Old 10-08-2018, 02:05 PM   #4705
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by mistople View Post
Is the C30 with the HBP a risky setup longer term? Using 96% of the unit's capacity has me worried for track use. I can't use the C38 since I don't have E85 and won't have a built engine.
It sounds like I can safely run the HBP on 92+ with the C30 when using an Ace header, but I still want to be sure I'm not placing unnecessary stress on the Rotrex unit.
You don't need E85 or a built engine to run the C38.
JDMChris is offline   Reply With Quote
Old 10-08-2018, 02:59 PM   #4706
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
I meant the C38 + HBP. I was recommended against it IIRC.
mistople is offline   Reply With Quote
Old 10-08-2018, 03:29 PM   #4707
kev0
Drives: '14
Is this SC reliable for 240HP? Don't want it to be racing fast, just want a little bit more oomph in my DD.
kev0 is offline   Reply With Quote
Old 10-08-2018, 04:02 PM   #4708
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
It's reliable well past 240. AFAIK with a carb tune not trying to push power you'll at least make 260s and that's about as conservative as it gets
Sent from my XT1650 using Tapatalk
Anderzz is offline   Reply With Quote
Old 10-08-2018, 04:08 PM   #4709
CSG Mike
CSG Mike's Avatar
rock solid reliable.
PM to order.
Old 10-10-2018, 05:32 PM   #4710
RFB
RFB's Avatar
Drives: FRS
Originally Posted by one2onejackpot View Post
Add me to the list of people who's included bypass valve has failed. I was getting a P0171 System Too Lean Bank 1 code because the bypass valve was sticking open. Jackson is sending me a replacement, but I may buy the Forge FMDV008 unit with green spring, to avoid any further issues.
The Forge FMDVOO8 is EXACTLY the recirculation valve my tuner replaced the Jackson one with, since the Jackson valve is plastic, with a bad seal that stuck open.
I noticed much nicer sound also with the Forge.
RFB is offline   Reply With Quote
Old 10-10-2018, 05:53 PM   #4711
mrg666
pessimistic skeptic
mrg666's Avatar
Do you mean that whistle sound when the open valve is recirculating? Otherwise, when the valve is closed for full boost, there is no sound from valve; all air is directed to manifold.
Old 10-10-2018, 05:57 PM   #4712
Anderzz
Anderzz's Avatar
I imagine, that's exactly what they're referring to. I have the Forge recirc as well and there is dramatic and very noticeable turbo flutter with it.
The Following User Says Thank You to Anderzz For This Useful Post:
mrg666 (10-10-2018)
Old 10-10-2018, 05:59 PM   #4713
mrg666
pessimistic skeptic
mrg666's Avatar
Ok, I understand now. Thanks!
Edit: Be careful to make sure that flutter sound is not surge to avoid ruining the compressor.
Old 10-11-2018, 10:40 PM   #4714
drm
Sad day... JRSC dieing
5 wonderful years, 23K miles.... but looks like it's over.
1 week ago, started to sound like this, and it is getting worse very quickly:
Originally Posted by idkwhatimdoing View Post
Stethoscope on unit sounds pretty "grindy". 1 oil change maintenance a year and a half ago (and no, i did not get low on fluid at any point).
At this point, thinking to just buy a new C30 unit, but obviously am a little gun shy. Thoughts?
drm is offline   Reply With Quote
The Following User Says Thank You to drm For This Useful Post:
Bonburner (10-12-2018)
Old 10-12-2018, 01:21 AM   #4715
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
ouch .. something break through your air filter and ding up your SC?
Old 10-12-2018, 10:35 AM   #4716
drm
It sounds like bearing failure, so probably not. I was just surprised because that sort of thing normally happens early on, or if you do something stupid like let the oil get low.
Old 10-12-2018, 01:02 PM   #4717
GrabTheWheel
Drives: 16' BRZ
Reliable is a relative term. Anyone buying this kit should keep in mind that these superchargers are not rebuildable and Rotrex is located overseas. When my first Rotrex failed after 3 months I knew it would be covered under warranty and did not want to wait for my warranty claim to be processed. This involves sending the the blower to Europe for inspection. Normally this is a 4-6 week process minimum I believe. Instead I forked over money for a replacement blower but still somehow waited well over 2 months to get a new Rotrex C38. I was eventually refunded under warranty. Hopefully my experience was a rare one. I have since moved on from the Jackson kit. I think Jackson Racing is a great company just wish they would use someone else for their blowers though. Preferably a company based in America that makes units that are rebuildable...
GrabTheWheel is offline   Reply With Quote
The Following User Says Thank You to GrabTheWheel For This Useful Post:
drm (10-12-2018)
Old 10-13-2018, 02:39 PM   #4718
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
My experience is that the wait for warranty, rebuild, etc with Vortech is the same.
Sleepless is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
