Old 05-23-2018, 12:09 PM   #4705
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by MTCRX View Post
HAve you looked into SSC class. You are part way there with your setup and it looks like a popular and fun setup.
Edit: He has a 2017 car which isn't currently eligible for SSC.
He also needs the right dampers, springs, wheels, tires, camber kit, and swaybars. Basically he needs to buy almost everything, a roughly $3k investment.
The only thing he's bought that will carry over to SSC is the exhaust and brake pads.
And if I could start over in STX again, I'd budget $6k for parts and have money left over for nearly a season's worth of entry fees.
ineedyourdiddly
Old 05-23-2018, 12:46 PM   #4706
tony_r
tony_r's Avatar
Drives: '15 STX
Dont go STX unless you are willing to spend lots of money. And know that there are many great drivers in that class and competition is very very tough.
No. It's not as expensive to get into STX as anyone thinks. You don't need big brakes. You don't need a diff. You don't need race seats. You don't need a battery. You don't need a full exhaust. None of these will make you faster.
SSC all in is about $2700, STX all in can be as little as $4k. Shopping smart used will bring this down a lot. Biggest cost is coilovers and even those can be cheap.
tony_r is offline   Reply With Quote
The Following User Says Thank You to tony_r For This Useful Post:
smg1138 (05-23-2018)
Old 05-23-2018, 02:06 PM   #4707
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I made my budget for STX... It came out to over $16,000 and I already have the exhaust and front sway.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-23-2018, 03:31 PM   #4708
tony_r
tony_r's Avatar
Drives: '15 STX
That's ridiculous and unnecessary. Are you budgeting a new car too? There are entire STX prepped cars for sale for $18-20k.
My build is done and I've spent $3k, but I lucked out on used stuff. New it would be:
ProParts Megan coilovers - $1800
Whiteline 22mm - $200
Wheels and tires - $1200
Tomei Header - $600
HPS Intake tube and random panel filter - $150
OFT - $500
$4450 and that is literally all you need. Finding that stuff used or alternatives knocks off a few hundred bucks. Seriously what are you buying?
Old 05-23-2018, 04:22 PM   #4709
Blue Gumby
Drives: 2017 86
Question on TRD CS cars. From my understanding, TRD front and rear bar causes understeer. Why does it seems like everyone opt to run a smaller front bar rather then run a bigger rear bar?
Blue Gumby is offline   Reply With Quote
Old 05-23-2018, 05:25 PM   #4710
Locust
Custom User Title
Locust's Avatar
Tomei Header - $600
OFT - $500
Ridiculous and unnecessary is the fun part of racing
LOCUST
Instagram:
LocustAutoX
Sponsors:
The Following User Says Thank You to Locust For This Useful Post:
cjd (05-25-2018)
Old 05-23-2018, 06:14 PM   #4711
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I went with a softer front bar because I was concerned about the diff-assist that kicks in when you unload the inside tire in a turn. (With the long-press method) I never tested a stiffer rear bar though.
Twinz is offline   Reply With Quote
Old 05-25-2018, 09:19 PM   #4712
dutchman1
Drives: 2017 86 6-Speed
Tomei Header - $600
OFT - $500
Where did you wind up sitting with rear camber with that setup? Or do you also have a rear LCA?
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 08-22-2018, 03:11 PM   #4713
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
So true, I've been following the same formula all year and having a blast.
Lincoln Logs is offline   Reply With Quote
Old 10-10-2018, 08:18 PM   #4714
dpaqu
Drives: 2018 Gt86
AutX newb here. What are the chances the rules change for C Street for next year. I don't want to buy some 17x7.5 wheels and find out that I could have got 8" wide wheels.
dpaqu is offline   Reply With Quote
Old 10-10-2018, 08:39 PM   #4715
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Street classes require wheels sizes that are available as OEM equipment, the only leeway you get is the +/-1" diameter and minor offset allowances.
The twins are in DS, if you're in CS (I think the ts and TRD are the only CS orphans) you are already in the wrong class.
You won't be competitive for your first 2 years (at least) anyway, but the twins are not competitive in CS regardless.
14stu is offline   Reply With Quote
Old 10-11-2018, 07:22 AM   #4716
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
They won't change the width allowance for wheels next year (if at all). There's a process in which new rules get added to the rule book called "Fastrack" and they announce months/years ahead of time to garner feedback from the membership if they should/shouldn't go forward with it.
A rule change for wheel width has not been proposed, nor in the pipeline.
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 10-11-2018, 12:57 PM   #4717
nico_rsx
Drives: BRZ 2017 Pure Red, MT
If he has the performance package (Brembo + shocks + 7.5" wheels), then he's in CS.
nico_rsx is offline   Reply With Quote
Old 10-13-2018, 08:12 PM   #4718
86prime
Drives: 18 BRZ tS
This may have been said already but imo it's not fair that the PP and tS got pushed into CS where they aren't that competitive. The new ND may not get bumped (my assumption).
86prime is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
