Old 10-06-2018, 06:29 AM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Creaking noise coming from the rear
Hello guys,
I've been getting a small creaking noise at the rear of the car for a while, which happens when driving over rough surfaces or when the body flexes.
I've tried securing every loose bit of wiring in the trunk, putting some cloth where the rear seat meets the parcel shelf, putting some electrician tape around the rear seat latches, but none of this has brought any improvement.
As far as I can hear, this noise seems to be coming from the inside of the trunk, and may be reduced when driving with stuff inside the car, so maybe something under the trunk's floor?
Any ideas?
Alex
alex87f is offline   Reply With Quote
Old 10-06-2018, 08:20 AM   #2
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
http://www.ft86club.com/forums/showthread.php?t=13451
Could it be something relating to ^ this issue? It drove me nuts for the first few months until I had it fixed. It's much better. A little bit of noise still persists, but I think it's from the leather on the bottom of the rear seat back rubbing on that of the rear seat bottoms.
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
Tcoat (10-06-2018)
Old 10-06-2018, 11:26 AM   #3
jcb476
Release 10 Series
jcb476's Avatar
Drives: 2013 10 Series FR-S #1874
I've noticed a creaking noise as well from what appears to be coming from the rear when the car flexes during certain types of cornering. Can't for certain which side it comes from. It's not a popping or clicking sound. It doesn't appear to be a metalic sound as much as a plastic or some other material rubbing together. It doesn't happen when driving down the road, just only on certain cornering or coming down at angle off of driveway curbing. And no...it's not from bottoming out.
jcb476 is offline   Reply With Quote
Old 10-06-2018, 11:44 AM   #4
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I had wiring in the trunk lid rattling around. Lighing and camera cable.
PetrolioBenzina is offline   Reply With Quote
Old 10-06-2018, 03:42 PM   #5
Decep
Drives: 2013 FR-S Series 10
Check the TSBs , there is one for this.
Old 10-06-2018, 04:07 PM   #6
highway7
Drives: FRS 2013
It's most likely from the rear deck, occurs during winter months due to plastic being harder
highway7 is offline   Reply With Quote
Old 10-06-2018, 06:40 PM   #7
jcb476
Release 10 Series
jcb476's Avatar
Sorry if this is a noob question, but where does one go to find the TSBs?
Old 10-06-2018, 07:14 PM   #8
Decep
First thread at the top of the Issues/Warranty/Recalls subforum
Old 10-08-2018, 07:11 AM   #9
alex87f
Meow
alex87f's Avatar
It sounds quite similar indeed!
I almost thought I had it as I found out the gas cap release cable was making a creak when moved by hand, but relocating that cable had no influence whatsoever on the sound.
After a bit of messing around, I can say for certain that:
-it's coming from inside the trunk (moving the backseat up or down has no influence on it)
-it's somewhere around the center
Here's a recording of the noise I just made, you can hear it at 6" and 16":
In that case I was causing it by driving part of the car over a raise on a curb, which caused the body to flex. But it also happen when driving over rough surfaces or imperfections.
Old 10-08-2018, 11:47 AM   #10
Gunman
Drives: 2019 Mazda Miata RF
If its not the deck spot welds, it could be the seat latches. Mine rattle from time to time, so I release the rear seat, and relatch it.
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
Creaking noise from overpipe sydious Engine, Exhaust, Transmission 4 06-27-2018 02:13 AM
creaking noise front end of suspension gtzany Scion FR-S / Toyota 86 GT86 General Forum 5 12-10-2014 01:36 PM
Help! New Fortune Auto 500's creaking right rear. mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-15-2014 04:59 PM
Creaking/Clinking Noise from Driver Side Touge86 Issues | Warranty | Recalls / TSB 17 08-17-2013 08:20 PM
