Old 09-15-2018, 08:25 AM   #1
STIMAN
Drives: 2015 Asphalt FR-S
Remote Lock/Unlock Issues
I'm having persistent remote lock/unlock issues with my 2015 FRS. I've tried searching the forums and I wasn't able to find anything that quite matched my issues. There are two threads I found, one is for keyless start only, and the other had no resolution.
About 99% of the time I try and unlock the car with my key fob, I get no response. And about 70% of the time I go to lock the car after I've gotten out and am leaving, I get no response. In most cases, I need to repeatedly press lock/unlock buttons (from 5-30 times) until I get a response from the car.
**The strangest part, and what makes me think it's the car's receiving end that is the issue, is that if I come to my car and unlock it with the key (WITHOUT attempting to unlock with the key remote), and I press the truck open button (the dash button, not the remote button), the button doesn't work (nothing happens).
TLDR / Notes:
- Car wont lock/unlock with remote
- 5-30 repeated lock/unlock presses eventually gets response from car and locks/unlocks the car.
- New batteries doesn't help or improve the situation
- Both key fobs do the same thing
- Issue is worse in cold weather
- Car does not have push start
STIMAN is offline   Reply With Quote
Old 09-15-2018, 02:03 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Try holding it, it's not designed to be a push but a short hold so you can't accidentally open it. The same is true of the remote.
TLDR / Notes:
How good is the car battery?
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-15-2018, 02:48 PM   #3
STIMAN
I do know about the requirement to hold the truck release button. Still it's unresponsive as described.
As for the battery, I'm not sure how good my battery is. Is it be possible for a 2015 battery to be getting bad by now? I'll look into that. Thank you.
Old 09-15-2018, 03:18 PM   #4
If your car starts up strong, the battery is most likely OK.
When you push the remote button, are you pointing the remote towards the car?
Old 09-15-2018, 05:07 PM   #5
STIMAN
Yeah, tried everything; pointing at the car, pointing away, pointing up, holding button, quick bursts... No response until after a bunch of tries it just starts working, and it's then good until I arrive at my destination. Then it often gives me trouble locking up again.
Old 09-15-2018, 06:08 PM   #6
teddale
Drives: 2017 86 special edition
How about the remote battery
teddale is offline   Reply With Quote
Old 09-15-2018, 07:15 PM   #7
The OP mentioned he has new remote batteries. However, it might be good to clean the contacts with a bit of alcohol -
Old 09-28-2018, 02:17 PM   #8
7c8
I have this same issue as you. I believe it is also something with the receiving end on the car. The fob battery contacts are clean but I've been through 3 batteries with this problem still persisting.
7c8 is offline   Reply With Quote
Old 09-28-2018, 02:22 PM   #9
STIMAN
Well, glad I'm not the only one.
I plan on scheduling an appointment with the dealership soon to get this look at. I will post my results here when I get to the bottom of this.
The main reason I wanted to start this thread is to help others who may have the same problem.
The Following User Says Thank You to STIMAN For This Useful Post:
winstonscifi (07-23-2020)
Old 09-28-2018, 02:50 PM   #10
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
Please keep us posted on what the solution was. I've had this issue on my driver's side, but from what I dug up on the forums, it might be built up gunk physically blocking the lock from moving rather than any communication issue between the car and remote. Not sure if that's what you're experiencing.
Beachin86 is offline   Reply With Quote
Old 07-23-2020, 03:21 PM   #11
Rmgibson
Drives: S2000, Fiesta ST
Did you ever get a resolution to this? I just picked up a 2015 FRS and it has the exact same issues.
Rmgibson is offline   Reply With Quote
Old 08-27-2021, 01:07 PM   #12
BradH_NC
Drives: 2013 FRS
I'm having this issue too. Did anyone resolve it?
BradH_NC is offline   Reply With Quote
Old 09-20-2021, 04:29 PM   #13
BradH_NC
Drives: 2013 FRS
Well dudes, for me... I just needed to replace the battery in my key fob. It's still strange to me that the buttons inside the door didn't work because of the fob battery.
The Following User Says Thank You to BradH_NC For This Useful Post:
Ultramaroon (09-20-2021)
Old 09-20-2021, 07:01 PM   #14
Just saw this thread. Strange! I thought the key start only has an RFID transponder.
Remote won't unlock doors. Need help diagnosing problem. DeviantBlue Issues | Warranty | Recalls / TSB 21 06-05-2018 02:23 AM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 10:50 AM
Remote lock/unlock not working zdaughtry1 Electronics | Audio | NAV | Infotainment 2 03-16-2017 10:16 AM
Auto Lock and Convenient Unlock delusional DIY (Do-It-Yourself) Guides 4 11-07-2012 05:34 PM
