Old 08-28-2018, 04:02 PM   #1
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Rear wheel liner issue
So I noticed my passenger side rear wheel liner ripped at the bottom where it attaches with a pop clip. It seems like this would be a common issue, any one have a better replacement or fix for this?
Old 08-28-2018, 04:04 PM   #2
CSG Mike
CSG Mike's Avatar
It's not a common issue. Replace with OEM.
Old 08-28-2018, 04:11 PM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Really? I already found multiple threads about it coming loose, ripping, or dragging against the wheel.
https://www.ft86club.com/forums/showthread.php?t=99996
Just seeing if there was a better fix than replacing it with something that will fail again.
Old 08-28-2018, 04:33 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I have this too, I just sewed it together and put the pop clip back in.
N1rve
Old 08-28-2018, 06:09 PM   #5
CSG Mike
CSG Mike's Avatar
Generally it happens when you hit something and get extreme compression, with wheels that are too low in offset.
Old 08-28-2018, 06:53 PM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Stock suspension and wheels with 32k on the car. Cant recall hitting anything, but Its possible obviously.
Old 08-28-2018, 07:55 PM   #7
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You don't have to hit anything big. Think of all those small pebbles/rocks on the road. Now think how many of those are picked up by the tire and thrown into the fender liner. Now think how many times your wheel goes round, now multiply it by how fast you travel.
There's your answer. simple huh?
Old 08-28-2018, 08:34 PM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Yeah.... never said it wasn't. Just looking to see if there was a better solution than a stock replacement.
Or an eloquent repair for the stock part when it rips or sags. Maybe sandwiching it between metal and using the push pin? Idk...
Old 08-29-2018, 10:53 AM   #9
N1rve
N1rve's Avatar
You can try adding a metal washer to see if that helps pressing it down since the attachment hole is torn.
N1rve
Old 08-29-2018, 11:29 AM   #10
norcalpb
norcalpb's Avatar
The rear wheel deflectors are like $20 from the dealership.
You need 2 backing washers, but it is impossible to put them on the inside of the frame so they need to sit on the push clip before you push it in.
I have Verus suspension covers, so it’s important the rear wheel deflectors stay still in order to stay in front of the wheel deflector built into the suspension cover for mAx AeRo.
norcalpb is online now   Reply With Quote
Old 08-29-2018, 05:40 PM   #11
Summerwolf
Panda Trueno
Summerwolf's Avatar
You have pictures of your covers by any chance? I have thought about doing their rear diffuser and the cover combo.
Old 08-29-2018, 06:03 PM   #12
norcalpb
norcalpb's Avatar
Unfortunately I lost all my pics of them last month...but I’ll post some soon as there’s hardly any pictures of the combo on the internet.
And it is a great combo, it is actually very difficult to scrape as well being installed at the max height.
Old 09-01-2018, 02:17 PM   #13
norcalpb
norcalpb's Avatar
So here’s a couple (bad) pics of my solution.
Used 2 washers (clear damage on wheel deflector but w/e.
And here is a pic of the OEM and Verus wheel deflectors meeting. I wish there was a way to connect the two, as going high speeds pushes the oem deflector behind the Verus wheel deflector. I believe the shown gap is for rear brake cooling.
I’ll get a better pic when I rotate my tires this weekend.
Old 09-01-2018, 03:39 PM   #14
Summerwolf
Panda Trueno
Summerwolf's Avatar
The two washer thing worked for the bottom. I occasionally have to push one side in after higher speeds as well. Not sure how to fix that. I'm actually surprised verus hasnt done anything like the front deflectors back there to match the under panels they already have.
I know it's a cheap part and all....
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 08:49 PM
Wheel well liner CSkap21 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 01-20-2018 01:27 PM
WTB Pass side Wheel liner Trphotomediadotcom Want-To-Buy Requests 6 10-18-2015 07:30 PM
WeatherTech Floor Liner Issue VIPER Cosmetic Modification (Interior/Exterior/Lighting) 39 04-05-2015 07:58 PM
Wheel well liner snap tabs Taro Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 03-10-2014 09:22 AM
