Old 09-22-2018, 05:44 PM   #1
Idaho-FRS
Drives: Stock FRS
Question Impreza top hots???
Just got a set of tein street basis z coil overs, they require you to use your own top hats. I have a friend who would be willing to sell me his camber plates off of his 2002 wrx but he does not want to take them apart if the won't work. I'd prefer to save some and buy his if I could instead of waiting for new one to ship to me. Does anyone know if they're interchangeable like forester and impreza suspension?
Idaho-FRS is offline   Reply With Quote
Old 09-22-2018, 10:22 PM   #2
wparsons
wparsons's Avatar
I forget the year crossover, but our upper mounts are 100% compatible with some year range WRX's. I'm running the STI Group N mounts on my car up front.
flickr
Leonardo (09-22-2018)
Old 09-23-2018, 01:23 AM   #3
Idaho-FRS
Drives: Stock FRS
Ok sweet, that will save me enough to get beer this weekend too!
Old 09-23-2018, 08:48 AM   #4
wparsons
wparsons's Avatar
Make sure you look up which model years work... not sure if a 2002 is compatible.
flickr
Old 09-23-2018, 09:40 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Front group-n topmounts can be found on both ft86sf & japanparts. Subaru P/N:ST2031055000 if searching in other shops
Old 09-23-2018, 09:08 PM   #6
wparsons
wparsons's Avatar
He's wanting to get camber plates from his friends' 2002 WRX and looking to know if they work for FRS/BRZ.
flickr
Old 09-24-2018, 12:55 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Oh. Should be more careful with reading.
Well, if going by that japanparts listing:
    • Impreza WRX/STi 2006-07 GD/GG F-G Hawk Eye
    • Impreza WRX/STi 2003-04 GD/GG C-D Blob Eye
    • Forester SG 2002-07 A-F
    • Impreza WRX/STi 2005 GD/GG E Blob Eye
    • Impreza WRX/STi 2001-02 GD/GG A-B Bug Eye
    • Forester SF 1997-02 A-D
    • Impreza WRX/STi 1992-00 GC/GF A-G
    • Legacy 1993-98 BD/BG A-C Liberty
    • Legacy 1998-03 BE/BH A-D Liberty
  • Compatible with:
  • GD/GG / GC/GF BH/BE BG/BD SF SG
That also hints some about compatibility of subbie front mounts in general.
I guess it might be not so well interchangeable with rear top mounts, as our have two bolt mounts, but many subies of that time IIRC had three bolt ones, and of more shapes/sizes.
Old 09-24-2018, 02:11 AM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes older Subaru had rear strut suspension, not multi link, so they needed the third bolt... Also meant that they could use rear camber plates to get it aligned, although it looks like bolts and lcas were easier.
Just interesting for people like me who didn't know much about older Subarus.
ineedyourdiddly
Racecomp Engineering (09-24-2018)
Old 09-24-2018, 10:33 AM   #9
Back when STI red was pink! (or cherry blossom red)
- Andrew
wparsons (09-25-2018)
Old 09-24-2018, 10:48 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Hello Kitty STI?
Old 09-24-2018, 10:50 AM   #11
Hello Kitty STI?
It's funny, everybody wanted pink STI parts all over their car back in those days.
To the OP, just be sure to check the camber plates for play in the bearing before putting them on. Remember camber plates aren't necessarily the best choice for every driver.
- Andrew
Shark_Bait88 (09-26-2018), wparsons (09-25-2018)
Old 09-24-2018, 11:42 AM   #12
jamal
jamal's Avatar
Drives: Legacy GT
The following cars use the same oem front top mounts that are the same pattern as the BRZ:
90-04 Legacy /outback
93-07 Impreza
98-08 Forester
After those last years, the top hats got bigger in overall diameter.
Front mounts (and front only) from all those cars should bolt into the chassis and fit the strut, however there is one thing that differs and that's the rotation of the holes in the strut tower. Going from, say, 1st gen to 2nd gen impreza (93-01 vs 02-07), the tops are rotated differently.
So they could end up like this depending on what the mounts came from:
Which is actually not always a bad thing because usually you don't need the plate all the way to the max negative camber setting and having them at an angle lets you add caster too. When I install coilovers/camber plates I almost always put them in at an angle for extra caster, set the adjustment all the way in and back, and fix cross camber at the lower bolt.
jamal is offline   Reply With Quote
Old 09-26-2018, 12:50 PM   #13
.Kyle
Drives: it's grey
The 02-07 Upper mount will work. Make sure it is a spherical bearing type since the strut angle is far different on this chassis. It will eat a standard bearing up that hasn't had it's angle adjusted in a few thousand miles.
Camber plates that are designed for this chassis are based off the stock strut angle and will work better than a GD/GG part.
.Kyle is offline   Reply With Quote
Old 09-26-2018, 01:50 PM   #14
jamal
jamal's Avatar
Drives: Legacy GT
Is the OEM frs/brz top directional and/or is the bearing set at an angle?
coil over, lowered, noob, suspension, top hat
New Impreza with FB25 GTLegend Other Vehicles & General Automotive Discussions 1 02-07-2014 05:24 PM
FR-S/BRZ VS. Impreza 2.5RS Alex FR-S / BRZ vs.... 9 08-27-2012 10:42 AM
3.3 H6 Impreza RS Starscream15 Off-Topic Lounge [WARNING: NO POLITICS] 0 07-10-2012 05:31 PM
Why not an Impreza or a WRX? slizoth BRZ First-Gen (2012+) — General Topics 137 04-08-2012 12:45 PM
