#71 |
Drives: 2013 Ultramarine FR-S
So even with a Key car. If I buy the techstream I can program the Immo system/new cluster at home?
#72 | |
Drives: MR2, Sliver BRZ
Are you using the MRS colins adapter for your swap?
Always looking to tinker with something..
#73 | |
and Yes I am
#74 |
Drives: 1949 UFO
#75 |
Well according to CK its easy though techstream. But seems he said ANY 2017+ cluster can be binded to a older car as the new clusters are binded at all.
I have never used a tactrix cable. Or not sure what version of techstream he had. @DustinS i ask because im not sure if it binds with the only and the BCM authenticates with the ECU. and since its going though a gateway if it would also pass on the binding data to the Original ECU assuming you wired your car to the stock Starter relay to turn your engine over..
| The Following User Says Thank You to geraldjust For This Useful Post: | DustinS (10-25-2018) |
#76 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
just curious where did u get the 2017 wiring diagram,
#77 |
Le Ingenieur
Drives: 2015 Subaru BRZ Aozora
Hey I am planning on doing this retrofit. How did you guys get the odometer to match the reading of the old cluster? I would prefer to figure this out before the car is put into storage. Mind that I have a push button car.
#78 |
Wel the Usual places were to get the 2017+ wiring diagram. Do you need it?
#79 |
Well since you got a push start car you should be plug in play mostly. Well the way it's possible is though reading the EEPROM chip directly from the board. then changing it based into what your old cluster odo. I would offer it as a service if anyone just not sure if people are interested.
#80 | |
Le Ingenieur
It’s just really expensive to ship a cluster across the border. I’m in Toronto and it seems like you are in SoCal. I however would be interested in the joystick you seem to be working on. Sent from my iPhone using Tapatalk |
#81 | |
Space for Rent
#82 | |
For the joystick are you thinking of replacing the middle button. Or placing it were ever you see fit? @1GiantTurtle PM'ed
#83 |
Drives: Brz WRB - Europe LHD
@geraldjust
Hi mate, I am now still searching tS JDM cluster MY'17 (I get the MY'13 one and I paired with no issue as it was new from Japanparts.), can you give me directions about wiring? (colours from car cluster main harness), which one in PIN 1 and so on, thanks mate. I know that in US is sold this item but I need only KMS range and not MPH.
#84 | |
Le Ingenieur
Middle button seems to be the most natural spot for it. Sent from my iPhone using Tapatalk |
| 2017 Limited Gauge Cluster | halleffect | Electronics | Audio | NAV | Infotainment | 26 | 10-22-2020 07:32 PM |
| 2017 GR edition cluster mod | vagthomas | Cosmetic Modification (Interior/Exterior/Lighting) | 63 | 06-29-2020 04:41 PM |
| Help! Is there anyway to change the 2017 cluster start up image? | slashlee | DIY (Do-It-Yourself) Guides | 2 | 11-17-2018 05:36 PM |
| 2017 Limited Gauge Cluster | halleffect | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-16-2017 03:55 AM |
| 2017 gauge cluster | Drakiv | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-14-2016 11:32 PM |
