: | SkyeHack (10-28-2018) |
#45 | |
Drives: 2017 Subaru BRZ PP WRB
| The Following User Says Thank You to NCtoBRZ For This Useful Post: | COBlue (10-28-2018) |
#46 |
Everyone in this thread - especially NCtoBRZ has been a huge help, but I still can't get past the dreaded black screen for the backup camera. Everything else works! Maybe somebody can find what I'm missing? 2017 BRZ PP with Pioneer AVH-2440NEX through Maestro RR with Drok 12v-6v and TO1 harness modified as below. 6.01v to camera verified.
Antenna adapter (blue) wire to 10pin harness pin 8 ANT + (blue wire) 28 PIN HARNESS PINS 2 (Reverse) - HU Reverse Gear Signal Input (purple/white) AND Drok Converter 12V (red) 9 (Amp Signal 12v) - HU Remote System Control (blue/white) 11 (Camera power 6v) - DROK 6v (yellow) 12 (Camera +) - RCA camera + (yellow) 13 (Camera -) - RCA camera - (brown) 15 (Parking) - HU Parking brake (light green) if no bypass used 17 (Vehicle Speed VSS) - HU VSS wire (if used) 20 (Camera Pwr GND) - DROK 6v ground (black) 21 (SW1) - RR yellow/red (iDatalink doc shows purple/red) 22 (SW2) - RR pink/red 23 (SW grnd) - RR black AND Drok 12 ground (black) Also note that Crutchfield and others use the AX-TOYUSB adapter cable for the OEM USB plug which does not fit the 2017, the AX-SUBUSB is apparently the proper cable (which I can verify when it gets here). Last edited by COBlue; 10-31-2018 at 05:13 PM. Reason: USB Adapter |
#47 | |
| The Following User Says Thank You to NCtoBRZ For This Useful Post: | COBlue (10-31-2018) |
#48 |
I had already sacrificed an RCA when I was considering going without the TO1 so tried that - and it worked!!! Two days of head banging for a bad wire. Thank you!!
#49 |
The Maestro RR is both a blessing and a curse. As we both discovered, the wiring on the 28 pin harness isn't even remotely correct. Low voltage from the RR kept my camera from working and a bad RCA cable kept yours from working. I appreciate the functionality of the RR but they need to improve quality control and update their harnesses to match the application as they say it will. Oh well... in the end we have working head units that are way better than the stock head unit in every way possible!
#50 | |
#51 |
Just saw this post http://www.12voltdata.com/forum/view...?f=318&t=18422 about the RR possibly draining the battery. Has anyone else noticed this?
#52 | |
Drives: 2016 Subaru BRZ Limited MT
I had a similar experience after installing my 2440NEX into my 2016 BRZ but I think it was probably related to an error I made rather than the NEX itself. A few days after I finished the install and testing it while driving with no issues, I decided to run the Auto EQ thing in my garage to see if that made any difference in the audio experience. To do this, the instructions say that the car must be on in the accessory mode (engine not on) and that the EQ would take around 10 minutes to complete. After it was done, I tried to start the car and the engine wouldn’t turn over due to the battery. I don’t remember how much the battery had drained but after I jump started it there were no further issues. Luckily, this was around the time I take it to the dealer for maintenance so during my visit I mentioned it to them and after they checked it out they said that sure enough the battery was depleted lower than acceptable and they replaced it for free. Ever since then I have not had any issues with the battery even after several days (and even one instance of over a week) of not turning the car on. Of course the only other variable I have tried to replicate was running the Auto EQ thing again but I really have found no reason to since I am happy with the current audio quality and experience. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to MarvinC93 For This Useful Post: | COBlue (11-05-2018) |
#53 | |
Response from iDatalink, note they are moving away from the TO2 harness: "We are aware of the issue, which pretty much only occurs in BRZ/FRS/Toyota 86. If you de-pin pin 9 of the green 10-pin plug (the blue wire), it should fix the issue. Now that the SU2 harness and firmwares are released, we are planning on switching these cars to that platform, which should fix the issue entirely." |
#54 |
I ended up moving to the SU2 harness and it's a much simpler installation, but not perfect. See this thread for more info.
#55 |
Drives: 2017 Toyota 86
Bumping this thread. I’m interested in idatalink features but this sounds like it’s far from a plug and play install that Crutchfield would have you believe.
#56 |
With the SU2 harness and updated firmware it's MUCH easier than the TO1 and numerous mods. Only mod I had to make with SU2 was for the power antenna but I believe that was subsequently resolved.
| Installing Pioneer AVH-2330 NEX with AndroidAuto | TheLaughingMan | DIY (Do-It-Yourself) Guides | 17 | 08-26-2019 04:33 PM |
| Maestro idatalink test dummy | tofurun | Electronics | Audio | NAV | Infotainment | 30 | 10-18-2016 01:01 PM |
| DIY: Installing Pioneer AVIC Z150BH Aftermarket Head Unit | tiz22 | DIY (Do-It-Yourself) Guides | 35 | 07-24-2014 07:03 PM |
