View Poll Results: Which Tire?
Hankook Ventus V12 Evo2 13 33.33%
Falken Azenis FK510 11 28.21%
General G-MAX RS 5 12.82%
Other, please post the tire and why? 10 25.64%
Voters: 39. You may not vote on this poll
Old 09-23-2018, 02:39 PM   #43
Originally Posted by malubawla View Post
Send the little extra and get the Indy 500
I'm not nice to my daily tires and I can't keep buying others' hand-me-down wheels. Would you still suggest the same for me?
Leonardo (09-23-2018)
Old 09-24-2018, 02:36 PM   #44
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
idk based on that TireRack test and your location (wet) I'd be looking at the Falkens or Conti's, both a touch cheaper than the Firestone, both supposedly better in the wet, only marginally behind in the dry.
https://www.tirerack.com/tires/tests...y.jsp?ttid=235
Edit: linked wrong test, fixed
ineedyourdiddly
Ultramaroon (09-24-2018)
Old 09-24-2018, 04:24 PM   #45
I'm probably putting WAY too much thought into it. I bet I'd be happy with any of them.
edit: fixed quoted link because I care that much.
strat61caster (09-24-2018)
Old 09-24-2018, 05:10 PM   #46
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
https://www.tirerack.com/tires/tests...y.jsp?ttid=234
Did you mean to link the EXTREME performance summer tires?
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 09-24-2018, 05:11 PM   #47
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
well you never know when you need that emergency braking in the wet.
plus higher grip theshold just means easier time driving in various conditions.
But I do find DarkPira7e's post interesting to read:
Originally Posted by DarkPira7e View Post
Vehicle was a 1993 325i, climate was Vermont summer into fall, so temps between 80 and 30, a lot of rain. Winters go on before snow hits.
I found that the Fallen tires had a very hard time remaining compliant on adverse road conditions much more so than the Hankooks tires. On damp roads with a bit of dirt strewn across (an intersection for example) the Falkens gave way under acceleration while turning marginally sooner than the Hankooks tires did. The compound might be harder, my tire pressures were consistent (I tend to run 30psi rear, 32 front until I have time to test different pressures) but I can say in all wet conditions, the Hankooks was more trustworthy. I'm not talking about me trying to drift or autocross; just driving spirited to find the thresholds of the tires.
I'm not at all claiming to be a scientist, but I have been running the Hankooks on my wife's car and enjoy that same safe feeling in the rain. They're far more tolerant of cold pavement as well than the Falkens. The Falkens didn't seem to have much more dry grip to offer, certainly not enough to warrant the purchase on a car that would not see autocross or track duty.
Edit: had the Falkens on for about 5 months, maybe 4800 miles. I bought the Hankooks the following spring and gave the Falkens to a friend who needed them. Ran the Hankooks off and on for a couple years, I swapped wheels/tires for when I wanted grip. For what it's worth, neither tire held a candle to the Dunlop Direzza StarSpec Z1.. this was also around 2011. Last 4 years on Hankooks on my wife's car have been great, so that experience is relevant
It really throws a screw in the picture
Old 09-24-2018, 05:28 PM   #48
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If it makes you feel any better, my account is fairly old. For daily driving tires, I think any of them would be great. It's not like they'd still be around if they actually were " terrible". Make sure to keep your intended use in mind. nobody should expect flesh tearing lateral G on any surface other than on ice with ice racing tires, or on pure pavement with dedicated track tires.
tl;dr, any of these would be great in my opinion. Use them for what you're buying them for and none of them will let you down.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
JonAvalon (09-24-2018), strat61caster (09-24-2018), Ultramaroon (09-24-2018)
Old 09-24-2018, 06:14 PM   #49
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Sure. I'm boosted with over 400whp and still have enough grip.
malubawla is offline   Reply With Quote
The Following User Says Thank You to malubawla For This Useful Post:
Old 09-24-2018, 07:03 PM   #50
Impureclient
Drives: 2015 FR-S
I echo going for the Firehawk Indy 500s. I'm barely getting into the tread at 1.5 years later and I do not go easy on my tires at all. To be fair,
I only roughly put on 4k miles on the car a year but at 2 years in(My 8k for 2 years + prior owner 4k, so 12k total) with the MPSS they were toast and sliding all over.
At the rate the Indy 500s are going, I think they'll outlast those prior tires I had by triple and probably much more. And they'll do so with providing better
grip by far in both dry and wet. They were a steal at the price we all got them for months ago and now that they increased the prices about 20% more, they're still a bargain for what they are.
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
chaoskaze (10-04-2018), Ultramaroon (09-24-2018)
Old 09-24-2018, 07:18 PM   #51
strat61caster
I'm NA with 245 RE71R Bridgestones and it's not enough grip...
ineedyourdiddly
Old 09-24-2018, 07:51 PM   #52
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
wow, how fast are you trying to go around corners?
Old 09-24-2018, 08:10 PM   #53
86MLR
86MLR's Avatar
Tyre size and camber are things you need to consider.
To much camber is a big issue.
You need to look at how your car is using the contact patch.
They little triangle wear indicators are there for a resson.
Old 09-24-2018, 08:58 PM   #54
strat61caster
As fast as physically possible*, if I didn't want to do that I wouldn't have bought a sports car or good tires.
*Not on public roads of course
I was still getting noticeable outer edge wear at -4 degrees up front, the cars faster than me are in the -3.5 to -4.5 range, but I'm being silly, it's not the tires fault, it's the stupid driver/mechanic and I'll be changing my suspension setup soon to improve the situation.
And that is not the purpose of the triangles, those exist to indicate where the wear bars are.
https://www.yokohama-online.com/Tyre...Tyre-Knowledge
But we're way off topic now, my apologies for being snarky.
ineedyourdiddly
Old 09-24-2018, 11:34 PM   #55
86MLR
86MLR's Avatar
I have been told to use them for not only tread depth but also as an indicator IRT setting camber and tyre pressures
If you have wear on or past the triangle add camber/psi
If your rear is not near the triangle remove camber/psi.
From talking to some tyre guys at the track and tech nights, you want your tyres to show signs of wear close to or at the tip of the triangle.
This is a rule of thumb guide if you don't have a pyro gauge.
It has been working well for me for years
Found a linky with pics that describes it better.
http://www.trackdayguru.com/tyre-management.html
The Following User Says Thank You to 86MLR For This Useful Post:
chaoskaze (09-25-2018)
Looking to buy Frs 20k budget nelsonzep Want-To-Buy Requests 0 05-26-2016 03:04 AM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
If you were to pick a used "High end" Sports car what would you pick? Atropine Other Vehicles & General Automotive Discussions 133 08-02-2014 02:00 AM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
