#589 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
The Tomei are good value. Though everyone always says Ace.
#590 | |
Remember, the Ace headers include an overpipe and all hardware, every time, so it's actually not as expensive as people think. |
#591 | |
Drives: Harrop TVS86 STi BRZ tS
#592 |
Well I bought a directional mic and stand for my phone. I did the cold start but honestly it sounded like ass. Once warmed up it is fine. So I might just do that haha
#593 | |
Do it! Sent from my iPhone using Tapatalk
#594 |
Drives: Q5 + BRZ + M796
I just got my registration renewal notice for December 2018. My car is a 2013 so I figured I wouldn’t need to smog until the sixth year (2019) or after the sixth year (2020), but in my mind I thought maybe my 2013 was a 2012 manufacturer date or something. Luckily that is not the case.
Long story short: I have at least another year before I have to worry about Harrop passing the CARB cert.
#595 |
Drives: 2013 Black FR-S
Friend and I made a MAF delete plug (motec m150 ecu doesn't use MAF sensor) to free up airflow to the supercharger:
#596 | |
#597 |
Anyone remove the bypass valve? If so, what does it entail? What was the effect? Smoother power transfers but worse gas mileage? Is it an internal blow off valve or a bypass that only opens at medium to high throttle input?
#598 |
Drives: '17 BRZ PP, old Legacy SSs and SVXs
It actually only opens at low throttle angles. It opens a path from the pressure side of the blower to the intake side of the blower - essentially a bypass that greatly reduces the power required to turn the assembly. It's a fuel economy saving device that allows the engine to revert to traditional "vacuum mode" when not under load.
#599 |
TRACKBREAD
Harrop TVS86 Owners Thread
This might be a strange question but did anyone notice a drop in the front ride height after installing the supercharger?
I guess in the same vein, does anyone know how much weight it actually adds? |
#600 | |
Drives: '17 Toyota 86
![]() Sent from my SM-N950U using Tapatalk |
#601 | |
TRACKBREAD
That's why I'm asking, people with coilovers don't really have this issue, but with lowering springs you may need a 1/4" spacer on the top hat to level it back out. Spacers like this: http://www.subtle-solutions.com/prod...roducts_id=286 60lbs/2.2kg/lb = 27.3kg For a fairly typical front spring rate for lowering springs of 3.5 kg/mm that's 27.3/(2*3.5kg/mm) = 3.9mm decrease in ride height For 80lbs that's 5.2mm It's definitely significant, I wanted to know if the math translated to reality. Last edited by Yoshoobaroo; 09-05-2018 at 08:56 AM. |
#602 | |
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 04:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
