Old 09-19-2018, 10:06 PM   #15
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
certain coil over companies make air lifts for the front only for this type of issue..but that's an expensive route to go.
maybe get some steel plates you can put down that don't block waterflow?
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 09-20-2018, 01:24 AM   #16
F14Scott
F14Scott's Avatar
Drives:
That's not a bad idea.
Sent from my SM-G965U using Tapatalk
F14Scott is offline   Reply With Quote
The Following User Says Thank You to F14Scott For This Useful Post:
JeremyR (09-20-2018)
Old 09-20-2018, 02:19 AM   #17
86MLR
86MLR's Avatar
Just be wary if your going that path.
The clearance with air cups is a issue I believe, they install them on a Supra, but there's more clearance with them.
They talk about them here for a bit at 1:30
Old 09-20-2018, 02:33 AM   #18
F14Scott
F14Scott's Avatar
Drives:
I actually was talking about the steel plates. Good info, though.
Old 09-20-2018, 03:24 AM   #19
JD001
JD001's Avatar
Drives: Subaru BRZ
Move.
Old 09-20-2018, 08:34 AM   #20
markitect
Drives: Scion FRS
I use ISC Surface Guard Tape on the front/bottom surface of my bumper. If you scrape bad enough it will get pulled off, but gives pretty good overall protection.
markitect is offline   Reply With Quote
Old 09-20-2018, 02:07 PM   #21
JeremyR
JeremyR's Avatar
Maybe some of your neighbors are having the same issue and you could pool funds
The Following User Says Thank You to JeremyR For This Useful Post:
Ganthrithor (09-23-2018)
Old 09-20-2018, 02:21 PM   #22
Works as long as you are not someplace that gets snow. One snowplow pass and things could go horribly, horribly wrong in a hurry.
Old 09-20-2018, 02:46 PM   #23
tobin
tobin's Avatar
Drives: '13 BRZ
I've had good results with this stuff http://www.aquaphalt.com
I always scraped at the end of my driveway at anything over a very slow roll. I filled in the dip with this stuff, and it's fine now —*I can coast through in second gear if I want. I used my pressure washer to clear all the dirt out of the dip, then filled with this stuff.
tobin is offline   Reply With Quote
Old 09-20-2018, 03:02 PM   #24
Many municipalities frown upon you filling in the gutters though.
Old 09-20-2018, 05:52 PM   #25
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Maybe I'll get a lift kit...
just remove the junk from the trunk and the rear seat and the car will be lifted enough.
Or just buy a can of plasti dip and apply as necessary. It should protect the bottom enough.
why? is offline   Reply With Quote
Old 09-21-2018, 02:03 PM   #26
ChanceSkeleton
Drives: 2016 Subaru BRZ Sport tech
I have the same issue. It's on the bottom of the car so no one sees it, so I've learned to just live with it. Besides, it's just plastic.
ChanceSkeleton is offline   Reply With Quote
Old 09-22-2018, 12:28 PM   #27
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Any weight removed from behind the rear wheels is going to lower the front.
I actually passed on an otherwise nice house because I scraped my FRS bumper on the driveway lip. That damage still makes me sad every time I change the oil....
Old 09-23-2018, 11:01 PM   #28
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
https://www.ft86club.com/forums/showthread.php?t=105692
Ganthrithor is offline   Reply With Quote
driveway scraping Toyarzee Scion FR-S / Toyota 86 GT86 General Forum 54 01-20-2015 07:18 AM
Clutch scraping noise 8 six Scion FR-S / Toyota 86 GT86 General Forum 31 01-05-2015 02:39 PM
Never trAcked my car Nd looking forward to it...help?!? Jonoraven93 Southeast 16 11-08-2013 04:11 PM
Lowered on coils- scraping Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-04-2013 04:41 PM
Protective Guard for Front Bumper from scraping? JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 4 02-17-2013 08:16 AM
