Old 12-30-2012, 01:12 PM   #1
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
diy request: removing back seats
Hi. I need help removing my backseats as I dropped a rivet into the hole under the backseats while trying to remove my tail lights. Thanks!
Dispect is offline   Reply With Quote
Old 12-30-2012, 03:35 PM   #2
BRAWL
Drives: Toyota 86 GTS Velocity Orange
Is there nothing in the manual?
I will be collecting my 86 in a few weeks and will be removing the rear seats just to see if the seat will travel any further back. I will make a little diy then
BRAWL is offline   Reply With Quote
Old 12-30-2012, 03:39 PM   #3
Dispect
Dispect's Avatar
havnt checked. but thanks. will look forward to it
Old 12-30-2012, 04:26 PM   #4
CheesusCrust
Drives: Subaru BRZ Silver 6MT
Could you PM if you make that? I could definitely use more space back, don't mind losing some trunk space either. One inch more of leg room would have been amazing
CheesusCrust is offline   Reply With Quote
Old 12-30-2012, 04:38 PM   #5
Supermassive
Supermassive's Avatar
I can make a quick one, it's suuuuper easy to remove the back seat lower cushions, you dont even need to remove the back rest to get to where the clip fell...i did the same thing so I know what you mean!
Supermassive is offline   Reply With Quote
Old 12-30-2012, 04:48 PM   #6
Supermassive
You wont get any more legroom because the back of the driver's seat actually comes in contact with the bump that houses the gas tank...removing the back seat cushions might provide a little more reclining but that's it...trust me I'm 6'5" so I definitely tried...
Old 12-30-2012, 04:52 PM   #7
Supermassive
Here ya go. It's not really removing the rear cushions, just so you can get under them. Removing the rear seats requires a bit more work and I am not quite ready to embark on that journey yet.
All you need is a 10mm Socket and Ratchet.
Undo this little fella right here:
And Pull up!
Thats where everything seems to end up that I drop in my trunk
Old 12-30-2012, 04:55 PM   #8
Dispect
Dispect's Avatar
And Pull up!
holy crap thats easy. ill go try it RIGHT NOW! thanks so so much.. hope i find the darn rivet
Old 12-30-2012, 05:02 PM   #9
Dispect
Dispect's Avatar
And Pull up!
Err problem. That lil fella is pretty damm hard to remove...
Old 12-30-2012, 05:55 PM   #10
BRAWL
I am also 6'5" and really want just an inch or so of room. Even reclining a bit more might help. Is the bump the same on both sides?
Regardless, I will play around a bit and see what extra space I can find
Old 12-30-2012, 06:03 PM   #11
Supermassive
The bolt? It's only one 10mm bolt, might need a bigger ratchet to break it, if i remember correctly it torqued down pretty damn tight. The little ring thing is actually attached to the seat so you dont remove that.
Old 12-30-2012, 06:20 PM   #12
Dispect
Dispect's Avatar
yeah i tried that. its super tight holy shit. im charging up my power tools now. hope that works. :/ if not, ill have to go get a ratchet. as of right now, i only tried removing it with a small 10mm wrench
Old 12-30-2012, 06:27 PM   #13
Supermassive
Haha!
Old 12-30-2012, 06:58 PM   #14
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Easy as pie, 1/2 inch ratchet with a small extension would do the job no problem.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Removing the Back Seat Matizzay Cosmetic Modification (Interior/Exterior/Lighting) 11 07-05-2014 05:43 PM
DIY Request- Removing Beat Sonic Antenna tamsau DIY (Do-It-Yourself) Guides 9 11-30-2012 11:00 PM
DIY REQUEST - Headers back exhaust install MaXimus DIY (Do-It-Yourself) Guides 2 11-22-2012 11:24 PM
2x Sparco Pro 2000 Fixed Back seats ADR approved Major Clod Australia Classifieds 1 10-24-2012 09:39 PM
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 03:11 PM
