Old 08-26-2018, 12:59 PM   #1
Nutrivce
Drives: ‘15 BRZ
Oil leak. Under the back seats
Just got a used brz yesterday, and it’s about 21k miles. Just noticed some oil leaking from the back in the middle under the back seats I believe. It is very slow and oil levels haven’t gone down. Anybody know what this is?
https://ibb.co/ibfoF9
https://ibb.co/mbD8F9
https://ibb.co/mrxPoU
https://ibb.co/cOER2p
Nutrivce is offline   Reply With Quote
Old 08-26-2018, 01:21 PM   #2
That is your dif. Get it in and filled ASAP. You have no idea how much much oil is left in there and could destroy it at ant time.
Tristor (08-26-2018)
Old 08-26-2018, 01:24 PM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Diff, fill it up.
Don't ask for leaks on internet if you don't know, it's kind danger. Tow it to a good shop asap, you can only see so much from the picture.
Old 08-26-2018, 05:56 PM   #4
Hello Nutrivce and welcome to our helpful forum -
Yep, like said, the differential is leaking oil -
hat seems to be a relatively rare happening.
If you are a DIY kind of guy, you may consider cleaning up the area, then see if you can tell where the leak is coming from. If it's leaking from the drain plug, I would suggest you replace the drain plug washer (might as well change the oil while you are at it).
If the leak is coming from another part, you may try tightening the bolts that hold the rear cover on (use torque wrench).
If it still leaks, unless you are a big time DIY person, I'd suggest you drive it slowly to have a shop and have them fix it.
OR
Do it the humfrz way, make an appointment at a shop (don't drive it in the meantime, except to the shop) and ask them to fix it -
Old 08-26-2018, 06:40 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
As others said, if you have AAA or roadside get it towed ASAP considering you didn't know what it was in the first place. It's most definitely differential fluid:
http://www.ft86club.com/forums/showthread.php?t=19218
That's how you fill it, if you can't do it get the dealer to do it.
Old 08-26-2018, 07:36 PM   #6
I don't know that a tow is really needed yet but it certainly needs to get in and be checked (or Ike Hum said check it yourself but if somebody doesn't know what the diff is they should be getting somebody else to check for now)
Old 08-28-2018, 04:58 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It doesn't need to be down on oil very much to start to damage the diff. You have no clue how much oil is in there. If you're handy and can get a ride to get oil & try and figure out the issue, or top it off and drive it to a shop and get it fixed or have it towed.
guybo is offline   Reply With Quote
Old 08-28-2018, 05:10 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I know right?
Sometimes when I partake on some herbal substances I worry about today's youth.
But it does provide hours of entertainment.
Trunk stuck... again. Back seats an option? jarviz Issues | Warranty | Recalls / TSB 0 04-07-2017 02:38 PM
How often do you have humanoids in the back seats? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 66 10-06-2016 12:35 PM
(NNJ) Scion FRS Base front and back seats AZP Installs Interior Parts (Incl. Lighting) 2 01-05-2016 01:50 PM
Do the front seats go all the way back in a lying down position sci3 Cosmetic Modification (Interior/Exterior/Lighting) 14 08-15-2014 06:31 PM
diy request: removing back seats Dispect DIY (Do-It-Yourself) Guides 31 01-03-2013 06:14 AM
