Old 08-21-2018, 01:11 PM   #57
PuslarBrrrz
Originally Posted by Scala View Post
Please explain the "proper tune". I could be interested but as a stand alone without any other modifications and only if an Ecutek License,Tune and Dyno is not required.
Thank you.
OFT has/had tunes designed around the BPB. Without, the drop off in the upper rpm is dramatic. With the tune it helps to gain back and flatten out the power at 6500-7200rpm.
PuslarBrrrz is offline   Reply With Quote
Old 08-21-2018, 04:37 PM   #58
Scala
Drives: 2018 BRZ tS
Thanks. Indeed the OFT was an affordable alternative for lower complexity tuning.
Scala is offline   Reply With Quote
Old 10-04-2018, 12:47 AM   #59
BOND007_LTK
Drives: 2013 brz
So I got the OFT, then the crawford power blocks, and now I have gruppes UEL catless, all of which were tuned for the appropriate mod.
The last addition of the catless, I don't think it was as significant as increase as the BPB. THE BPB were a significant difference.
Of course, arguably, the header + OFT would be a significant difference from the OFT itself. That being said, maybe BPB and headers together don't make too much a difference, maybe someone can chime in?
Either way, BPB with OFT was pretty good.
BOND007_LTK is offline   Reply With Quote
Old 10-04-2018, 09:54 AM   #60
bfrank1972
Drives: 2013 FR-S Argento
Hmmm interesting. I did this:
OFT 93 tune for stock header - pretty noticable difference in smoothness, tip in throttle 'aggressiveness', and a nice but subtle bump in power
OFT stage 2 93 tune + P&L catted EL 4-1 header - a pretty big difference in power, both in delivery and quantity, over just the OFT. Got rid of torque dip and provided a nice bump in torque 3500-5000 and then again 6500+. BUT it took a few drives for it to really feel good in day to day driving. ECU needs to adjust.
just recently, added BPB to the above combo, with timing mods per Shiv's post, first driving I noticed a small difference but was a little disappointed (also had someone riding in car with me). But over next couple of days as ECU re-adjusted for part throttle etc. I noticed a pretty significant difference - not quite as much as adding the headers but a good jump. Car feels more urgent now 3000+ and around 5500+ you get a nice surge toward redline. I don't even really notice any drop-off past 7000.
Not sure how long you've been driving this setup, but drive it around a bit and see if it improves. Other factors can influence as well, like temperature, added weight from passengers, or even your mood
Also it's possible you may be able to optimize cam/ignition timing a bit for your combo, but unless you know what you're doing with that, it would require a custom tune (from Shiv, who is hard to get a hold of these days I think).
Lastly headers, especially UEL, really shine in the low end. You shouldn't have much of a torque dip at this point, and you probably won't experience quite the gains in the upper mid RPM that you felt with the BPB's. But you should feel a significant bump in the lower mid RPM band (3000-5000).
Old 10-04-2018, 10:54 AM   #61
FRS Justin
Drives: 2013 Asphalt FRS
Delicious Tuning did a write up on this a few years ago complete with dyno numbers.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
bfrank1972 (10-04-2018)
Old 10-04-2018, 11:39 AM   #62
bfrank1972
Yup - I think there are a few threads from reputable tuners on here somewhere. Shiv definitely did one. Mike from Moto East did a test as well. Just do a google search if you're interested and they'll come up. Moto Mike's test really convinced me - and after some driving I definitely feel the changes (installed last weekend). Definitely worth considering if you are NA, not worth it if you are FI (or going that way).
How to install Crawford Performance Billet Power Blocks (video?) Mr. DIY (Do-It-Yourself) Guides 51 09-08-2019 08:10 PM
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) nelsmar Engine, Exhaust, Transmission 295 08-25-2018 04:19 PM
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 08:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
***VISHNU*** Crawford Billet Power Blocks: +19HP +15TQ Garrett@Openflash Engine, Exhaust, Bolt-Ons 34 06-11-2014 07:28 PM
