Old 07-16-2018, 07:42 PM   #589
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by kuczynskika View Post
Nope, no headers yet. Still gonna do the Tomei ELs tho and an OP/FP. The biggest bitch has actually been my cosworth nameless exhaust... taking it in for some welding repair soon. Just develops cracks all over the place.
I’d also go flex fuel if I could but we no haz in Nevada.
Gotta talk to Neal @theracerline soon about getting the smaller pulley and some supporting mods!
More cracks? Jeez that really sucks. Luckily my header from Cosworth hasn't cracked. But the HKS set up is amazing.
The Tomei are good value. Though everyone always says Ace.
MS, CSCS, TSAC-F, CPT
Old 07-16-2018, 10:10 PM   #590
CSG Mike
CSG Mike's Avatar
There can only be one best!
Remember, the Ace headers include an overpipe and all hardware, every time, so it's actually not as expensive as people think.
Old 07-17-2018, 12:19 AM   #591
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Yeah yeah, where's that video of your exhaust setup?
kuczynskika is offline   Reply With Quote
Old 07-17-2018, 10:12 AM   #592
weederr33
weederr33's Avatar
Well I bought a directional mic and stand for my phone. I did the cold start but honestly it sounded like ass. Once warmed up it is fine. So I might just do that haha
Old 07-17-2018, 10:13 AM   #593
kuczynskika
Do it!
Old 07-23-2018, 09:28 PM   #594
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I just got my registration renewal notice for December 2018. My car is a 2013 so I figured I wouldn’t need to smog until the sixth year (2019) or after the sixth year (2020), but in my mind I thought maybe my 2013 was a 2012 manufacturer date or something. Luckily that is not the case.
Long story short: I have at least another year before I have to worry about Harrop passing the CARB cert.
Old 09-02-2018, 03:06 PM   #595
sw20kosh
Drives: 2013 Black FR-S
Friend and I made a MAF delete plug (motec m150 ecu doesn't use MAF sensor) to free up airflow to the supercharger:
Old 09-02-2018, 03:54 PM   #596
Irace86.2.0
I’m sorry. I’m going to need to see more pics of the complete engine/setup than some closeups of a part.
Old 09-04-2018, 06:40 PM   #597
Irace86.2.0
Anyone remove the bypass valve? If so, what does it entail? What was the effect? Smoother power transfers but worse gas mileage? Is it an internal blow off valve or a bypass that only opens at medium to high throttle input?
Old 09-04-2018, 06:47 PM   #598
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
It actually only opens at low throttle angles. It opens a path from the pressure side of the blower to the intake side of the blower - essentially a bypass that greatly reduces the power required to turn the assembly. It's a fuel economy saving device that allows the engine to revert to traditional "vacuum mode" when not under load.
PhyrraM is offline   Reply With Quote
Old 09-04-2018, 07:03 PM   #599
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Harrop TVS86 Owners Thread
This might be a strange question but did anyone notice a drop in the front ride height after installing the supercharger?
I guess in the same vein, does anyone know how much weight it actually adds?
Old 09-04-2018, 07:24 PM   #600
HaloKouki86
Drives: '17 Toyota 86
I would think anywhere from 60 to 80 lbs? Not sure though since I don't even have a kit installed. I'm just guestimating according to the Edelbrock kit weight.
Sent from my SM-N950U using Tapatalk
HaloKouki86 is offline   Reply With Quote
Old 09-04-2018, 08:37 PM   #601
Yoshoobaroo
TRACKBREAD
That's why I'm asking, people with coilovers don't really have this issue, but with lowering springs you may need a 1/4" spacer on the top hat to level it back out. Spacers like this: http://www.subtle-solutions.com/prod...roducts_id=286
60lbs/2.2kg/lb = 27.3kg
For a fairly typical front spring rate for lowering springs of 3.5 kg/mm that's 27.3/(2*3.5kg/mm) = 3.9mm decrease in ride height
For 80lbs that's 5.2mm
It's definitely significant, I wanted to know if the math translated to reality.
Old 09-04-2018, 10:46 PM   #602
Irace86.2.0
What would be the cost to gas mileage by removing it? Would there be consequences in any other way? Would there be improvements?
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
