Old 08-08-2018, 01:32 PM   #99
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
High beam draws more current than low beam
Here's something peculiar. I was looking at the tech manuals 86 2017 and noticed that the the high beams uses more current than the low beam. If it's a device blocking the beam that uses 5 watts that would explain it.
Tech Manual
High Beam/Low Beam Headlight
34/29 watts.
pcguru2000 is offline   Reply With Quote
Old 09-02-2018, 07:45 PM   #100
ShadowWolf_99
ShadowWolf_99's Avatar
Drives: 10 Series #895
Got a three prong switch for my fogs but the wires from the harness have 4. Two reds hots and the other grounds? Or will this switch not work?it has a blue led status light too.
Sent from my SM-G950U using Tapatalk
PDX86 / 86 Sessions / 86Squad / DarkSquad
ShadowWolf_99 is offline   Reply With Quote
Old 09-02-2018, 07:48 PM   #101
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
You need to buy the specific switch and harness specifically for your car. Ok ne set is for illumination and 1 is for the fogs if I remember right.
https://parts.westcoasttoyotalb.com/...oaAg_vEALw_wcB
https://www.ebay.com/p/8416012060-TO...ff46c58&chn=ps
-B
HeresMyMind is offline   Reply With Quote
Old 09-02-2018, 07:54 PM   #102
ShadowWolf_99
-B
Is one red only for low volt led? I can make all sorts of connections I am an electrician by trade. I just want to make what I have work today now. I dont have time to wait for parts
Old 09-02-2018, 09:29 PM   #103
carlovestela
Drives: 2015 Firestorm FRS
Hello guys. Can i use 2017 brz headlights to my 2014 frs? Thanks
carlovestela is offline   Reply With Quote
Old 09-02-2018, 09:51 PM   #104
HeresMyMind
Yes. You will need to repin a few of the wires. And the electronic lever won’t work. But it’s not that hard!
-B
Old 09-03-2018, 02:09 PM   #105
ShadowWolf_99
So for the full break down I took this fully wired set of fog lights out of my friends frs and began putting it into mine. He kept his switch and I got a auto zone 3 prong toggle. The green plug for the original switch had 4 wires. I cut back to where the splice was made to split from one power wire to two wires and the put fork connectors on the ground(black), power in(red), and power out (yellow). The three prong says power at bottom, load middle and ground top. I tapped the power for that wire off my tails/turns so if they aren't on the fogs wont come on plus I'll get a ding if I leave them on. The problem begins when i turn on power for the running lights/ turns/tails and the flick the fog switch. Instant fuse pop. I've gone over YouTube and I did everything right the only issue that could be wrong is the way the internal of the switch works for the fogs. Anyone have any ideas what else it could be?
Old 09-03-2018, 02:34 PM   #106
ShadowWolf_99
I removed the ground and now I get the led on the switch but nothing to the fogs. Oh and then I found an issue. I have a bare wire touching metal. So i fixed that but still no lights.......
Old 09-03-2018, 04:40 PM   #107
ShadowWolf_99
Upgrading the relay harness. If that doesn't work then I have to check each individual wire for continuity.
Old 09-03-2018, 04:40 PM   #108
HeresMyMind
you could just run a very basic stand alone harness. and leave stock wiring alone.
-B
Old 09-03-2018, 05:35 PM   #109
ShadowWolf_99
-B
The old harness is outdated and finding relays for it is a pain as told to me by friends. So I got a modern relay attachment. I'm going to pin it and see what I get. If no lights then I'll tone all the wires
Old 09-03-2018, 06:21 PM   #110
ShadowWolf_99
Ok new relay harness in and..... nothing. Wires instantly getting hot. Damnit.
Old 09-03-2018, 06:30 PM   #111
HeresMyMind
want me to send you a schematic on a fog light harness?
Old 09-03-2018, 06:31 PM   #112
ShadowWolf_99
Sure cant hurt
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
