Old 09-19-2018, 06:23 PM   #1
F14Scott
F14Scott's Avatar
Drives:
Scraping my forward bumper. Solutions?
My driveway has a dip where it meets the street, and no matter how slowly I drive, I scuff the two nose points.
Anyone have any luck with bolt on lips or dams that can take the scuffs more gracefully than the car, itself? At some point, I may pour some more concrete, but until then, I want to minimize damage.
Sent from my SM-G965U using Tapatalk
F14Scott is offline   Reply With Quote
Old 09-19-2018, 06:28 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
is it possible to approach the dip at an angle?
HKz is offline   Reply With Quote
Old 09-19-2018, 06:29 PM   #3
wild03
Drives: Silver 2017 Limited with PP
Hmm? can you enter the dip at an angle? can you fill it with dirt or sand for now?
wild03 is offline   Reply With Quote
Old 09-19-2018, 06:34 PM   #4
Chikna
Drives: 2018 BRZ TS 244/500
Good idea, I too scrapped tS twice and now I do a reverse at an angle and park slowly (1st gear) in my driveway. By the way, I practiced hill start here.
Chikna is offline   Reply With Quote
The Following User Says Thank You to Chikna For This Useful Post:
HKz (09-19-2018)
Old 09-19-2018, 06:41 PM   #5
86MLR
86MLR's Avatar
Maybe 2 bits of timber, they only need to be 200mm wide and as long and high as you need.
Watch leaving anything permanent for liability sake.
And dirt or sand may cause issues with local council, or wash away the first time it rains.
Old 09-19-2018, 06:43 PM   #6
arkanist
Drives: 2016 BRZ Limited, Stock
You could always get a cheap lip kit like the baysonR sti lip. It's under $100 and will keep your bumper protected. Otherwise you are gonna want to hit it at an angle like everyone else is saying.
arkanist is offline   Reply With Quote
Old 09-19-2018, 06:46 PM   #7
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
You could try a ProTEK skid plate, dont know how high up on those points your scraping at
http://www.protektskidplates.com/
VIP BRZ is offline   Reply With Quote
Old 09-19-2018, 06:48 PM   #8
If you can't get a good approach angle a lip will just increase your issues not solve them. By extending the bumper down and forward you reduce your clearance even more. Best case scenario you just rip the lip off. Worst case it hold and breaks the bumper clips creating sag.
The bottom of my bumper is worn down from scrapping but it can't be seen so I just live with it.
Brink (09-24-2018), Ganthrithor (09-23-2018), korhun (06-26-2019), Leonardo (09-20-2018)
Old 09-19-2018, 08:17 PM   #9
F14Scott
F14Scott's Avatar
Drives:
Thanks all. I'm backing through an iron gate flanked by two brick columns. I live in a downtown neighborhood with street parking, so my driveway gets other street-parked cars right up to the edge, so angling in is unavailable, most of the time. It rains so much here in Houston that sand or gravelwould just be washed away, and the boards would be a trip hazard that I don't want to be liable for.
I understand that adding material will only make it scrape more, but at least it would be a consumable scrape vice a permanent one.
I'll look into the mentioned dam. Thanks again.
The Following User Says Thank You to F14Scott For This Useful Post:
Tcoat (09-19-2018)
Old 09-19-2018, 08:23 PM   #10
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
go in backwards thats how i have to get into my friends driveway
Breadman is offline   Reply With Quote
Old 09-19-2018, 08:30 PM   #11
Be OK if the lip just wore away but the extra pressure on the bumper which it attached to could cause some serious damage under the wrong circumstances. The attachment points on these bumpers are not great.
Old 09-19-2018, 08:37 PM   #12
F14Scott
F14Scott's Avatar
Drives:
Maybe I'll get a lift kit...
Tcoat (09-19-2018)
Old 09-19-2018, 08:49 PM   #13
Clutch
Clutch's Avatar
Drives: 2018 Subaru BRZ Limited (Silver)
Same problem as OP at my new place. This is my life now
Clutch is offline   Reply With Quote
Old 09-19-2018, 08:53 PM   #14
Go big!
Adam_L (09-24-2018), korhun (06-26-2019)
driveway scraping Toyarzee Scion FR-S / Toyota 86 GT86 General Forum 54 01-20-2015 07:18 AM
Clutch scraping noise 8 six Scion FR-S / Toyota 86 GT86 General Forum 31 01-05-2015 02:39 PM
Never trAcked my car Nd looking forward to it...help?!? Jonoraven93 Southeast 16 11-08-2013 04:11 PM
Lowered on coils- scraping Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-04-2013 04:41 PM
Protective Guard for Front Bumper from scraping? JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 4 02-17-2013 08:16 AM
