| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#267 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Yup 17's clear with plenty of space. They are +38 offset.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#268 |
Drives: 2013 white out fr-s
17x9 will be close unless you're on coils, but I'm on RCE springs with -1.4 camber up front, 245/40 and I still managed to clear, but its maxed out, about 2mm of clearance
| The Following User Says Thank You to kuya For This Useful Post: | kevaughan (10-18-2018) |
#269 |
Drives: 2015 Firestorm FRS
Stock struts with trd springs
245/40/17 hankook evo 17x9+38 -0.4 front camber http://imgur.com/a/1oibIrE |
| The Following User Says Thank You to carlovestela For This Useful Post: | Kiibiiin (06-25-2018) |
#270 | |
What size center caps did you get?
#271 |
Drives: very carefully.
66mm x 58mm which doesn't really fit.
So I sanded it down to 65mm and wrapped the clips with 3M friction tape. |
#273 |
Drives: 2018 86 Steel / 97 MX-5
![]() transitioned my set on my trade-in, sitting on TRD lowering springs
| The Following User Says Thank You to Kiibiiin For This Useful Post: | Aipex8 (07-04-2018) |
#275 |
Drives: 2017 BRZ Limited
#276 | |
Drives: it's grey
No rear spacer. I could run one back there but I haven't fit one yet. I have been waiting for the CNC to not be locked in on a production job at work to run some personal stuff through. Intent is to make a hubcentric ring and spacer combo. |
#277 | |
I gotcha. I run extended studs and Kyo-ei spacers. Plan to run 3mm all around when I get my +38 57CRs in the next 2-3 weeks. I'll be running 245/40/17 so I think I need the little extra push for the best fitment. 255s tend to do it without spacers sometimes. |
#278 | |
Drives: it's grey
![]() ![]() edit: better pic/angle
| The Following User Says Thank You to .Kyle For This Useful Post: | jubella2 (08-28-2018) |
#279 |
Drives: DGM BRZ
Depends which tires you run too. The MPSS 245 has a tiny bit of stretch but they are on the narrower side for 245s. I've seen other brands that look more square on a 9" wheel in a 245/40
#280 | |
Appreciate it! Stoked to finally get wheels. I'll probably post to this thread once it's done. |
| 2015 New Wheel | Gram Lights 57Transcend | Concave 10-Spoke | Kami Speed | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 07-15-2019 05:47 PM |
| WTB Gram Lights | CRBCelica | Want-To-Buy Requests | 0 | 03-16-2015 07:21 PM |
| Gram Lights 57s-pro on FRS? | MrMarinakos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-27-2014 05:46 PM |
| Gram Lights in the GTA | Skurj | CANADA | 3 | 11-22-2012 09:41 PM |
| gram lights 57s pro | jdmboss86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 08-10-2012 12:58 AM |
