Old 09-05-2018, 02:12 AM   #127
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by carlovestela View Post
Did you guys used tape measure, and tape?
Have to turn left and right the white screw.
For my winjets I used a tape and tape measure method I found online. It's hard to find a place to do it that people allow use of at night, but I used a high school parking lot that was relatively flat. Even then I found it a little odd.
So I had a friend bring my CX-5 GT which comes with factory LED headlights. Marked it's location 30 feet away from the wall and beam pattern relative to the wall using tape, parked the FR-S on the same tape and aimed around 1.5 inches below them.
This is a really crude and incorrect method but the tape method didn't give me the road coverage I wanted with a non retrofit hid setup. I have yet to be double flashed by oncoming traffic with these lights and they appear to not blind others as I'm not able to see into the cabins of other vehicles for the most part.
For your headlights which have a proper projector and led setup the tape method should work perfectly. You shouldn't have any issues.
Old 09-11-2018, 09:03 PM   #128
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Originally Posted by Rican_D View Post
Is your car factory halogens? I've noticed that happen on mine. I think it's the the drl wiring setup for the halogens.
Sent from my Pixel 2 XL using Tapatalk
Did you guys figure out a fix for the blinking high beams for the FRS?
Instagram: @battleship_86
It's more than a hobby it's a lifestyle.
KungFuWaffle is offline   Reply With Quote
Old 09-12-2018, 11:40 AM   #129
Chimera
Drives: FRS
It doesn't bother me, its momentary.
Old 09-12-2018, 02:54 PM   #130
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
I'm not really concerned it's like a half second blip. Everything working fine.
Rican_D is offline   Reply With Quote
Old 11-17-2018, 04:17 PM   #131
LeonardoDaVinny
NotVinnyy
Drives: 2013 White Pearl FRS
Originally Posted by Chimera View Post
It is with adapter harness. And yes, I'm using both signals atm.
Is this the Quick Swap Plug and Play (17+) option? I have a 2013 FRS! Just curious. Thanks in advance
LeonardoDaVinny is offline   Reply With Quote
Old 11-17-2018, 05:38 PM   #132
Rican_D
Rican_D's Avatar
It should be. Contact the people at trs, they'll confirm if it's PNP.
The Following User Says Thank You to Rican_D For This Useful Post:
Chimera (11-17-2018)
Old 11-17-2018, 07:55 PM   #133
Chimera
Drives: FRS
I have a 13frs, was pnp for me
The Following User Says Thank You to Chimera For This Useful Post:
LeonardoDaVinny (11-17-2018)
Old 11-17-2018, 08:02 PM   #134
LeonardoDaVinny
NotVinnyy
Wow, thanks for the quick response! I have been debating whether or not to buy these headlights. I have never taken off mine before, so I was a bit skeptical.
Old 11-17-2018, 10:15 PM   #135
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
It's pretty easy, just make sure to take bumper out properly trying to not break the clips. After that everything's pretty straight-forward.
carsebuco is offline   Reply With Quote
The Following User Says Thank You to carsebuco For This Useful Post:
LeonardoDaVinny (11-18-2018)
Old 11-19-2018, 08:46 AM   #136
sqd
sqd's Avatar
Drives: '13 SWP GT86
These work when replacing European GT86 headlights right? My car is a 2013, manufactured in 2012, not sure if newer models have different types of lights (HID, LED etc).
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 11-20-2018, 03:10 AM   #137
Mr_Eyo
Drives: 2017 Toyota 86
So post 48 also confirms my hyperblink issue in sequential mode, even on my 2017. Why aren't these things advertised as needing a hyperblink module?
Mr_Eyo is offline   Reply With Quote
Old 11-20-2018, 11:55 AM   #138
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
I have a set, that I might be willing to sell. If anyone is interested Pm me an offer.
Juanito08 is offline   Reply With Quote
Old 11-20-2018, 02:39 PM   #139
Chimera
Drives: FRS
That is a fair question. my guess is its prob oversight, most users are prob people who would have already gotten the much cheaper mod/upgrade of LED blinkers and flasher module.
Old 11-21-2018, 08:30 PM   #140
Mr_Eyo
I thought the MY 2017+ were LED compatible since my tail lights are LED/sequential and have no trouble. Anyway, I installed the hyperblink module and sequential turn signals on the headlights work correctly now. What a bitch to get at though.
Spec-D Headlights & Morimoto D2S HID Kit FyeaFRS Cosmetic Modification (Interior/Exterior/Lighting) 9 03-10-2017 12:19 AM
6K H11 Morimoto HID Kit Zero90 Exterior Parts (Aero, Lighting, Etc.) 2 05-20-2014 12:49 PM
FS: FRS HID Retrofit Kid (Morimoto) Khyron686 Exterior Parts (Aero, Lighting, Etc.) 2 04-21-2014 10:08 PM
Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards tbox Exterior Parts (Aero, Lighting, Etc.) 14 01-11-2014 02:18 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 02:03 AM
