Old 09-22-2017, 01:57 PM   #323
JD001
JD001's Avatar
Drives: Subaru BRZ
Update: New fuel pump installed today. Drove it back home (about 20miles), so far no crickets.. Got so used to the little blighters, my brain is still hearing them even though in reality they have been banished (I hope!).
Old 09-25-2017, 09:41 PM   #324
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
There are a few new TSBs for the BRZ, specifically the 2015 Head unit re: firemware upgrades. I downloaded the file, but can't find the TSB with the update information.
This is supposed to fix the constant head unit crashing/reboots.
It's TSB 15-193-16, and apparently 15-193-16R as well, there's a laundry list of other TSBs on true delta as well. Can anyone post the PDFs?
https://www.truedelta.com/Subaru-BRZ-tsbs-1097,2015
Edit: this may be for Clarion headunits . . . were there Clarions in 2015 BRZs?
Here's the link to the firmware update: https://content.subarunet.com/snet/b..._downloads.htm
DoomsdayJesus is offline   Reply With Quote
The Following User Says Thank You to DoomsdayJesus For This Useful Post:
swarb (09-25-2017)
Old 06-22-2018, 02:02 PM   #325
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Michaelwelty View Post
I was just in for my first oil change about a week and a half ago and there was no mention on a recall or TSB
For what specifically, recall they will do on their own. TSB they won't do unless you tell them or there are symptoms of something
Old 09-05-2018, 06:28 AM   #326
Leeky
3S-GTE Junky
Leeky's Avatar
Drives: Toyota Celica GT-Four ST205
Hi guys,
FYI the TSB's unfortunatly aren't the same number world wide I have found.
Example -
S-SB-0023-12 (Chirping Noise from High Pressure Fuel Pump) - is actually EG-0113T-1115 in europe.
Regards
Leeky
Leeky is offline   Reply With Quote
The Following 3 Users Say Thank You to Leeky For This Useful Post:
Dadhawk (09-05-2018), Tcoat (09-05-2018), Ultramaroon (09-05-2018)
Old 09-06-2018, 10:25 PM   #327
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Long shot for more info... I had my plugs done by the dealership @ just over 60K, and, almost certainly coincidentally, seem to have been getting about 2 or 3 less mpg ever since (at around 75K now). My son, who's a total car nut, said that there's a TSB out for leaking fuel injector seals in the early FR-S (mine's a 2013). He listened to the engine and heard a distinct sort of whooshing pop after reving the engine and letting it return to idle, which he said confirms that diagnosis. I haven't seen a TSB for that. Anybody know anything? I've got a "Certified" warranty for another 25K miles or until July, 2019, whichever comes first, on the drivetrain. Covered? The car, other than the slight drop in mpg, seems to be running as it always has... great.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 09-06-2018, 11:23 PM   #328
FRSBRZGT86FAN
That's an earlier issue, the fix was a new tune and replacing the seals on those effected. I would get it diagnosed just in case it's a similiar issue to this because the DIY repair is quite extensive for the shady tree mechanic:
[ame]https://www.youtube.com/watch?v=VnFa2IvNs9g[/ame]
[ame]https://www.youtube.com/watch?v=450Pov98STg[/ame]
http://www.ft86club.com/forums/showthread.php?t=42849
It should be stressed to the dealership that along with the DI seal replacement that an ECU update to the latest ECU Firmware for your car should be performed through techstream, otherwise later on in the cars life this will happen again. Assuming that is the noise you or your son is hearing. Also that is not a North American TSB it's an australia, south africa or other countries service bulletin and didn't get sent through the channel to North America for some reason. If the seals are replaced and the tune isn't updated you can be super sure its safe by flashing a Stage 1 OFT tune or the like onto the car which has the fix to prevent it
from occurring again as well. Check to see what month and year your car was built
@Sigh-on-Rice aware of anything posted in the US?
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
gravitylover (10-14-2018), MuseChaser (09-07-2018)
Old 09-07-2018, 11:30 AM   #329
MuseChaser
MuseChaser's Avatar
Originally Posted by FRSBRZGT86FAN View Post
.... Check to see what month and year your car was built
Thanks for the very helpful, detailed reply. Manufacture date of my car is June, 2012. I listened to the linked videos and read the linked thread in addition to all the great info you included. I'm not sure my issue is the same thing (or really even if it IS an issue), but it very well could be. The sound my son pointed out to me sounds like a single "PPPffffffffffff" ("Poof," only without the vocalized "oooo") as the engine returns to idle after having been goosed... like burping a big Tupperware container, if that helps. In the first linked video, the "pop" is more like a deep "click" sound, and it occurs just as the engine is goosed, rather than as it returns to idle.. if I'm hearing it correctly?
On my car, Idle is smooth (as it's always been), no CEL, no other symptoms that I'm aware of.. just a slight reduction of mpg.. about 29/30 around town (used to be 32 or so) and 36 highway (have done 38/40 on the same trips). Probably should have the dealership look at it, I guess.
Old 09-07-2018, 02:51 PM   #330
FRSBRZGT86FAN
I'd still have it checked, my just be a quirk or engine whirring but it's safe to double check. Ask the tech to let you show them where the sound appears.
Old 10-13-2018, 03:55 PM   #331
gpvecchi
gpvecchi's Avatar
Guys, Toyota Europe lets you download calibration files for free, but it asks for bulletin ID, does someone has latest bulletins for ECU and ABS?
Old 10-14-2018, 10:14 AM   #332
gravitylover
...Check to see what month and year your car was built
Mine is also an early build. I don't think I'm experiencing this problem but just out of curiosity how hard is it to replace the injectors? I know it's usually a significant project that most backyard mechanics won't do.
Old 10-14-2018, 08:45 PM   #333
FRSBRZGT86FAN
Port injectors are easy, direct injectors pretty damn involved. I'll put a link to a you-tuber I watch who did it to his car when he first started supercharging it:
[ame]https://www.youtube.com/watch?v=sdeO4rBwuQ4[/ame]
It's not replacing the injector, it's replacing the seals, also its only on cars that have the symptoms of popping. Otherwise you don't do it, also you'd want to update to an aftermarket tune or flash an updated factory tune so it doesn't happen again.
Old 10-15-2018, 09:37 AM   #334
gravitylover
Thanks.
I have a stage 1 tune now and it has solved a bunch of silly "issues" I had, nearly eliminated 'the dip' and I get quite a bit better mpg too.
Old 01-11-2019, 07:48 AM   #335
atomicalex
Drives: 2018 BRZ Limited Perf Pack
WTZ85 - Subaru of America, Inc. (Subaru) is recalling 2018 model year Legacy, Outback, and BRZ vehicles equipped with a certain combination of head unit hardware and software, due to the possibility of noncompliance with Federal Motor Vehicle Safety Standard
Type: Recall | Service Campaign: WTZ85 | NHTSA Campaign: 18V-000000
Open
Recall Date: January 02, 2019
Description
18 LEG/OUT/BRZ V3 Head Unit Reprogram
Safety Risk
Due to a software issue, the head unit memory retrieval and assembly time may exceed the designed time to begin the boot-up cycle. If this occurs, the head unit display will not boot, causing the screen to remain blank. In this condition, while backing the vehicle, the rearview image may not be displayed. The failure to display the rearview image creates a noncompliance with the requirements of FMVSS 111 – “Rear Visibility,” increasing the risk of a crash.
Remedy
I'm guessing they will reprogram it? I will update when I get the recall completed.
edit - they reflashed the HU and now it boots faster. The ambient light sensor needed some time to recalibrate, that was annoying.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Old 01-27-2019, 10:00 AM   #336
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The following alludes to a 11-184-18 and a new version of the ECM software
http://www.ft86club.com/forums/showp...33&postcount=8
It's not out yet on Mitchell or Identifix and I need that sooo hard.
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 10:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-04-2012 11:45 PM
