Old 09-20-2018, 02:21 PM   #1
StraightOuttaCanadaEh
Wes
Pentosin MTF has been discontinued
And I was just about to try it, having heard the good reviews. Just wanted to share in case anyone else wants to stock up on remaining units sitting around somewhere. I can't find any here in toronto
Instagram: @gt86ws
Old 09-20-2018, 03:55 PM   #2
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Give Synchrotech's, Mady by Torco, MTF a shot. Absolutely loved it in my built trans.
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
rice_classic (10-11-2018)
Old 09-20-2018, 04:32 PM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I just want to throw in that their oil is not 75W90, its between 0W30-0W20** viscosity.
So use at your own risk.
If you want to stick to the manufacturer's suggested specs .. Motul 300 is a solid choice.
Edit: ** that's engine oil ratings, forgot that transmission fluid ratings are a little different. Synchrotech is between Pentosin MTF-2 and OEM specs in terms of viscocity rating FYI.
Old 09-20-2018, 04:38 PM   #4
VerusEric
VerusEric's Avatar
Originally Posted by Bonburner View Post
I just want to throw in that their oil is not 75W90, its between 0W30-0W20 viscosity.
I assumed OP knew this as he was looking at Pentosin MTF. I had no ill effects after 6k miles (granted not a lot) other than better shifting.
I'll be trying it in some other transmissions as well.
100% agreed though, this is *not* a weight recommended by OEMs. Use at your own risk.
Thanks,
Eric
Bonburner (09-20-2018)
Old 09-20-2018, 05:55 PM   #5
Wes
While personally for me motul is better than OEM, it wasn't that much better. And becomes less smooth as time goes on. It's only been about 8 months and it feels almost oem.
Instagram: @gt86ws
Old 09-20-2018, 06:23 PM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
seeing as you're toronto .. I'm not surprised it's been getting notchier lately as the temperatures drop
Old 09-20-2018, 06:28 PM   #7
Wes
Could be, so I'm hoping to change it out in october and have it somewhat better. Still won't be as bad as oem, even in below zero. Just a shame cause I was really looking forward to trying pentosin and now I can't. That other brand I don't think is available in canada.
Instagram: @gt86ws
Old 09-20-2018, 06:33 PM   #8
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
well you can venture outside the suggested specs since its pretty cold up there ... or you could just venture into new york and use one of those amazon pick up sites or something along those lines hahaha
Old 09-21-2018, 03:09 PM   #9
chipmunk
Drives: _
Had Pentosin for about 12k miles, but the dealer changed it to Subaru OEM transmission fluid recently while doing warranty work. Pentosin was GL4. Subaru gear oil is GL5. I'm gonna leave it in and see what happens. Not sure if I should believe in the whole GL5 vs yellow metals argument...
chipmunk is offline   Reply With Quote
Old 09-21-2018, 04:15 PM   #10
chipmunk
Drives: _
Just beware that this guy's smile is a little creepy...
[ame]https://m.youtube.com/watch?v=XHwULF-EdtQ[/ame]
The Following 2 Users Say Thank You to chipmunk For This Useful Post:
Bonburner (09-22-2018), Sportsguy83 (10-06-2018)
Old 10-10-2018, 10:28 PM   #11
BOND007_LTK
Drives: 2013 brz
And how does it compare to the Pentosin. The general consensus at least in Canada where it's cold is that Pentosin MTF-2 75w80 is the best for cold weathers - and it's really smooth. Higher and longer lasting session is another story of course and questionable.
BOND007_LTK is offline   Reply With Quote
Old 10-10-2018, 10:29 PM   #12
BOND007_LTK
Drives: 2013 brz
Also can't find it in Toronto...
Old 10-11-2018, 07:26 AM   #13
cueball89
Drives: 15 Impreza
Red Line sells 70w/75, 75w-80, 75w-85 and 75w-90 GL4 gear oil.
https://www.redlineoil.com/gear-oil-...-transmissions
cueball89 is offline   Reply With Quote
Old 10-11-2018, 07:52 AM   #14
n0thing
Drives: Subaru BRZ
Try contacting Ivan at igarage, that's where I got mine.
n0thing is offline   Reply With Quote
Pentosin FFL-4 vs MTF2 takethecake Engine, Exhaust, Transmission 0 08-02-2017 12:04 PM
Pentosin MTF2 Calum Engine, Exhaust, Transmission 10 12-09-2014 07:43 PM
Is this the right Pentosin mtf-2 Raven604 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-09-2014 09:58 PM
Looking for Pentosin MTF-2 in Ontario? wtout86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-26-2012 07:07 PM
